Sam Strano
Old 12-03-2014, 10:45 AM   #1835
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Originally Posted by SeanRTR View Post
Are you that convinced the RX8 and one ringer Miata is that much faster than the twins?
I don't have an RX8 around here to test/compare, but anecdotal evidence from drivers that do the back to back testing is mounting. I think the car is properly classed, and I think it's obviously a trophy contender. I just wonder if it's really got the potential to win on a national level course against an RX8 all things being equal. I've got trophies and podiums and stuff - I want a damn jacket!
Regardless, I still have some things to try. I want to get the 245's off the car and go to 225's to get the transient performance up, and I need to make a straight pipe exhaust. I've considered getting a pair of DA front shocks made, but I'm pretty happy with the car's balance as-is at this point.
On another note, what would need to be done to use wheels with a 35mm offset to be legal for Street? 10mm spacer? Probably can't run that large of a spacer on the OEM studs though I assume?
You'd need to take the wheels to a machine shop and shave the mounting surface back, which is a very large amount and probably very unsafe. Spacers only add offset.
Autocross nut
AustinTX is offline   Reply With Quote
Old 12-03-2014, 10:47 AM   #1836
justint5387
Drives: 4 wheels
You can't make a +35mm offset wheel legal unless you get a machine shop to shave 6mm off the hub pad. The more spacer you add, the more negative the offset becomes.
justint5387 is offline   Reply With Quote
Old 12-03-2014, 11:33 AM   #1837
SeanRTR
C-Street AutoX
SeanRTR's Avatar
For Sale: OZ Racing Ultraleggera wheels qty 2 16 x 7 35mm offset Straight, but minor scuffs. Make offer:
http://www.tirerack.com/wheels/Wheel...int&tab=wheels
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 12-03-2014, 11:34 AM   #1838
qoncept
qoncept's Avatar
... and if you're going the other way, I put even my 5mm spacers aside until I had longer wheel studs. The stockers are SHORT.
qoncept is offline   Reply With Quote
Old 12-03-2014, 11:58 AM   #1839
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Annoyingly short...
DylanFRS is offline   Reply With Quote
Old 12-03-2014, 02:27 PM   #1840
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I can only use a 3mm when using certain lugs. Not all lugs taper enough to seat well with 3mm spacer!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-03-2014, 02:34 PM   #1841
renfield90
The Stig's German cousin
Nothing much to talk about in this thread these days?
Glad someone caught this. Thread totally jumped the shark there. It's nice not having a real off season.
The gearing hurts us against the RX8, but on a 60 MPH course or less, I don't really see it being an issue. A course that's heavy in slaloms and low on top speed should favor the twins over the RX8. Other than one random car in California, the only the Miata to show any signs of being competitive, let alone faster than the twins has big $$ Double adjustable Koni's, that no one has even tried on the twins yet. And this car is driven by Fenter, a former national champion in arguably the most competitive class at nationals (SSR). I'm not even sure he'll be driving that car next season, and I've beaten the car owner (Harvey) 2/3 times when facing him. There's still more shit to be tried and tested before saying the twins can't even podium at nationals I feel. The 370Z is gone, our PAX number is fixed. We should all be pretty damn excited.
Big +1. My setup turns the knob to 11 on transitions/slaloms but I suffer a bit in sweepers. I'm still on OEM shocks, I think if I had some pimp DAs I could probably fix that. Add the right tires, staying off the cones, not getting sick at nats, who knows where I end up? Simply getting a trophy is not going to be my goal.
I thought some people ran the MCS shocks this year?
Old 12-03-2014, 02:49 PM   #1842
renfield90
Get the nameless track exhaust. Not as cheap as DIY but it's an easy button.
Old 12-03-2014, 03:41 PM   #1843
AustinTX
AustinTX's Avatar
I've got the Perrin resonated catback, so I need to get a v-band straight pipe made to replace the muffler section.
Autocross nut
Old 12-03-2014, 04:27 PM   #1844
redlined600
redlined600's Avatar
Drives: Fr-s
Quick question on the camber bolts I didn't see in here. Does the fsm specify a part number or can any camber bolt(including eccentric) be used?
redlined600 is online now   Reply With Quote
Old 12-03-2014, 06:06 PM   #1845
SeanRTR
C-Street AutoX
SeanRTR's Avatar
At nationals? Not sure. The Potocki FR-S from Wilmington and East couse Pro's Tour's runs MCS shocks. 370Z's kept them from making the trip to Lincoln. Our times have been very similar at most events we've both attended.
Last year at nationals Trevor Jones was on MCS, and I think he was the fastest twin until the final run, when he pas passed by Laughlin running Koni yellows. I'd love to see a test of both cars on similar tires/bars back to back.
Old 12-03-2014, 07:15 PM   #1846
renfield90
I'd be more curious to see shock dyno plots.
I mean, at that point it's going to come down to driving style and where to turn the knob, unless one set has additional adjustment range the other doesn't and this part of the range proves faster. Without the data in hand you can really only draw conclusions between those two individual sets of shocks, just my opinion. Konis in particular I've heard can have significant variation.
If I get shocks next year I will post dynos (I've searched and haven't found any). We'll see what the budget allows.
Old 12-04-2014, 08:10 AM   #1847
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
To stay in C-Street and be in the rules, you must run the Toyota/Subaru factory approved parts. This means no eccentrics.
bimmer635csi is offline   Reply With Quote
Old 12-04-2014, 11:06 AM   #1848
qoncept
qoncept's Avatar
Way to ruin this guy's day:
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
