Old 12-06-2014, 07:01 AM   #547
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by MINOCIN View Post
Has anyone tried a fire sleeve and tape kit. For example the one from DEI.
I wrapped my turbo lines and various other hoses and lines with this stuff. It works great. Not cheap though.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
CSG Mike (12-06-2014)
Old 12-06-2014, 08:19 AM   #548
mike the snake
Why would oil temps rise so high while idling or going slow in traffic?
Seems to me the engine's not making much heat/no load, I would think the oil temps would level off at some lower temp.
Do the temps rise that high on stock cars in traffic?
I too have my oil cooler mounted behind the passenger side fog light with holes cut out. It does make a significant difference at speeds over 40 mph while driving in a straight line, but I was still seeing temperatures climb past 255 F when stuck in LA traffic, driving hard in the canyons and at the race track with the Innovate SC kit (intercooled). So I fabricated a shroud around the oil cooler to route air thru it. The shroud definitely helped reduce temps at the race track and in the canyons, but it can't really do much if I'm stuck in traffic. I'll need to get a fan for that.
I would say that if you already have a cooler behind the fog light or if you're thinking of putting one there because it's your only option then make sure to have a shroud to redirect air to it.
Old 12-06-2014, 08:40 AM   #549
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
The car needs to be in motion to take advantage of the cool air rushing in through the grills and openings while in motion or at speed. When at idle the cars engine bay is like an oven baking a two liter because no cool air is coming through passing over the internals and assisting cooling mods with cooling
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-06-2014, 01:56 PM   #550
mike the snake
I just think with the car just idling in traffic that the oil temps would level off, and not be as high as 255. The radiator fans would be on, cooling the radiator (mine stays at 200 under load or not) and with no load, the oil wouldn't heat up so much.
Do stock, unmodified cars run oil temps as high as 255 in traffic?
Old 12-06-2014, 03:47 PM   #551
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
I have the aftermarket Koyo radiator for my FRS. Coolant temps for me hardly ever go over 192.2 F (if the fans are on keeping the coolant temps cool then I don't notice them), but the oil temps will definitely rise regardless. If I see the oil temps climbing past around 250 F then I'll turn on the heater, which will eventually get the oil temps to drop. I'm not stock though, I have the Innovate SC kit w/ intercooler and PPE headers.
I should have elaborated on the driving condition instead of just saying, "stuck in LA traffic." Here's the scenario:
I'm driving down to LA on the freeway cruising with the flow between 60 -75 mph, and then I quickly come up on a wall of traffic and I have to come to a complete stop or almost a complete stop. The car is stopped or slowly crawling for almost a minute before it picks up again, but the car hardly reaches speeds over 35 mph before having to stop or crawl again. This will continue for another 15-30 minutes depending on how bad traffic is. As already mentioned by others, not a lot of airflow passing thru the radiators to cool them down.
If the radiator fans are being switched on automatically then I don't notice them. I don't hear them spinning, I don't feel the engine surging at all and I don't see the rpms dip either- like when I normally have the heater on. Turning the heater on will help the oil temps drop down back to normal. Lucky for me I don't mind a little heat. As for my passengers, I just explain to them that it's necessary because I'm FI and they're cool with it.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 12-06-2014, 04:42 PM   #552
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The exhaust manifold is beneath the engine, so even idling this engine is going to heat the oil more than other cars that don't use boxer engines...
Sellout is offline   Reply With Quote
Old 12-06-2014, 04:46 PM   #553
CSG Mike
CSG Mike's Avatar
Originally Posted by Dipstik-sportech View Post
That's how all oil coolers without fans will preform regardless of where they're mounted. With it behind the fog light it just allows cooler fresh air to get to it quicker and in greater volume than if the light was still in place.
Sort of.
If the cooler is mounted in front of the radiator/AC condenser, then anytime the fans kick in to cool down the coolant or AC condenser, it also pulls air through the oil cooler.
We never, ever, see temps over 220 street driving with the JRSC + JROC. Regulation of ECT also results in regulation of EOT as a byproduct.
Old 12-06-2014, 06:43 PM   #554
Dipstik-sportech
Dipstik-sportech's Avatar
And in my eyes mounting it in front of the rad, condenser, and intercooler just doesn't seem wise.
Old 12-06-2014, 06:50 PM   #555
CSG Mike
CSG Mike's Avatar
That's why the JRSC has the oil cooler mounted behind the FMIC.
The FMIC is the system that will not cause any real damage if it gets hit by a rock or something. You'll have a boost leak, but the MAF will also read less air, so you just make less power until you replace/repair the FMIC. You won't lose an engine.
tumbla.jr (03-01-2015)
Old 12-06-2014, 07:26 PM   #556
mike the snake
I see some pretty crazy JDM stuff from Japan, up-turned muffler tips, huge wings on drift cars, and also externally mounted oil coolers with exposed cooler lines like in this pic.
https://www.google.com/search?q=jdm+...2F%3B631%3B420
I was thinking of mounting my cooler like this, but covering it with my license plate. This would keep it protected, and when needed for track use I'd just remove the license plate for the needed cooling.
All the other times (street) the plate would cover it and no one would know, except for the cooler lines, which might look kind of JDM cool, drifty style.
Old 12-06-2014, 07:31 PM   #557
sko222
Drives: 2013 scion fr-s
Doesn't hks have a cooler that is placed behind a fog light housing
sko222 is offline   Reply With Quote
Old 12-06-2014, 07:58 PM   #558
Dipstik-sportech
It's not the damage issue I worry about. It's stacking more radiators in the only opening in the bumper, hot air acrosz the intercooler, oil cooler and condenser = warm air across the rad. If I can take one out of the flow that's got to help.
Old 12-06-2014, 10:16 PM   #559
CSG Mike
CSG Mike's Avatar
I'm less worried about the air temp, and more worried about the amount of flow, but that hasn't proven to be an issue with the OEM radiator.
The ptuning guys that track use an even larger intercooler and oil cooler, and haven't had any issues either.
The first step is to add more powerful fans, but the vendors on this board love to push radiators instead (which, IMO, is not the first cooling mod that should be done).
Old 12-06-2014, 10:59 PM   #560
mike the snake
I agree, I think the shroud is more important than a bigger radiator.
My problem is not enough space to mount my oil cooler.
I'm going to explore cutting the opening in the front plastic splitter and mounting my oil cooler flat, or installing behind the passenger fog light.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
