Old 12-04-2014, 02:35 AM   #519
CSG Mike
CSG Mike's Avatar
Originally Posted by sw20kosh View Post
@mkivsoopra and i tested this theory at the thunderhill racetrack in CA. Doesn't work. We even used pieces of string to visualize the flow of air on the track and the pieces of string were sucked into the engine bay which means air is not being evacuated. Our coolant and oil temps did not decrease. @CSG Mike has seen similar findings.
We have solved our FI heat problems by installing a huge oil cooler (25 row series 9 setrab). A 20 row may suffice btw but it is untested. NOTE: This has yet to be tested in 100+ degree weather. In 80+ degree weather we were seeing no more than ~215 F oil and coolant driving hard on track. Stock radiator.
I still vote 15 row and a phat fan
Old 12-04-2014, 10:05 AM   #520
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
My string flew out. What did you do to the cowl? I cut two 3 inch holes in the middle
Old 12-04-2014, 11:04 AM   #521
mkivsoopra
We pulled the weather stripping thing off.
mkivsoopra is offline   Reply With Quote
Old 12-04-2014, 02:08 PM   #522
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Out of curiosity, were you experiencing similar heat and air flow issues with the Innovate Intercooled kit u used to have?
AyJay is offline   Reply With Quote
Old 12-04-2014, 02:11 PM   #523
Reaper
Reaper's Avatar
Drives: violent
That doesn't work.
Old 12-04-2014, 02:20 PM   #524
mkivsoopra
That doesn't work.
Confirmed.
Not sure if I want to actually cut open the cowl piece though.
Old 12-04-2014, 02:39 PM   #525
sw20kosh
Drives: 2013 Black FR-S
In addition to weather stripping I took out the passenger side cowl pieces like I saw someone do on the forum.
Old 12-04-2014, 02:43 PM   #526
sw20kosh
I had a robispec radiator/oil cooler thing back when I had the SC. I think it was sufficient but I also wasn't driving as hard back then.
Old 12-04-2014, 04:58 PM   #527
AyJay
AyJay's Avatar
O ok. I been kicking around the idea of FI looking for a modest hp bump while trying to stay as trouble free at the track as possible. This thread hasn't been very inspiring for me to go away from an NA setup.
Old 12-04-2014, 05:08 PM   #528
sw20kosh
I would recommend the JRSC. A lot of track enthusiasts are currently running it consistently and I know a few more who are planning on ordering kits next year.
If I didn't go turbo I would hands down get the JRSC.
Old 12-04-2014, 05:20 PM   #529
Reaper
Reaper's Avatar
Drives: violent
Confirmed.
This worked.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
keen as (12-04-2014), mkivsoopra (12-04-2014)
Old 12-04-2014, 05:21 PM   #530
AyJay
AyJay's Avatar
JRSC is definitely on my short list of possibilities. This thread focused mostly on turbo kits and I was curious to hear from a person with 1st hand experience whether they faced the same issues with an SC kit.
Old 12-04-2014, 05:42 PM   #531
CSG Mike
CSG Mike's Avatar
As of now, the JRSC is the only supercharger kit I see at the track. All of the Innovate powered cars have either parted their kits or quit tracking altogether.
At CARB level power, you will have zero heat issues, even in 115F weather, with a stock radiator and fan.
rs999 (12-05-2014)
Old 12-04-2014, 05:50 PM   #532
AyJay
AyJay's Avatar
Are these JRSC cars using the JR specific oil cooler or some other solution?
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
