Old 12-05-2014, 02:11 PM   #533
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
A little dangerous to do while driving but that's water coming OUT of the vents cut in my cowl.
The Following User Says Thank You to Reaper For This Useful Post:
keen as (12-10-2014)
Old 12-05-2014, 03:28 PM   #534
CSG Mike
CSG Mike's Avatar
Originally Posted by AyJay View Post
Are these JRSC cars using the JR specific oil cooler or some other solution?
JR Specific; you'd need some really creative airflow design to fit something else unless you relocate the JRSC components.
Old 12-05-2014, 04:41 PM   #535
sw20kosh
Drives: 2013 Black FR-S
He could swap out the 15 row for a 20 row easily right?
Aren't you able to get your JRSC brz pretty hot on the track to the point where you have to back off? And you also run with heater vents blowing full hot? Not saying the 15 row is insufficient... but YOU are able to get the temps up there no?
Old 12-05-2014, 08:02 PM   #536
mike the snake
I'm wondering if one couldn't cut an opening in the stock front plastic splitter piece and install an oil cooler, laid flat instead of upright.
Seems to me that inside the grill area in front of the radiator/intercooler is all high pressure, so air would still be pushed through the cooler even though it's laid flat.
I just got an oil cooler, and I want to either mount it behind my passenger side fog light, or maybe mount it flat onto the plastic splitter as I've suggested.
I've seen some ducting for the fog light mounting as well but can't find pics.
I do not want to mount my oil cooler in front of the intercooler. On my car there's no room since everything got moved forward.
Any thoughts?
Also, I'd love to see some pics of coolers mounted on BRZ's.
Old 12-05-2014, 08:05 PM   #537
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Any thoughts?
Fullblowns oil cooler is positioned behind the foglight area and is proven to help significantly even without any cutouts/modifications to the foglight area, hope that helps your decision.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-05-2014, 08:07 PM   #538
Dipstik-sportech
Dipstik-sportech's Avatar
I run mine with the fog light removed and it helped oil temps significantly.
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
Brody602 (12-05-2014), D_Thissen (12-06-2014)
Old 12-05-2014, 08:10 PM   #539
Brody602
Drift King
Brody602's Avatar
Depending on the numbers I get when I get my car back I might look into cutting out the "T" hole out of my bezel for more airflow Name:  ImageUploadedByTapatalk1417828209.826561.jpg
Old 12-05-2014, 09:36 PM   #540
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Pop the foglight bezel out and use a die grinder and just shave the backside where the space invader pattern is until just the grille pattern remains. Function and looks without it looking hacked up.
Old 12-05-2014, 09:46 PM   #541
mike the snake
Any pics of coolers installed on a BRZ?
Old 12-05-2014, 11:12 PM   #542
Dipstik-sportech
I'll take one tomorrow for u
Old 12-05-2014, 11:50 PM   #543
CSG Mike
CSG Mike's Avatar
Oil temps, no, coolant temps, yes, but we're using a radiator that is designed for high pressure fans... but we don't have the fans on.
The car actually runs cooler (coolant temp) with the stock radiator.
Then again, coolant never got over about 205F at Thill, so my running the header is more a precaution rather than a necessity.
I could get the coolant to 220F with stock fans and the custom radiator, but that's in 115F weather. In 110F weather, I can get the coolant to stabilize around 215, and in 100F, heat wasn't an issue.
It's also partially dependent on the tune and fuel we run, as we experiment with different setups.
Old 12-06-2014, 02:35 AM   #544
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
I too have my oil cooler mounted behind the passenger side fog light with holes cut out. It does make a significant difference at speeds over 40 mph while driving in a straight line, but I was still seeing temperatures climb past 255 F when stuck in LA traffic, driving hard in the canyons and at the race track with the Innovate SC kit (intercooled). So I fabricated a shroud around the oil cooler to route air thru it. The shroud definitely helped reduce temps at the race track and in the canyons, but it can't really do much if I'm stuck in traffic. I'll need to get a fan for that.
I would say that if you already have a cooler behind the fog light or if you're thinking of putting one there because it's your only option then make sure to have a shroud to redirect air to it.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 12-06-2014, 02:51 AM   #545
Dipstik-sportech
That's how all oil coolers without fans will preform regardless of where they're mounted. With it behind the fog light it just allows cooler fresh air to get to it quicker and in greater volume than if the light was still in place.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
The Racers Line (12-06-2014)
Old 12-06-2014, 04:06 AM   #546
MINOCIN
MINOCIN's Avatar
As of now, the JRSC is the only supercharger kit I see at the track. All of the Innovate powered cars have either parted their kits or quit tracking altogether.
I'm Innovate powered and I haven't stopped tracking
I'm by no means a track rat, I just had to end this year a bit early because my tires started to cord. The JRSC kit may be better, especially at the track, but I still have fun with the Innovate kit. You are right though, I never really did see any other Innovate powered 86s around the socal tracks. Perhaps some are doing Auto-X like whataboutbob. He seems to be doing pretty well in that arena.
Sorry for getting off topic, I just don't want any Innovate guys to be discouraged from going to the track.
Umm... How can I get back on topic?
Has anyone tried a fire sleeve and tape kit. For example the one from DEI.
https://www.designengineering.com/ca...eeve-tape-kits
According to the description the kit helps insulate and protect your lines. Not too long ago I had to refit my oil cooler lines and so I decided to give the sleeve a try. Since my oil cooler lines run close to the intake snorkel and right in front of the radiator I figured the less radiant heat the better.
Unfortunately I can't say for sure how much the sleeves are helping though because at the same time I also made a shroud for my oil cooler, which I think helped the most. Now that the weather has cooled down though I hardly ever see my oil temps budge over 187 F.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
