Old 12-10-2014, 11:16 AM   #183
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
@troek helped me with updated definitions which worked perfect.
Ill be switching back to 1x definitions since i just picked up a vortech and will be using oft300 map.
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 12-10-2014, 11:20 AM   #184
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by acj47 View Post
According to this thread, I should have the tables "MAF Correction After Start (In Gear)" and "MAF Correction After Start (Neutral)" in the "Mass Airflow / Engine Load" folder of the .bin file.
I am using OFT v2.06 A01C bin file (Stg 2 E85) and these tables are not present. There's a lot of talk about what to do/not to do to add these using definition files from romraider, github, etc...
Can Shiv or someone else confirm what is needed to get these two tables in the v2.06 A01C bin file? Thanks!
The 2.x files are based on the B01 definition, I believe. So you're going to need to grab the appropriate XML blocks for MAF After Start (In Gear) as well as the (Neutral) one, paste them into your definition file, then apply the definition and reopen the ROM in RomRaider. Should show up then.
The Following User Says Thank You to Foobar For This Useful Post:
acj47 (12-10-2014)
Old 12-10-2014, 11:32 AM   #185
acj47
acj47's Avatar
I just checked, and it appears the B01 does not have the (Neutral) or (In Gear) information either.
acj47 is offline   Reply With Quote
Old 12-10-2014, 12:11 PM   #186
Foobar
SLO NO MO
Foobar's Avatar
Grab the definitions from TD-D's github and paste the relevant blocks into the OFT 2.x ones.
Old 12-10-2014, 01:10 PM   #187
acj47
acj47's Avatar
Oft guys just be carefull using defs off github as the oft roms can have the calid changed and hence need thecmatching defs from the openflash site. eg an oft 700C rom is exactly the same cas a 900C or an A01C just with calid changed. the oft guys alter the defs to match if you get github defs and your oft rom has been calid changed its not going to work and the tables will be all screwed up.
it will work if the rom yo have is the native rom the series was created wiith ie the latest rom in series
So if I am using OFT v2.06 map and my calid is A01C, which file do I need to reference?
Thank you.
Old 12-10-2014, 01:20 PM   #188
Foobar
SLO NO MO
Foobar's Avatar
Thank you.
The B01C definition should have the appropriate mappings.
Specifically, you'll need
Code:
		<table name="MAF Correction After Start (Neutral)" storageaddress="11C868">
		  <table type="X Axis" storageaddress="11C81C" />
		  <table type="Y Axis" storageaddress="11C848" />
		</table>
		<table name="MAF Correction After Start (In Gear)" storageaddress="11C964">
			<table type="X Axis" storageaddress="11C918" />
			<table type="Y Axis" storageaddress="11C944" />
		</table>
and
Code:
    <table type="3D" name="MAF Correction After Start (In Gear)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
      <scaling units="g/s" expression="x*0.004577637" to_byte="x/0.004577637" format="0.0" fineincrement="0.1" coarseincrement="1" />
      <table type="X Axis" name="Coolant Temperature" storagetype="float" >
        <scaling units="DegreesF" expression="(x*1.8)+32" to_byte="(x-32)/1.8" format="0.0" fineincrement="1" coarseincrement="10" />
        </table>
      <table type="Y Axis" name="Idle Mode" storagetype="float" >
        <scaling units="Mode Counter" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="5" />
      </table>
    </table>
    <table type="3D" name="MAF Correction After Start (Neutral)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
        </table>
      </table>
    </table>
I think that's all you're missing.
The Following 3 Users Say Thank You to Foobar For This Useful Post:
acj47 (12-10-2014), Andrew025 (01-05-2015), RavioliG (01-26-2015)
Old 12-10-2014, 01:36 PM   #189
acj47
acj47's Avatar
Code:
		</table>
		</table>
and
Code:
        </table>
      </table>
    </table>
        </table>
      </table>
    </table>
Thanks - just figured that out. My problem was this tidbit of information: Why is my Tune Calibration ID different from my stock ROM or in OFT/OFM...OFT tunes are generally based on the latest ROM revision for your ROM type...For USA/Canada type = C eg ZA1JB01C...2.0X tunes based on B01 revision
So once I added the two parts of code from the B01 file https://raw.githubusercontent.com/TD...R_ZA1JB01C.xml I then opened up in RomRaider and: success!
Thanks to all who helped!
The Following User Says Thank You to acj47 For This Useful Post:
Old 12-10-2014, 01:43 PM   #190
Foobar
SLO NO MO
Foobar's Avatar
success!
Right on! I've been using the quiet cold start through cold weather (right at freezing) and haven't had any issues. I know the primary purpose of the original start parameters are to make the cats more efficient, so I'm feeling a bit guilty about that, but then again, I've already eliminated one of the cats, so I'm already in the hole I guess.
Old 12-10-2014, 01:55 PM   #191
acj47
acj47's Avatar
Exactly - I don't want to be the pesky neighbor with the loud exhaust, especially early in the morning. I changed the Ignition Timing Post Start values to 0 (0.04) yesterday, but the car still started up at ~2100 RPM and threw the CEL P050B (Cold Start Ignition Timing Performance). I'm hopeful that editing the MAF Correction AFter Start (In Gear) & (Neutral) tables will eliminate throwing the CEL and bring down the idle RPM to my Idle Speed Target values.
This forum rocks
Old 12-10-2014, 03:01 PM   #192
Foobar
SLO NO MO
Foobar's Avatar
This forum rocks
My ignition timing post start is set to -8.05 through the entire row, MAF Correction After Start is set to 8, 7, 5, 5, 5, 4, 4, 4, 4 on all rows for both in gear and neutral, and for good measure, I disabled the DTC for P050B - not sure if I needed to do that one.
Old 12-10-2014, 03:14 PM   #193
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Last weekend I started my car in -15C a couple times, zero issues.
- AdrianG
AdrianG is offline   Reply With Quote
Old 12-10-2014, 03:27 PM   #194
acj47
acj47's Avatar
I left it enabled to see if it pops up again. I'll let you know what I find out.
Old 12-10-2014, 05:09 PM   #195
steve99
Drives: FT86
I modded a tune or a guy in usa and he threw up same cel P050B , its definitly due to change to ingintion timing post start was using -4 instead of -15.
just disable the code.
we never throw that code on G roms, must be something dierent in usa roms.
you need to alter the maf correction at statup or the car will still idle high and not follow the idle maping settings at startup
Old 12-10-2014, 05:42 PM   #196
phrosty
I've been using a cold start tune for a while and haven't had any codes, but I modified mine to be slightly less aggressive down low since I live in a place with freezing temps.
phrosty is offline   Reply With Quote
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
