Old 12-01-2014, 08:04 PM   #2409
xDanger_208x
xDanger_208x's Avatar
Drives:
Originally Posted by KraftWerks View Post
Oh BOY! We're gettin' orders out as fast as we can. Thanks for the order! I'll be shooting you a PM shortly as well.
The C38 kits should see close to 300whp on 91 Octane. Unless the tuner was being completely safe, the car should see near that 300 platform. Even at 3000'
YES!!!!!
xDanger_208x is offline   Reply With Quote
Old 12-01-2014, 08:12 PM   #2410
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Im am SO waiting for the c38 to be CARB approved. Hopefully kraftwerks will be doing so after the c30 gets approved..
Sent from my SCH-I545 using Tapatalk
Avo1789 is offline   Reply With Quote
Old 12-01-2014, 08:36 PM   #2411
gmsii
gmsii's Avatar
enjoy the spin....
“Yes, there are multiple C38 JRSC cars running around, and also multiple high boost cars. Every single one of these cars are heavily tracked cars.
It is only available by calling CSG or Jackson Racing directly. It is
not publicly available through every JR dealer because it is a highly
application specific product.
You *CANNOT* properly utilize a C38 unless you have a built engine. You need to be pushing more CFM and boost with a C38 than a C30 can at peak, to actually be getting any more flow or power with the C38. Anyone running a C38 at 12 psi or lower, quite frankly, is using the wrong supercharger.
The problem is, if you're running 12+ psi, you need to be running either race gas or E85. Most people will opt for E85. This means output will be north of 325 torque and 400 horsepower.
325 torque is where the stock transmission's failure point is, and you already need to have a clutch to even get to that torque level. Guess what fails? The trans. At this point, the cheapest aftermarket
transmission option is 18k.
The C38 JRSC has been around since day 1. It is not released because it is not the right product for 99% of the general public. JR is not in the business of selling the wrong product to people, and nor is CSG.
The price for the C38 and C30 are the same from Rotrex.
Next, the high boost pulley. This is also available, and has been from day 1. The reason the 110mm pulley was chosen for the stock kit, is that a LOT of tuners like to tune for higher redlines. For some reason, the general public thinks this is safe (it's not), so the pulley
was sized to max out the blower near 8000 RPM, so that the supercharger is less likely to be overspun by a third party tuner. The 100mm pulley takes the supercharger to max at about 7350 RPM. The 110mm pulley also happens to high the limitation of CA 91 right as you hit the stock redline.
Obviously, the other parts are not part of the CARB kit, and if you do
get a ref ticket, you'll need to have the stock pulley on (they measure
it), but you will pass with a CARB tune and cats on.
A pulley swap is a 10 minute job, at most.”
translation= they couldnt get it right, so now they have to say its unreliable, unusable, not optimal, tuners want less power and more revs, it'll blow up your transmission, it'll blow up your motor...smh
plenty of KW c38 owners would say otherwise
gmsii is offline   Reply With Quote
The Following User Says Thank You to gmsii For This Useful Post:
Freeman (12-02-2014)
Old 12-01-2014, 08:54 PM   #2412
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
post_break is offline   Reply With Quote
The Following 2 Users Say Thank You to post_break For This Useful Post:
lucid215 (12-03-2014), xDanger_208x (12-01-2014)
Old 12-01-2014, 08:55 PM   #2413
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Hahah
Sent from my Nexus 5 using NASIOC mobile app
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 12-01-2014, 09:16 PM   #2414
FirestormFRS
Awww hate to see vendors ragging each other in these threads. The threads end up going away. You guys cut it out!!!!
FirestormFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to FirestormFRS For This Useful Post:
Calum (12-01-2014), mitosis (12-04-2014), projek_01 (12-05-2014)
Old 12-02-2014, 12:58 AM   #2415
xDanger_208x
Drives:
I'm not going to use the washer bottle.
Would there be any problem with mounting the oil reservoir in that general location??
I realize it won't be as easy to fill when the maintenance interval comes around, but I can deal with the slight inconvenience.
I want the cleanest, uncluttered look possible.
Old 12-02-2014, 01:01 AM   #2416
xDanger_208x
Drives:
@KraftWerks
Told you I'm getting anxious Hahahaha
Old 12-02-2014, 02:11 AM   #2417
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by SPCorBUST View Post
Anybody looking to up their C30 to a C38? I'll trade you mine for yours + some moola.
I need the C30 for CARB, in case you can't tell. No rush to trade, either. Obviously I've already waited 5 months...
Interested!
Freeman is offline   Reply With Quote
Old 12-02-2014, 11:38 AM   #2418
Airboy
Drives: 06WRX 15WRX
From this thread:
Dyno Dynamics, 11/11.5psi, 259/266whp
http://www.ft86club.com/forums/showp...&postcount=179
Mustang, 10psi, 246whp
http://www.ft86club.com/forums/showp...&postcount=661
Originally Posted by BRZZZZZZZZZZ View Post
258WHP on 10psi.
That's a little light, even with 3000' and 94 Octane.
Who did the tuning?
Airboy is offline   Reply With Quote
The Following User Says Thank You to Airboy For This Useful Post:
zoth (12-02-2014)
Old 12-02-2014, 07:13 PM   #2419
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by Airboy View Post
From this thread:
I have to agree, from everything I have read that my car made right around what I expected. I am sure the tune is safe and I want my engine to last.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 12-02-2014, 07:30 PM   #2420
Scracho
Drives: 2018 Subaru BRZ
Originally Posted by xDanger_208x View Post
@KraftWerks any idea when all of the black Friday orders will start shipping? I'm getting anxious ;-)
Mine should be here tomorrow according to UPS tracking! Muhuhuahahaha
I don't think I can sleep tonight lol
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
xDanger_208x (12-02-2014)
Old 12-02-2014, 07:30 PM   #2421
xDanger_208x
Drives:
Mine hasn't shipped yet as far as I know
Old 12-02-2014, 07:35 PM   #2422
Scracho
Originally Posted by post_break View Post
LMAO!
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
