#533 |
in orbe terrum non visi
Drives: violent
A little dangerous to do while driving but that's water coming OUT of the vents cut in my cowl.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | keen as (12-10-2014) |
#534 |
#535 | |
Drives: 2013 Black FR-S
Aren't you able to get your JRSC brz pretty hot on the track to the point where you have to back off? And you also run with heater vents blowing full hot? Not saying the 15 row is insufficient... but YOU are able to get the temps up there no?
#536 |
I'm wondering if one couldn't cut an opening in the stock front plastic splitter piece and install an oil cooler, laid flat instead of upright.
Seems to me that inside the grill area in front of the radiator/intercooler is all high pressure, so air would still be pushed through the cooler even though it's laid flat. I just got an oil cooler, and I want to either mount it behind my passenger side fog light, or maybe mount it flat onto the plastic splitter as I've suggested. I've seen some ducting for the fog light mounting as well but can't find pics. I do not want to mount my oil cooler in front of the intercooler. On my car there's no room since everything got moved forward. Any thoughts? Also, I'd love to see some pics of coolers mounted on BRZ's. |
#537 | |
Drift King
Drives: '13 Firestorm FR-S 6MT
Fullblowns oil cooler is positioned behind the foglight area and is proven to help significantly even without any cutouts/modifications to the foglight area, hope that helps your decision. Sent from my iPhone using Tapatalk
'13 6MT Firestorm FR-S
#538 |
I run mine with the fog light removed and it helped oil temps significantly.
#539 | |
Drift King
Depending on the numbers I get when I get my car back I might look into cutting out the "T" hole out of my bezel for more airflow Sent from my iPhone using Tapatalk
#540 |
Drives: RX-7 / BRZ
Pop the foglight bezel out and use a die grinder and just shave the backside where the space invader pattern is until just the grille pattern remains. Function and looks without it looking hacked up.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#541 |
Any pics of coolers installed on a BRZ?
#542 |
I'll take one tomorrow for u
#543 | |
The car actually runs cooler (coolant temp) with the stock radiator. Then again, coolant never got over about 205F at Thill, so my running the header is more a precaution rather than a necessity. I could get the coolant to 220F with stock fans and the custom radiator, but that's in 115F weather. In 110F weather, I can get the coolant to stabilize around 215, and in 100F, heat wasn't an issue. It's also partially dependent on the tune and fuel we run, as we experiment with different setups. |
#544 | |
Drives: Asphalt 2013 FR-S
I would say that if you already have a cooler behind the fog light or if you're thinking of putting one there because it's your only option then make sure to have a shroud to redirect air to it.
#545 | |
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | The Racers Line (12-06-2014) |
#546 | |
![]() I'm by no means a track rat, I just had to end this year a bit early because my tires started to cord. The JRSC kit may be better, especially at the track, but I still have fun with the Innovate kit. You are right though, I never really did see any other Innovate powered 86s around the socal tracks. Perhaps some are doing Auto-X like whataboutbob. He seems to be doing pretty well in that arena. Sorry for getting off topic, I just don't want any Innovate guys to be discouraged from going to the track. Umm... How can I get back on topic? Has anyone tried a fire sleeve and tape kit. For example the one from DEI. https://www.designengineering.com/ca...eeve-tape-kits According to the description the kit helps insulate and protect your lines. Not too long ago I had to refit my oil cooler lines and so I decided to give the sleeve a try. Since my oil cooler lines run close to the intake snorkel and right in front of the radiator I figured the less radiant heat the better. Unfortunately I can't say for sure how much the sleeves are helping though because at the same time I also made a shroud for my oil cooler, which I think helped the most. Now that the weather has cooled down though I hardly ever see my oil temps budge over 187 F.
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 04:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 11:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 10:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 07:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 02:18 AM |
