go_a_way1
Old 11-24-2014, 08:42 PM   #7995
predator800
Drives: 2015 Scion FRS
Originally Posted by Robftss View Post
Attachment 96592
Attachment 96593
Here are the bits needed for a larger starter.
Battery: (used in the MX-5)
http://www.atbatt.com/interstate-meg...ry-370-cca.asp
Tray:
http://www.northernautoparts.com/part/de-00252
Post clamp: see pics...available everywhere in multiple versions.
Remove (unscrew) one of the hold down block wings, cover sheet needs to be cut/trimmed for Neg post terminal.
This set-up was tested for a couple months last winter.
Rob.
I call this the Canadian Prairie edition battery pack.
predator800 is offline   Reply With Quote
The Following User Says Thank You to predator800 For This Useful Post:
fenton (11-25-2014)
Old 11-25-2014, 09:24 PM   #7996
Gums
Drives: SWP BRZ
Originally Posted by Target70 View Post
just out of curiosity, how would you compare performance between the powersonics and the Odysseys? data logging boost?
Also, I could see using it for the starter battery, but for the dump packs this kind of concerns me: "capable of 100 percentage recharge in 4 - 6 hours" From my usage of the powersonic dumps, it reaches full charge in 4 to 6 seconds. I realize I am not comparing from fully depleted, but I am no expert at batteries. I am still trying to figure out how to compare Amp hours to Cold cranking amps. Based on Amazon, the price is slightly under double. ~$140 shipped. So to replace would cost $420. Which would be a comparable price if the 1.5 kit was still optional. Plus, the dump harness would have to be modified/replaced.
Don't have any odyssey batteries at the moment. Hopefully, one day Rob may test them. He told me he has tested some heavier duty Powersonic with little difference in results. Supposedly the Odyssey's are different.
Recovery rate (recharge?) is better with the odyssey, according to my battery guy. (I'm definitely no expert in lots of things, one of which is batteries)
In no way am I suggesting replacing the 0.5dump pack, it was just a comment by the battery guy re the short discharge amps available from the Odyssey.
As the open source guys appear to be finding, ESC's involve a bit of voodoo, so I'll be leaving the improvements to Rob.
Gums is offline   Reply With Quote
Old 11-25-2014, 09:32 PM   #7997
Gums
Drives: SWP BRZ
Originally Posted by Gary in NJ View Post
The Power Sonic battery is a 21Ah battery where the Odyssey battery is a 16Ah battery.
It's possible that the Odyssey is a better start battery...but we wont know until someone (in a cold climate) tests it.
Apparently the Odyssey is capable of delivering much higher amps for short periods (such as starting) Though I agree the No's would suggest otherwise.
Old 11-25-2014, 11:06 PM   #7998
jwvand02
Drives: 2013 SWP BRZ Limited
I have an odyssey in my living room. Going to hook it up by the end of the week, when it gets less than 30 degrees out I'll report back. My battery seems to do great down to 30 or so then it falls off rapidly.
2013 SWP BRZ Limted
Innovate Stage 2
E85, Tuned by Moto-East
jwvand02 is offline   Reply With Quote
Old 11-26-2014, 06:14 PM   #7999
GTO5005
Drives: White Scion FR-S
Has anyone on e85 got the winterblend mix, does shivs ESC E85 tune adjust pretty well after a while, or do you think i should just switch to 91?
Phantom ESC 1.5 Dump Conversion, Borla Headers, TRD Exhaust, OFT E85 Tune
GTO5005 is offline   Reply With Quote
Old 11-28-2014, 02:11 PM   #8000
BadHabit
Drives: 2013 FRS
Originally Posted by BadHabit View Post
Thank you for the feedback. Just recieved the ECS kit from @shif7i7down! Going to pick one of these tuning options soon so I can get on the install.
Thanks @Target70
I went with OFT and glad I did. Stage 1 93oct tune right now and can tell the difference. Tone of the engine changed from VVT adjustments. Also like the soft rev limiter and launch control/2 step feature.
ESC and OFT UEL Header next on the list.
I am missing the black cap to block off the intake air silencer. Anyone know where I could source that part?
2013 FRS Phantom ESC, OFT, K&N "SOLD"
2002 Z06 Tune, Bolt Ons
1995 Z28 STS Turbo, Meth, N2O, 700rwhp 740rwtq "SOLD"
2000 Audi B5 1.8T "SOLD"
BadHabit is offline   Reply With Quote
Old 11-28-2014, 02:13 PM   #8001
jwvand02
Thanks @Target70
EST and OFT UEL Header next on the list.
1.5 inch rubber pipe cap from lowes, in the plumbing section.
