Old 11-24-2014, 07:27 PM   #1303
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by protpibe View Post
Actually, I did. As long as that flange isn't sealed 100%, you'll smell it.
Thank You bro! Did you end up using the larger gasket that came with the turbo or the smaller one that probably came with the exhaust (I used the larger gasket)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 11-24-2014, 07:30 PM   #1304
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Originally Posted by Fizz View Post
Do you still have a catted front pipe?
Nope, i'm cat free...
Old 11-24-2014, 08:12 PM   #1305
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
LoL....you sure the smell you're getting is not because of the catless system? That pungent smell tends to stick to fabric (clothes, interior) for a little while, hence could be the reason why you're still smelling it whilst driving.
Fizz is offline   Reply With Quote
Old 11-24-2014, 10:04 PM   #1306
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I actually used stacked vibrant gaskets. They worked like a charm. The standard gasket wasn't thick enough so the overpipe flanges were pulling at each other
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 11-25-2014, 03:30 PM   #1307
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Tell me more about this amazing product (including where to get some)
Old 11-25-2014, 05:58 PM   #1308
protpibe
protpibe's Avatar
Take your pick
http://vibrantperformance.com/catalo...1022_1068_1126
I find the AVO gaskets are very thin with a pretty weak looking blast ring. The Vibrant ones have a lot more "meat" to them.
Old 11-25-2014, 08:49 PM   #1309
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Need to order some Nord Lock washers. Can anyone tell me if the manifold-to-engine flange bolt/stud is an M8 or M10?
Old 11-26-2014, 10:15 AM   #1310
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
I would like to know this as well.
Old 11-26-2014, 10:16 AM   #1311
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Take your pick
how many did you stack?
Old 11-26-2014, 10:47 AM   #1312
protpibe
protpibe's Avatar
I used two at each overpipe flange. I found that the overpipe was the one taking the stress since it's mounted to a header stud now.
I also used double nuts on those flanges
Old 11-26-2014, 12:56 PM   #1313
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
The smell itself is caused by the cat-less system. The problem is the odor coming into the cabin vents. The exhaust outlet itself is well away from the cabin air inlet so when you're smelling gases it's because they are collecting under the hood and that means a leak somewhere near engine compartment itself.
Also keep in mind these fumes are not also stinky, they're dangerous because they are non-catalyzed so there's a *LOT* more carbon-monoxide. It's a serious health and safety issue and one I need to fix.
Old 11-26-2014, 06:11 PM   #1314
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
There's also vents behind the rear bumper. Perhaps the smell could have come through there? But anyway I ge what you're saying and you should sort this out ASAP. Have u tried the soapy water trick?
Old 11-27-2014, 03:20 AM   #1315
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What size is the brake booster hose ID (for the bov tee piece)?
Old 11-27-2014, 06:10 PM   #1316
Skorov
Skorov's Avatar
Drives: 86 GTS White
Anyone have any issues with the pulley hitting the charge pipe on medium-hard braking?
Mine makes quite a bad noise. Any solutions?
Skorov is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
