Old 12-04-2014, 07:10 AM   #15
troek
troek's Avatar
Drives: 2012 Toyota 86
the blank screen/resume feature is great, and i love using it during the day for stops and what not, so much better than the old way. but its not too much work if the car is gona be sitting more than a day to just unplug it. it would be amazing if we could just plug it in and leave it forever. but we have to remember, most of us bought this just for tuning and some data logging. so these added features are an awesome bonus IMO.
troek is offline   Reply With Quote
Old 12-04-2014, 07:29 AM   #16
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
When it happened to me, my car wasn't sitting not being driven though.
I drove back and forth from work which is about 10 miles each way.
I think it was maybe the 4th day when my car wouldn't crank.
Old 12-04-2014, 07:36 AM   #17
troek
troek's Avatar
in just one night?
Old 12-04-2014, 08:03 AM   #18
Andrew025
Andrew025's Avatar
Originally Posted by troek View Post
in just one night?
Over the course of 3 days.
Back and forth from work each day with OFT plugged in the whole time.
Old 12-04-2014, 08:34 AM   #19
troek
troek's Avatar
ahh i see what your saying. yeah, best bet is like you already are doing, just unplug it over night. its a pretty mild tune, unless your tracking there's no need to monitor it every time you drive the car anyway. I only use mine if ive made changes, or if im gona be driving hard/tracking.
Old 12-04-2014, 08:42 AM   #20
Andrew025
Andrew025's Avatar
Yeah, it's not a big deal.
I had it mounted perfectly to leave plugged in though
Old 12-04-2014, 11:57 AM   #21
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
This is why I've been trying to source an OBD extension with a built on switch. There are a few online but they're not cheap...
1Cor10:23 is offline   Reply With Quote
Old 12-04-2014, 12:05 PM   #22
Foobar
SLO NO MO
Foobar's Avatar
Would probably be cheaper to just buy an extension and splice a switch in yourself. Battery power is on Pin 16, which is the lower right most pin if you're looking directly at your OBD2 port on the vehicle (narrow side down, wide side up).
Old 12-04-2014, 12:19 PM   #23
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by s2d4 View Post
To flatten the battery in 3 days, it'll need to draw ~1.27A constantly every single hour. Did you measure it with a multimeter?
Not enough to crank as per troek probably makes more sense, I wonder how much it actually draws? Perhaps it's something else like keeping the ECU awake.
This ^, I was wondering the same thing. It would make sense if the ecu normally goes into a standby mode when the car is off, but when I leave it on the datalog screen it always has up-to-date info from all the sensors, so maybe it is constantly sending/receiving when the oft is plugged in.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 12-04-2014, 12:33 PM   #24
1Cor10:23
1Cor10:23's Avatar
Yup, I've got a few extensions on the way, I'll experiment later now to find a good spot to house the switch...
Old 12-04-2014, 12:40 PM   #25
stugray
Drives: 2013 GBS BRZ Limited
Perhaps the fact that the OFT is talking to the ECU keeps the ECU awake?
That would make more sense than just the OFT draining the battery.
Old 12-04-2014, 12:48 PM   #26
Foobar
SLO NO MO
Foobar's Avatar
The light dimmer panel on the left side of the driver underdash panel is a good candidate. Can remove that whole panel from the underdash panel and work on it with unlimited access. Snap it back together and route the wires along the back of the panel, good to go.
The Following User Says Thank You to Foobar For This Useful Post:
1Cor10:23 (12-04-2014)
Old 12-04-2014, 01:09 PM   #27
s2d4
s2d4's Avatar
Yes, that is what I was referring to rather than OFT flattens batteries by its own power draw.
Old 12-04-2014, 01:14 PM   #28
stugray
If you go through the trouble of making a custom cable with a switch, just take Ignition power and route it to pin 16 of the OBD-II connector instead of Battery.
Then the OFT will only get power when the car is on.
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 10:56 AM
car wont start, winjet to blame?? 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 21 12-29-2013 03:34 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 08:57 PM
