Old 12-09-2014, 09:19 PM   #71
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
build thread shows 379
Build thread shows a high of 393wtq but I usually drive it somewhere around 370wtq. I just replaced a transmission with a sheared 4th gear in a car that only made 350whp and ALOT less torque.
Old 12-09-2014, 11:15 PM   #72
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
So don't do 4th gear pulls?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-08-2015, 12:32 AM   #73
TekPrime
Chef
TekPrime's Avatar
Drives: 2014 Subaru BRZ Limited (D6X)
Any possibility the guy shredded his syncros because he can't shift properly, and that the transmission from the wrecked cars had drivers with the same talent?
TekPrime is offline   Reply With Quote
Old 01-08-2015, 12:52 AM   #74
sachu
Drives: rocketship
^ my thoughts exactly.
sachu is offline   Reply With Quote
Old 01-08-2015, 01:18 AM   #75
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I've stalked around the forums for a while now, and I've always thought about having a turbo BRZ, so I've tried to pay attention to those threads.
Heard lots of complaints about this car and FI.
This is really the first time where I've seen so many complaints about how the transmission gives out....
And you keep mentioning the synchros giving out, so is it FI or is it something unrelated thats screwing up your trannys?
Old 01-08-2015, 02:44 PM   #76
Reaper
Reaper's Avatar
Drives: violent
My first transmission grinded in second straight off the showroom floor. Ive pulled coroded syncros from the fa20 transmissions in two separate cars on 3 separate transmissions both turbo and non turbo. Both 5th gear and 2nd gear. My transmission that sheared 4th was brand new and had excessive wear on the 2nd gear syncro but didn't grind yet. There is a syncro problem from the factory. My used transmission had excessive wear on the reverse gear but is holding up. Though 3rd crunched at -3 this morning. My car has no clutch drag and stock shifter. My current transmission has a cooler on it. Heat may be hurting these transmissions but it's too cold here to tell. Element tuning has the same findings as me last we talked.
The Following User Says Thank You to Reaper For This Useful Post:
Darryljr11 (03-15-2015)
Old 01-08-2015, 02:48 PM   #77
Reaper
Reaper's Avatar
Drives: violent
Horsepower has nothing to do with syncros unless there is a heat issue but it's too cold for me to test that now. And I've only been monitoring transmission temps on my most recent one and its lasted the longest. But I've seen first hand 4th gear grenade at 350whp in my friends car and 450whp in my car. Both on street tires. Both rather violently.
Old 01-08-2015, 02:49 PM   #78
Reaper
Reaper's Avatar
Drives: violent
Nope.
Old 01-08-2015, 03:00 PM   #79
PandaSPUR
PandaSPUR's Avatar
From everything you've said in the last 3 posts... It sounds like you have bad luck with transmissions from the factory rather than the transmissions have issues with FI.
Synchros breaking? As you said, not HP/TQ related, so not FI related.
2nd gear grinding when brand new? Sounds defective
4th gear breaking, again w hen brand new? So unless you installed FI on a brand new car, this also sounds like you had crappy luck with a defective transmission.
I'm not trying to sound like an ass or anything, I just dont see how those 3 problems are caused by FI?
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
ChrisD (01-21-2015), hmong337 (01-08-2015)
Old 01-08-2015, 03:15 PM   #80
Reaper
Reaper's Avatar
Drives: violent
I actually said the syncro problem is not caused by FI and I've pulled bad syncros out of car that were not FI
I've said that multiple times. I even tried to take a dealer to court over it. (They said it was FI fault I said it was not) toyota agreed with me on it but it was not worth the lawyer costs when I found a few transmissions for 500$ each.
Shearing 4th gear is 100% FI. Me, @Synack, fullblown, evasive, element.....and a host of others have all sheared 4th gear around the 400whp mark.
Old 01-08-2015, 04:59 PM   #81
BRZPDX
Boosted Member
BRZPDX's Avatar
So what about the threshold for AT's? I'm pushing about 300whp/225wtq with a trans cooler atm, has anyone blown them up yet?
Old 01-08-2015, 05:06 PM   #82
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Where did you find transmissions for 500? I'm going to need one. Fourth gear is a problem and second and fifth are becoming worse every time I drive
GotBRZ1691 is offline   Reply With Quote
Old 01-08-2015, 05:44 PM   #83
PandaSPUR
PandaSPUR's Avatar
Damn. So I'm guessing you guys experience these failures while at the track or in some other scenario where you're shifting near red line right?
In other words, if I plan on mostly casual driving and just going to the track once in a while, my transmission should last longer?
Old 01-08-2015, 11:05 PM   #84
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
How are you needing a gearbox when you're not even turbo?
hmong337 is offline   Reply With Quote
WTB FA20 Stock Cross Want-To-Buy Requests 22 08-19-2014 02:59 PM
WTB FA20 Stock Cross Want-To-Buy Requests 1 08-01-2014 06:47 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 07:44 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Stock AISSIN Transmission Power Capacity Don@Accelerated Forced Induction 37 07-03-2013 10:15 PM
