Old 11-26-2014, 04:02 AM   #2381
SPCorBUST
SPCorBUST's Avatar
Originally Posted by gmsii View Post
Bro...nobody's lying...the car has been in the lab off and on for preliminary testing for a while...the preliminary tests are differnt than the actual test where the car is hooked up directly to carb....if you have questions or want more detail about this process , feel free to email me directly...this is Jeff btw
The e-mail chain references a revision happening in August. Thats quite a while back. You're saying that every visit prior was a preliminary test, and that on the actual test you had to have a revision, which must have happened semi-recently because it is only going back to the lab next week.
What happened to last month when it was already approved?
It sounds like 30 days forward and 5 steps back.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 11-26-2014, 04:21 AM   #2382
SPCorBUST
SPCorBUST's Avatar
Anybody looking to up their C30 to a C38? I'll trade you mine for yours + some moola.
I need the C30 for CARB, in case you can't tell. No rush to trade, either. Obviously I've already waited 5 months...
Old 11-26-2014, 10:17 AM   #2383
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by Jasbel View Post
Hi All
I'm interested in the Kraftwerks Supercharger and the AVO Stage 3 Turbo Kit
But I can't decide as they are both good kits.
I'm sure there a lot of other people who had the same problem deciding which
Way to go?
My question is what made Kraftwerk owners choose there kit over the AVO kit
besides the price.
Any advice would be much appreciated
Cheers Darren
I already have a turbo car, and my only experience was with my S/C Miata and I loved the S/C feel of it, so I went with the S/C again.
They are totally new to me. I've run N/A, Turbo, Twin Turbo, Centrifugal type S/C and Roots type S/C vehicles now.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 11-26-2014, 10:55 AM   #2384
Lonewolf
Lonewolf's Avatar
Drives: Moped
Hi All
Way to go?
besides the price.
Cheers Darren
It seems that AVO's customer service leaves much to be desired based on several threads on here. Just some food for thought...
Old 11-26-2014, 11:34 AM   #2385
MidnightRunner
MidnightRunner's Avatar
And exhaust leaks are still an issue as well..
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 11-26-2014, 01:06 PM   #2386
xDanger_208x
xDanger_208x's Avatar
Drives:
What brand do you all recommend for fuel pump/injectors???
xDanger_208x is offline   Reply With Quote
Old 11-26-2014, 01:11 PM   #2387
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'm using fuel injector clinic. Not sure about others but they are flow rate matched.
post_break is offline   Reply With Quote
Old 11-26-2014, 01:26 PM   #2388
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Grams Performance, a Sister Company, has PnP Injector Kits and a 265lph Fuel Pump for the platform.
Shoot me a PM and we can talk about these as well to keep the posts within this thread about KW.
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
xDanger_208x (11-26-2014)
Old 11-26-2014, 08:27 PM   #2389
Scracho
Drives: 2018 Subaru BRZ
Hi All
Way to go?
besides the price.
Cheers Darren
Agree with @Rulin
I also had several WRX's and other Turbo vehicles, some of them were factory equipped and others bolt on kits.
My experience with turbo vehicles are great for all out power but once modified I found the vehicle would suffer from the Jekyll and Hyde syndrome with both drivability and reliability. The bolt turbo kit cars I had always required a fair amount of "tweaking" which resulted in more "tweaking time" than actual track/daily/enjoyment time.
With the high static compression of the FA20 and most turbo kits having a front mounted turbo (a few exceptions) heat soak from much higher under hood temps have me concerned for overall reliability long term especially when I consider doing a lot of consecutive hard laps in the car, not to mention the way a turbo delivers the power is FAR less linear than that of a S/C setup. I know this can be argued to death, but this is my opinion based on previous experience.
I considered every S/C kit available and overall the KraftWerks kit I feel is the best engineered, clean looking, upgradable, and ease of installation is what had me sold. Rotrex units have proven to be reliable with great power delivery and a much higher ceiling for power limits than other kits available...
Owning many performance enhanced cars and researching what is available for the 86 platform, the KW kit is in my opinion the best combination of value, performance and engineered with reliability in mind.
Just my $.02
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following 3 Users Say Thank You to Scracho For This Useful Post:
Chad86 (12-20-2014), themajesticone (01-20-2015), xDanger_208x (11-26-2014)
Old 11-26-2014, 08:29 PM   #2390
xDanger_208x
Drives:
Originally Posted by Scracho View Post
Agree with @Rulin
With the high static compression of the FA20 and most turbo kits having a front mounted turbo (a few exceptions) heat soak from much high under hood temps have me concerned for overall reliability long term especially when I consider doing a lot of consecutive hard laps in the car, not to mention the way a turbo delivers the power is FAR less linear than that of a S/C setup. I know this can be argued to death, but this is my opinion based on previous experience.
Just my $.02
This is exactly why I'm choosing KW
The Following User Says Thank You to xDanger_208x For This Useful Post:
Scracho (11-26-2014)
Old 11-27-2014, 01:29 PM   #2391
BRZZZZZZZZZZ
Car Nut
JDL UEL
JDL Overpipe
JDL Catted front pipe
Greddy SP Ellite Axle Back
Kraftwerks C38
Video Credit Sunny (Sonny?) Airboy Tuning
[ame="https://www.youtube.com/watch?v=UXL3EpeuiGI"]BRZ Kraftwerks SC - YouTube[/ame]
The Following 4 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
D_Thissen (11-29-2014), Hyper4mance2k (06-09-2015), mit_peid (11-27-2014), themajesticone (01-20-2015)
Old 11-27-2014, 01:34 PM   #2392
xDanger_208x
Drives:
Originally Posted by BRZZZZZZZZZZ View Post
JDL UEL
JDL Overpipe
Kraftwerks C38
Rad! Mine should sound very similar.
What were your numbers?? And on what fuel??
Old 11-27-2014, 01:34 PM   #2393
Scracho
Beat me to it lol
Old 11-27-2014, 01:37 PM   #2394
BRZZZZZZZZZZ
Car Nut
Nobody has said numbers yet, but just regular 94 octane is all I can get up here.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