2013 SWP BRZ Limted
Innovate Stage 2
The Following User Says Thank You to jwvand02 For This Useful Post:
Sojhinn (11-28-2014)
Old 11-28-2014, 02:57 PM   #8002
DAEMANO
Time Traveller
Pump 2 gals premiumr pump gas to 9 gals of e85 and you'll start pretty smooth every time.
Old 11-29-2014, 02:19 PM   #8003
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by fenton View Post
Hello Phantom faithfuls:
Been getting alot of questions about the wait list....below is the list of people that Rob has noted are interested in purchasing the Phantom SC TQ250. If you are not mentioned below, you have been missed. Please PM Robftss with any correspondents so he can ascertain your priority on the list.
Please note that the list is not in order so the only important thing is that you are on the list.
@Robftss has 5 kits that are ready to go, people will be getting PM's for those this week. If a response is not received he will move down the list.
Thanks all!
@GTO5005
@s2d4
@LazyZed
@keen as
@SuperKazRacing
@Target70
@reneezak90
@gtfapollo
@werunbklynn
@JuicyFruits
@FingR-S
@godzuki
@MelloFlow
@Emac
@PantsDants
@Jonsey
@natemathFT
@l0aded
@Thobjo
@MagicBobert
@SimplePortal
@jwSubMOA
@ChiStig
@yamsta
@Larkin
@Terrapin77
@Pistol
@statlab
@Account Attempt No. 4
@taiquach
@RRIII
@reignerabellera
@KGB
@jwvand02
@far east autopart
@Infidel86
@GotBRZ1691
@kchar
@Technotweak
@GhostOp86
@murselyfe
@BadHabit
@SOAZ
@killy
@j_Zer0
@Namuna
@alex345
@Bigbadvoodooguru
@MmmHamSandwich
@og25491
@Necric
@JoonPrime
@KoolBRZ
So are people being removed from the list when they get their ESC, or decide they don't want one? Are there really 50+ people waiting for 5 ESC's per batch? Will there be another batch ready before Christmas? Any idea how long I'll have to wait?
KoolBRZ is offline   Reply With Quote
Old 11-29-2014, 07:14 PM   #8004
Namuna
Namuna's Avatar
I learned about the Noco GB30 JumpStarter here, so I figure I'll share a great deal I just got on it: $94.12 shipped (Regular street price is $129.99).
Noco GB30 JumpStarter: $99.99
Coupon Code- MK39743: 15% Off $100
Add something cheap to get over the $100 mark (I bought some scouring pads for $1.99) and since I'm in NJ I had to pay sales tax.
Final Price for me: $94.12 shipped
Namuna is offline   Reply With Quote
The Following 2 Users Say Thank You to Namuna For This Useful Post:
DAEMANO (11-30-2014), TM (12-01-2014)
Old 11-29-2014, 11:25 PM   #8005
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Not that it matters here in San Diego but I snagged an odyssey battery for shits and giggles. I'll let you guys know how it fits and works.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (11-30-2014), Gums (11-30-2014)
Old 11-30-2014, 09:19 PM   #8006
GerryL
Drives: White BRZ
I have one of these in my BRZ's spare tire compartment just in case. Fits easily, and I tried it for grins and definately gets the starter spinnng quicker. Mine has always started ok with the ESC battery system, but I just wanted a little extra insurance, and it functions as an emergency phone charger to boot.
GerryL is offline   Reply With Quote
The Following User Says Thank You to GerryL For This Useful Post:
Old 12-01-2014, 03:05 PM   #8007
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
I ran 2 odysseys as dump packs with the additions of 2 half dumps, We saw no gains, only difference was they didn't need to be warmed up, I could hit full boost off the bat however the dump packs would need to drain a few times before they proved useful.
@robwbright Sorry Ive been loosely following this thread as of late. Are you still having battery issues? did you determine if it was the start battery that has gone bad? do you have the stock battery still? maybe install back in the car and drive around for a week without the ESC, this could help you determine if have a drainage issue, just an idea.
P.S. Im back to the original starter battery, the same one majority of us are using, it was -20C - -25C in calgary this week and the car wasn't started for 4 days and still started pretty decently.
Cheers
Bu-Tang is offline   Reply With Quote
The Following 4 Users Say Thank You to Bu-Tang For This Useful Post:
DAEMANO (12-01-2014), Gums (12-01-2014), robwbright (01-06-2015), Target70 (12-01-2014)
Old 12-01-2014, 03:52 PM   #8008
TM
TM's Avatar
Drives: DGM BRZ 6MT
I left my car off for 5 days during my thanksgiving break. When I came back this morning, the car started nice and strong with no hesitations. I don't think it's a drain; my problem was mostly likely weather-related.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
