Old 05-08-2012, 09:57 PM   #43
Chauntalei
Drives: Non-BRZ
I ordered mine in DGM, Premium 6MT w/spoiler, and after seeing those pics of the DGM, I am VERY glad I made that choice! My local dealer only had a silver one in the showroom when I made my order, so I picked the color blind for the most part.
Chauntalei is offline   Reply With Quote
Old 05-08-2012, 10:02 PM   #44
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
Originally Posted by Subie View Post
It's not all about power you know. The Subaru head unit appears vastly superior to the base Scion unit.
Oh god, not this again! It's enough we have to deal with it arguing over the chassis and drivetrain... SHEESH!
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
The Following User Says Thank You to Lighting Red For This Useful Post:
Subie (05-08-2012)
Old 05-08-2012, 10:20 PM   #45
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I had typed up a response based on my electrical engineering degree but I know it will set off a whole frs vs BRZ argument so I won't even bother.
Long story short: they will sound the same
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following User Says Thank You to Spaceywilly For This Useful Post:
Subaruwrxfan (05-08-2012)
Old 05-09-2012, 12:06 AM   #46
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Haha, you ordered the same car as me (except the spoiler) and you live 5 min away (I am in San Mateo).
uspspro is offline   Reply With Quote
Old 05-09-2012, 12:10 AM   #47
MRZ415
Drives: 2015 Subaru WRX
there will be at least 20-25 DGM BRZ in the area.
DGM here too.
MRZ415 is offline   Reply With Quote
Old 05-09-2012, 12:19 AM   #48
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Originally Posted by Subaruwrxfan View Post
I'm not concerned so much about the head unit as I am the actual speaker components. I'm not very knowledgeable about stereo stuff, so someone will have to enlighten me. Do the cars both have the same speakers? Will the Subaru sound as good as the Scion?
They do use same woofers size-wise, so should be the same speakers. But remember, Subaru always puts crappy speakers even with Premium sound. Literally, 1 inch neodymium magnets, very lightweight. In return, they are very sensitive, designed to output higher acoustic dBA with less power.
Look, the ones in the middle are Subaru speakers, vs aftermarket:
Soo, even with 4x50 Watt MOSFET amp Pioner unit in BRZ (which is on par with aftermarket, frankly), I plan to replace speakers with Polk (most likely) or better + amp to drive true components. Subaru 'components' usually use 1st-order high pass passive filters for tweeters (I expect similar in BRZ/FR-S, even with additional mid-'speaker'). I'll be replacing those with active filters at the line-output prior to amp. Thats what works for me.
Without the amp, you can still an drive true component speakers, but you need to pay attention to its sensitivity/efficiency. 91 dBA or better is what you want. These, for example, are good speakers to set the front stage with little money: [ame="http://www.amazon.com/Polk-Audio-DB6501-6-5-Inch-Component/dp/B000P0R6LQ/ref=sr_1_1?ie=UTF8&qid=1336536712&sr=8-1"]Amazon.com: Polk Audio DB6501 6.5-Inch 2-Way Component System (Pair, Silver): Car Electronics[/ame]
Also, little RAAMatig goes a long way: http://www.raamaudio.com/products/RAAMmat-BXT-II.html and this: http://www.raamaudio.com/products/En...and-Stick.html
There is a discount for members of Subaru Forester club. You may want to review Sea-Scooby's threads, which are plenty descriptive on sound setups, including closed enclosure subs: http://www.subaruforester.org/vbulle...resters-29648/
Oriental Life is offline   Reply With Quote
The Following User Says Thank You to Oriental Life For This Useful Post:
Subaruwrxfan (05-09-2012)
Old 05-09-2012, 04:59 PM   #49
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
Without the amp, you can still an drive true component speakers, but you need to pay attention to its sensitivity/efficiency. 91 dBA or better is what you want. These, for example, are good speakers to set the front stage with little money: Amazon.com: Polk Audio DB6501 6.5-Inch 2-Way Component System (Pair, Silver): Car Electronics
Thank you for the very informative post. Just added those speakers to my wish list on amazon, lol. They're plug and play right? If the stock speakers don't impress me, this will probably be my first mod.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 05-09-2012, 08:26 PM   #50
Oriental Life
If door speakers are 6.5" and do not require spacers, swap should be straight. I'd still add a little sound deadening material for lower mids quality.
I have no idea yet how dash speakers are mounted. If its like in other cars I used to have, it will be PITA to remove those if they don't use clippers. At the factory they put in the dash first, mount speakers and than glue the windshield in. Last resort will be to leave original twitters-high-mids, then, tune dash speakers to play everything above 5-6 kHz with pre-amp crossover.
I don't have a plan yet for rear speakers - it will depend on available space. I like my backstage to act as mid bass, with 8 inch speakers and sometimes add directional tweeters in the rear to give overall sound some space and clarity. But this will be hard to pull off in BRZ, and I'll have to settle for an upgraded 4" speakers. We'll see when the car finally gets here. Maybe by that time someone with FR-S or East Coast BRZ will get to it faster than I'll get a chance and we'll have more info.
Old 05-10-2012, 02:00 AM   #51
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
I hope you are wrong about this because it'll be an expensive & time consuming bitch if people want to replace them with higher end components.
I wanna run some high end fronts like Audison, Hertz, Rainbow, etc, if the stock system isn't adequate enough for my taste.
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline   Reply With Quote
Old 05-10-2012, 02:36 AM   #52
Oriental Life
Looking back at dash speakers, they are very close to the windshield:
But its not the end of the world. Subaru used to put higher quality tweeters into its setups. Considering mids are going to be covered by quality door woofers, those high-mids in the dash are not really needed. As one of my former colleague, sound stage engineer, used to say "Those are tweeters, they 'tweet', there is nothing to it" Quality crossover should solve this small problem.
Between running errants and stock-like setup, I'll go with the later.
Finally sat in a BRZ today BattleArmor BRZ First-Gen (2012+) — General Topics 41 03-12-2012 06:17 PM
Interior space for a tall person? MXRider BRZ First-Gen (2012+) — General Topics 22 03-09-2012 01:50 PM
ATTENTION METRO HOUSTON AREA if you want to see the BRZ in person SeaWall BRZ First-Gen (2012+) — General Topics 6 03-01-2012 12:06 PM
BRZ/FRS LAAS In-person Experience Giccin BRZ First-Gen (2012+) — General Topics 17 11-22-2011 03:01 AM
Finally found another AE86 for sale.. EJ20 Other Vehicles & General Automotive Discussions 11 06-21-2011 03:19 AM
