Member's Car Journals Car journals by our members. |
#15 |
bRz
Drives: Subaru Brz
Dam bro sucks it melted it down a bit, you should of wrapped the headers.
#16 | |
Turning is for Nerds
Drives: 35 characters is not enough
Can't say I'm surprised, noticed IATs climb to the 70s once while I was waiting in the queue at an autocross
#17 |
Running the car without the primary resonator end up giving some pretty high LTFTs at low RPMs around -10 or so. Today I did a bit of work to stop the resonator from melting
First I added some gold reflective tape ![]() But just on the bottom so it still looks pretty clean up top ![]() And added a pop clip for easy removal in the future ![]() This should stop the plastic from melting any further ![]() |
#18 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
Nice car and enjoying the mods. the heat shield rear tray was clever. That header, though. Packaging the manifold on the flat fours is a real PITA, but to bring it up in front of the engine like that where it can radiate all that heat can't be the best approach. You couldn't fit Bill Clinton's definition of "is" between the tubing and your crank pulley.
#19 | |
Yeah, unfortunately its the only way I've seen which allows for long enough runners to achieve a nice mid range torque boost. It seems to work pretty well for most of the turbo guys without many melting issues, but none of them re-use the stock airbox. Clearance to the crank pulley isn't as bad as it appears in this picture, but it is close. The manifold actually kind of goes around the outside of the CP if viewed from the front and ends up closer to the fans than the block.
The Following User Says Thank You to Decay107 For This Useful Post: | kendalldwhite (12-07-2014) |
#20 |
Winter mode activate! Only took me a quick drive a few days ago to realize how useless the AD08s are in the cold/wet. I threw a plasti dipped set of OEM wheels and tires I picked up pretty cheap.
![]() Not a huge fan of the plasti dip, but I'm far too lazy to remove it all. Yes they are in fact Subaru wheels, no I'm not going to bother cleaning them (can't really figure out how to do it on plasti dip anyway). ![]() And here is my custom "oil cooler block off plate". I've found that my oil tends to run too cold in the winter despite having a thermostatically controlled oil cooler kit, this lets it get nice and toasty even if I'm just driving around town. ![]() |
#21 |
LCAs came in today
![]() ![]() And the list of things that need to occur before the track season starts up ![]() |
#22 |
Took a quick spin in Ultramaroon's car today with the clutch slave cylinder modification, bought one about an hour later after arriving back home. Totally removes the Fischer Price feeling from the clutch.
http://www.ft86club.com/forums/showthread.php?t=77390 |
The Following User Says Thank You to Decay107 For This Useful Post: | Ultramaroon (03-25-2015) |
#23 |
Installed my control arms today. Still need an alignment, but I roughed it in pretty well with a set of calipers
![]() Also just found out that MCA was chosen as the spec damper for the Australian 86 PRO-AM series, which means I can now say I have racing suspension ![]() |
#24 |
So, busy week this week. The SPL arms I received did not have enough camber adjustment available for my rally-stance car. The guys at SPL (specifically Pat) express shipped me some extended adjusters, and some extended heim joints just in case the adjustment screws were not enough. Great folks to deal with!
I got aligned and the setup I'll be running this year are (at basically stock height) -3.1 per side front camber 0 toe -1.7 per side rear camber .04* toe in Brake fluid changed out and Project Mu Club racers installed, no impressions yet as they have not been up to proper operating temperature. I also removed the speed bleeders, pretty sure they were letting air into the system and I probably need to reapply the thread sealant before they work again. I got an updated nameless front pipe with the new spherical resonance chamber, sounds far less raspy than the old can style. I can actually rev the car out on public roads again without feeling like an ass. First track day of the season is this Saturday! |
#25 |
Ordered a larger oil cooler core and I plan to prototype some ducting to make it more effective. Target oil temp is 220 max during a 20 minute session. Might also design a blank off plate for winter driving, I've found that even with a thermostatic takeoff plate, most air to oil radiators overcool in the winter.
#26 |
JHerbert Racing
Drives: 2013 Scion FRS
Loving your build. Sub'd for updates
The Following User Says Thank You to Takumi788 For This Useful Post: | Decay107 (04-07-2015) |
#27 |
Well two track weekends in a row down. New brakes are doing the trick perfectly, as I'm now running out of tire well before I run out of brakes. It's been cool (mid 60's) so the current set up isn't having any heat issues at all, saw oil temps stable around 220 for a full 40 minute session this past weekend.
![]() ![]() ![]() Played for a bit with an R1 powered Lotus Seven before he totally walked away from me. Little more power and tire and I'd have had him ![]() ![]() |
The Following User Says Thank You to Decay107 For This Useful Post: | NLSP (04-08-2015) |
#28 |
Drives: '18 STi
Hey man! How did you like your Muffled Track Pipe with the rest of your exhaust setup? Was it unbearable or annoying whatsoever? Was there drone?! :O
My Ultramarine FR-S | evilconcarne999 | Member's Car Journals | 25 | 07-14-2013 09:16 PM |
ultramarine | Splat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-14-2013 07:31 PM |
AZ: Ultramarine 6MT FR-S FS 25k | Tujin | Cars for Sale/Trade | 0 | 02-21-2013 06:37 PM |
Ultramarine! | Loki556 | AUSTRALIA | 17 | 09-08-2012 08:27 PM |
FrX's Ultramarine MT | FrX | Member's Car Journals | 22 | 06-26-2012 05:53 AM |
