#1303 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Thank You bro! Did you end up using the larger gasket that came with the turbo or the smaller one that probably came with the exhaust (I used the larger gasket)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#1304 |
uosɹǝdʎɐl ʇɹǝdxǝ
#1305 |
Senior Addict
Drives: 86 GT
#1306 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
I actually used stacked vibrant gaskets. They worked like a charm. The standard gasket wasn't thick enough so the overpipe flanges were pulling at each other
Top Tier Imports - Check out my build journal HERE
#1307 |
uosɹǝdʎɐl ʇɹǝdxǝ
Tell me more about this amazing product (including where to get some)
#1308 | |
![]() http://vibrantperformance.com/catalo...1022_1068_1126 I find the AVO gaskets are very thin with a pretty weak looking blast ring. The Vibrant ones have a lot more "meat" to them.
#1309 |
Senior Addict
Drives: 86 GT
Need to order some Nord Lock washers. Can anyone tell me if the manifold-to-engine flange bolt/stud is an M8 or M10?
#1310 |
uosɹǝdʎɐl ʇɹǝdxǝ
I would like to know this as well.
#1311 | |
uosɹǝdʎɐl ʇɹǝdxǝ
#1312 |
I used two at each overpipe flange. I found that the overpipe was the one taking the stress since it's mounted to a header stud now. I also used double nuts on those flanges
#1313 | |
uosɹǝdʎɐl ʇɹǝdxǝ
Also keep in mind these fumes are not also stinky, they're dangerous because they are non-catalyzed so there's a *LOT* more carbon-monoxide. It's a serious health and safety issue and one I need to fix.
#1314 | |
Senior Addict
Drives: 86 GT
There's also vents behind the rear bumper. Perhaps the smell could have come through there? But anyway I ge what you're saying and you should sort this out ASAP. Have u tried the soapy water trick? |
#1315 |
Senior Addict
Drives: 86 GT
What size is the brake booster hose ID (for the bov tee piece)?
#1316 |
Drives: 86 GTS White
Anyone have any issues with the pulley hitting the charge pipe on medium-hard braking?
Mine makes quite a bad noise. Any solutions? |
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 05:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
