Old 11-17-2014, 12:28 PM   #2577
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Kayshart View Post
Hi,
I'm looking to change to Advan RGIII 18x8 +37, with 225/40R18.
I would like to know the pros and cons between choosing 8in wide or 8.5in. The 8.5in offset comes in +31 or +47 only.
Please advise.
Thanks!
The 18x8 +37 will fit without issue anywhere.
Pros and Cons?
It's not a huge difference, so doubt anyone will notice but you.
Pretty much the same tire size, and you should be able to run up to 245/35R18 on both. The 225-wide is better suited for a 7.5+8" wide wheel while the 245 is better on the 8.5" but there is a bit of play there (like folks with 225's on 9's, lol).
I would suggest you choose the wheel width that gives you the best offset of the 2. For me, I would go with the 8" +37 as opposed to the 8.5+31 (+47 will fit but lots of tuck).
The other thing to consider is suspension upgrade, not sure if you are lowered or not. Also, tire choice is a factor, easier to run the bigger tire with the 8.5+31.
Slick is offline   Reply With Quote
Old 11-17-2014, 12:32 PM   #2578
Slick
Slick's Avatar
Originally Posted by Patty hoo hoo View Post
I need to know if this will fit and if anyone is running this set up and if so pics please!
18x9.5 40+ with a 215 or 225 size tire.
I always have a st coilovers and I plan on maxing them out. I want to be stanced. I do have LCA and plan on getting adjustable tow's for the rear so camber is what I'm going for but I don't want to do anything crazy!
If anyone is running this/will it fit please let me know!
Best to post here as these guys are of the same mindset as you (stance crowd).
http://www.ft86club.com/forums/showt...25171&page=123
As you can see from this thread (if you choose to read the whole thing or just a few pages), pretty crazy wheels and offsets can be made to fit if you want it to.
The wheels will fit, but stanced is all about camber. Read on...
Old 11-17-2014, 05:40 PM   #2579
Patty hoo hoo
Drives: Scion frs
Thank you I'll check it out
Patty hoo hoo is offline   Reply With Quote
Old 11-21-2014, 11:54 AM   #2580
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Is it possible to have enough camber for a 17x8 +32 not to poke up front without it looking ridiculous?
Nevermore is offline   Reply With Quote
Old 11-23-2014, 09:29 AM   #2581
hotsaucepanda
Drives: Subaru BRZ
will this guys fit? I'm looking at this 3SDM 0.06 18" 5x100 et35 245. I want to run the same size on all four. will this be possible if I go 2" down? My only fear is for the tires to touch. Im installing st suspension coilovers xta as well.
thanks for all the help guys
hotsaucepanda is offline   Reply With Quote
Old 11-24-2014, 10:44 AM   #2582
Kayshart
Hi,
Quick question, do I need extended lugs with 10mm spacers?
With stock wheels and a +47 Advan rim.
Thanks!
Kayshart is offline   Reply With Quote
Old 11-25-2014, 01:16 PM   #2583
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
Plan on running 18 x 10 +36 Square. Ideally I would like to run 275/35/18 square but i doubt i could fit that in the front. What do you guys suggest? I'm on coilovers.
VroomVroom86 is offline   Reply With Quote
Old 11-26-2014, 03:02 AM   #2584
MadeInSweden
Drives: Nissan GT-R
I will run H&R coilovers and want a square wheel setup on my EU 2014 GT86.
Plan is to run 9.5x18 with either 245/40-18(MPSS) or 255/35-18(PZero) but the question is if I should go for ET35 or ET40? What issues could I be facing?
Nurburgring 07:42 BTG
MadeInSweden is offline   Reply With Quote
Old 11-27-2014, 03:00 PM   #2585
Slick
Slick's Avatar
That shouldn't poke out much at all even without camber.
These are RPF1 17x8 +35. So you're only 3mm further out.
http://www.ft86club.com/forums/showthread.php?t=37136
And with a mild drop, the natural camber will bring them in a bit.
Old 11-27-2014, 03:05 PM   #2586
Slick
Slick's Avatar
Hi,
Thanks!
The answer is yes to extended studs, but you could go with an extended lugnut like this also:
Not sure what you mean by stock wheels and Advan +47 wheels though.
I would consider a wheel with a better offset instead of dealing with studs or extended lugnuts.
Old 11-27-2014, 03:09 PM   #2587
Slick
Slick's Avatar
What width are these wheels?
Even with an 18x9 +35, you can fit a 245 on all corners easily. I am running that spec wheel with 255/35R18 currently with no rubbing and -2.2F/-2.0R camber on a 1" drop.
With a 2" drop, you should be okay with 245/35R18 with the proper camber settings.
Old 11-27-2014, 03:12 PM   #2588
Slick
Slick's Avatar
You can run a 275 up front with coilovers, the issue is not with the tires but with the wheel size and your offset. Looks like alot of poke unless you camber the crap out of it.
See the aggressive wheels thread here for more info:
http://www.ft86club.com/forums/showthread.php?t=25171
Old 11-27-2014, 03:15 PM   #2589
Slick
Slick's Avatar
Between those 2 offsets I would choose the +40 since you have coilovers installed and this will tuck the wheels in a bit more.
With the +35, you will need more camber dialed-in to eliminate the poke or rubbing.
Tire size for that wheel should be the 255/35R18 or 245/35R18. A 245/40R18 will be too tall.
Old 11-29-2014, 05:51 PM   #2590
Vancityfrs
Drives: Whiteout frs
17x9 +28
Lowered 2"
not sure on tire specs yet
cheers
Vancityfrs is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
