Old 12-10-2014, 12:14 PM   #2213
Choong86
Drives: Toyota GTS 86
Originally Posted by Brody602 View Post
Well you'll need a clutch, possibly flex fuel depending how you want to run your setup. 400whp should be possible on e85, e85 runs a lot cooler, depending on the temperature where you live, you may be able to skip on the radiator stuff for a while
yeah i wanna be able to switch between 98 and e85, would a flex fuel kit help for that?
from australia so summers are about 30-40 degrees celsius and winters are 10-20 degrees
one more question: would i be fine running by current 2.5'' motiv fp/op combo with a 3" tomei exhaust with the system, or should i switch out my fp/op to 3'' as well
Choong86 is offline   Reply With Quote
Old 12-10-2014, 12:18 PM   #2214
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Full Blown Turbo Kit Owners Topic
I think fp/op might need to be fbm's due to the turbo manifold, i'm not 100% sure though, My car is in their shop getting completely built, 3" from the turbo back. Flex fuel would definitely be way better, you only need 1 map, and you also wouldnt have to worry about being almost out of fuel before switching back and fueling up, also don't have to worry about remembering to switch maps, which could be deadly for the engine. fullblown sells a plug and play flex fuel kit for 749$ i believe (you'd just need a tune), you'll be okay for temps in the winter, but probably need the upgraded rad in the summer depending how hard you push it, their oil cooler kit is a good thing to consider as well
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-10-2014, 12:23 PM   #2215
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Your fp/op is fine. I would get a bigger oil pan. Either fullblown cast pan or a racerx or map pan. More capacity is nice and you won't have to drill and weld the stock pan.
Old 12-10-2014, 01:48 PM   #2216
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Your FP/OP will be fine. I would prioritize your upgrades as a clutch and a boost/wideband gauge. The flex fuel kit can wait till you have it running properly on 98.
Old 12-10-2014, 02:03 PM   #2217
willharp360
I just recently purchased the base kit with the gt2871r turbo. After talking briefly to FB they recommended upgrading the fans, radiator and clutch. This will be a daily driver and I'm aiming for the typical 300-320hp mark for now. Anything else y'all can suggest to upgrade?
willharp360 is offline   Reply With Quote
Old 12-10-2014, 05:10 PM   #2218
Dipstik-sportech
Dipstik-sportech's Avatar
A wideband and boost gauge!!!! Thier shroud and fan combo, rad, bigger oil pan, clutch, tires, brake pads and fluid.
Old 12-10-2014, 05:12 PM   #2219
Brody602
Drift King
Brody602's Avatar
@willharp360 or... If you're anything like Dipstik, keep the oem tires because drift car. Hahah
Old 12-10-2014, 06:04 PM   #2220
D_Thissen
D_Thissen's Avatar
Says the guy who ran 360whp on Prius tires, and finally upgraded his brakes @Dipstik-sportech
Old 12-10-2014, 06:05 PM   #2221
Brody602
Drift King
Brody602's Avatar
Pretty sure he ran 430whp on them tires too haha
The Following User Says Thank You to Brody602 For This Useful Post:
Dipstik-sportech (12-10-2014)
Old 12-10-2014, 07:01 PM   #2222
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Anybody running a catted FBM setup?
Alltezza is offline   Reply With Quote
Old 12-10-2014, 09:48 PM   #2223
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
dumb question i cant remember from the install.. are the FBM 550cc injectors bosch ?
PolishFrs13 is offline   Reply With Quote
Old 12-10-2014, 10:09 PM   #2224
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Bosch ev14
pt#0280158117
IIRC I beleive tut said they were basicly 07-10 Ford GT500 injectors. I'm not sure if these were reworked/rebranded by Injector Dynamics though.
The Following User Says Thank You to Kiske For This Useful Post:
PolishFrs13 (12-10-2014)
Old 12-10-2014, 10:14 PM   #2225
PolishFrs13
building life
Originally Posted by Kiske View Post
Bosch ev14
pt#0280158117
Just curious about it, debating on getting a flash and go from @delicoustuning (reason being is for the CEL P0441 and traction control light still going on. i have check and clapped all my lines and still comes up) tired of clearing it.. or a aem failsafe gauge and frontpipe
Old 12-12-2014, 05:18 PM   #2226
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
So, has anyone else noticed this about their header?
These first two pictures show that I have one of the flanges lined up the best I can to the factory manifold, which fell off the factory studs/block with NO issues.
This picture shows how far off this flange/the runners are in comparison to having the other flange clocked correctly. You can also see in this picture how far off each runner is in comparison to the mounting hole it's next to. These runners should be aligned on center, and the flanges appear to be CNC cut so I do not think their mounting holes are incorrect. It appears to be either a sloppy job of initial fixturing/welding, or it was sloppy to begin with and has moved with the heat cycles after being on two cars before mine.
The flanges are obviously twisted. It doesn't look like it was beat up during initial installation or shipping (I bought it second-second hand), and the carbon build up on the flanges themselves show that they're not sitting where they should be.
The runners themselves are off compared to the flange too, and you can see that by looking down the runner and seeing how much was filled in by weld.
Any ideas on how to correct this? The manifold has absolutely NO spring to it and I can't force it on to the studs, so I'm thinking that I'll either have the guys at FBM throw it back on their jig and repair it, or I can just cut the flanges off and weld new ones on myself.
Travisty75 is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
