Old 12-08-2014, 04:14 PM   #15
raven1231
I agree looks great! Would like to see a slightly smaller gap though. Otherwise I think it looks great!
raven1231 is offline
streetzeal (12-08-2014)
Old 12-08-2014, 04:26 PM   #16
streetzeal
streetzeal's Avatar
Drives: 2013 Scion FRS
Originally Posted by KAR View Post
on the corner where it meets the black side of the bumper.. you can maybe make it flow better.. if you can make it the same "surface" as the black part of the bumper, then that will be golden..
Hmmm, yes this was one we contemplated about and ended up mating it to the edges as best as possible, the gap and brackets are very much exaggerated in these pictures as they are all taken very low. I will have to post some street pictures to show it cant really be seen from a higher angle. With fiberglass it would be near impossible to match the plastic weave of the OEM bumber but again unless your very close its difficult to tell.
streetzeal is offline
Old 12-08-2014, 04:27 PM   #17
streetzeal
streetzeal's Avatar
Originally Posted by jvincent View Post
Any chance you can post a picture from directly under the lift?
I'll second the mounting bracket comment and the fins as well.
I dont have any currently but i'll try and get it up again and snap a couple. it will give everyone a better idea of how far back the diffuser mounts.
Old 12-08-2014, 04:36 PM   #18
KAR
Drives: Whiteout 6spd
optional vortex generator on the sides to hide those brackets.. where does it connect on the bottom by the diff.. probably need a bracket to keep the wind from ripping off at high speeds..
KAR is offline
The Following User Says Thank You to KAR For This Useful Post:
Old 12-08-2014, 04:45 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
but anytime you can redirect air from being caught in the rear bumper you are reducing drag.
Are you?
Drag isn't just some air caught in the bumper, vortices that induce drag or lift or both would make the car less aerodynamically efficient.
While I agree these look great, I think it should just be left at the "better looking than Driveway Labs or OEM diffuser" in the looks department, and nothing else. To say it improves aerodynamics without facts is kind of a generous stretch.
-alex
mav1178 is offline
Ammonia (12-20-2014)
Old 12-08-2014, 04:47 PM   #20
streetzeal
streetzeal's Avatar
We did actually make a separate mold for those but decided to scrap them after we installed them - it didnt quite flow with the lines but we have designed the brackets as side valance pieces as an option (no pictures yet) the mounts are very secure and tested at high speeds with no noise/vibration. This will be version 1 that will be released - I appreciate the ideas everyone has and we will be looking into ver2 molds in the future.
Old 12-08-2014, 04:55 PM   #21
streetzeal
streetzeal's Avatar
Originally Posted by mav1178 View Post
Are you?
-alex
Nothing but theory yet, but will have to get back to you in time.
Old 12-08-2014, 04:58 PM   #22
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It does look good
SkAsphalt is offline
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 12-08-2014, 05:05 PM   #23
try2findmark
Drives: Bukkake FR-S
finally a good looking diffuser, definitely interested in one!!
try2findmark is offline
The Following User Says Thank You to try2findmark For This Useful Post:
Old 12-08-2014, 05:27 PM   #24
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
I'm in to buy this already. Hurry up and produce.
Care to shed light on your body of work though? Or your website?
I googled and couldn't find anything at all.
Follow me on IG: @rougarou86
boucher is offline
Old 12-08-2014, 05:32 PM   #25
raven1231
In for price estimate
Old 12-08-2014, 05:39 PM   #26
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Check the comments on the top left picture here:
http://instagram.com/streetzeal/
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline
The Following 2 Users Say Thank You to phobos512 For This Useful Post:
raven1231 (12-08-2014), streetzeal (12-08-2014)
Old 12-08-2014, 05:55 PM   #27
raven1231
Thank you! In that case I'm interested in first run discount if still being offered.
Old 12-08-2014, 05:57 PM   #28
streetzeal
streetzeal's Avatar
Thank you!
The Following User Says Thank You to streetzeal For This Useful Post:
phobos512 (12-08-2014)
Diffuser LPC_FRS Cosmetic Modification (Interior/Exterior/Lighting) 0 08-04-2014 05:19 PM
WTB OE Diffuser skyloran Exterior Parts (Aero, Lighting, Etc.) 0 06-25-2014 02:33 PM
WTB: TRD Diffuser becauseracecar1 Exterior Parts (Aero, Lighting, Etc.) 0 04-07-2014 11:10 PM
OEM Diffuser Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-10-2014 10:18 AM
Where to buy brz diffuser? DarkCard Cosmetic Modification (Interior/Exterior/Lighting) 9 11-09-2012 12:18 PM
