View Poll Results: What's your preferred method of starting from a stop on a typical hill?
Foot pedals only (clutch biting/friction technique) 152 63.33%
Foot pedals AND handbrake 69 28.75%
I drive an auto! 19 7.92%
Voters: 240. You may not vote on this poll
Old 11-21-2014, 10:59 AM   #43
Originally Posted by extrashaky View Post
When I was a teenager, one of our vehicles was a 1959 Chevy Apache pickup. Its emergency brake was a big handle under the dash. You pulled that thing out and it would make this horrible gear grinding noise, then lock in place. Then you squeezed the handle to release it with a large "BANG" as it cut loose.
It was not possible to use the emergency brake method for hill starts in that thing. Same thing goes for the foot e-brake in my S10.
I get a kick out of English people trying to tell the rest of the world how to drive. They can't even get the names of the parts of the car right.
Had a couple of vehicles with that set up. They were the manly ebrake! Pretty sure they designed some exercise equipment based on them.
Then all of a sudden, without any warning you would pull it and there would be no resistance at all. You then knew you had a project ahead of you.
Old 11-21-2014, 11:02 AM   #44
Koa
My 1952 Willy's truck (grandfather's family rig before he passed) has one of these. It's a riot every time
Old 11-21-2014, 11:13 AM   #45
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
no handbrake. fast response FTW!!!
Old 11-22-2014, 03:03 AM   #46
swpbrz
Drives: swp brz limited
Originally Posted by tobin View Post
I almost always use the handbrake. I have been driving manual transmission cars almost every day for 15 years. I feel that the handbrake method is the smoothest way to start moving on an incline and prevents wear to the clutch that doesn't need to happen.
These are my thoughts. You either burned through learning or are still burning through more clutch than you need to, or having a jerky start, if your doing any of these heel toe or quick peddle move with clutch biting methods. I'll stick with Handbrake and save my drivetrain.
swpbrz is offline   Reply With Quote
Old 11-22-2014, 01:01 PM   #47
Hahaha... Silly stuff like this is what makes life so great. I wish "LOL" wasn't such a tired expression.
Many moons ago when I was a teen, I let my then girlfriend drive my beetle. Had to go uphill to exit the garage. She panicked and rolled right into the back wall. What a mess that was.
For those wanting to advance beyond using the hand brake, remember it's ok to stall the engine. The beauty of it is that you won't roll backward so there's no need to panic.
If you think you're going to flub it, just let go. A little herky jerky but no harm - no foul.
Old 11-22-2014, 02:05 PM   #48
Koa
I can see how it's possible, but you are not recognizing that the clutch biting method doesn't need any fancy tricks to work properly. You literally find the clutch biting point, take your foot off the brake (the clutch will prevent you from sliding back), press on the gas, and release the clutch the rest of the way.
People who don't use the clutch biting technique try and paint a picture that it's some frantic struggle to transition the pedals and start on a hill. It's almost a hand-brake superiority complex imo
Old 11-22-2014, 03:52 PM   #49
extrashaky
Drives: 2014 BRZ Limited
I don't use any particular "method." I just let the clutch out and push the gas in, just like on flat ground. I just do it quickly enough that I don't roll back. I'm not putting any more wear on the clutch than you are.
Old 11-24-2014, 06:18 AM   #50
EthsTornadoGTS
Drives:
If you have to ask
You need to go back to driving a prius
Seriously there's no science
Quick transition
Or use the ebrake
Or
Rev to 25000 dump clutch
Rinse and repeat
EthsTornadoGTS is offline   Reply With Quote
Old 11-24-2014, 10:18 AM   #51
FRiSson
Drives: FR-S MT
Originally Posted by sgh View Post
Oh, and I think for people who believe that a 30% grade hill does not seem that steep, it will feel MUCH steeper than the picture indicates. There is a hill near me that's a 22% grade and it feels VERY steep. I was shocked when I found out it was only 22% I certainly wouldn't want to ride my bike up it... The steepest grade in the Tour de France for example is usually about 33%
Yup, they should have a SlopeChill index. A 25 degree slope "feels like" 45 degrees when you are on it.
FRiSson is offline   Reply With Quote
Old 11-24-2014, 11:05 AM   #52
RojerLockless
RojerLockless's Avatar
Drives: Raven Fr-s
learn to drive a standard? I don't really understand the question since it's obvious.
RojerLockless is offline   Reply With Quote
Old 11-24-2014, 11:16 AM   #53
Koa
what's a standard?
Old 11-24-2014, 11:57 AM   #54
Originally Posted by Koa View Post
what's a standard?
stand·ard
noun
noun: standard; plural noun: standards
  1. 1.
    a level of quality or attainment.
    "their restaurant offers a high standard of service"
    • a required or agreed level of quality or attainment.
      "half of the beaches fail to comply with EPA standards"
  2. 2.
    an idea or thing used as a measure, norm, or model in comparative evaluations.
    "the wages are low by today's standards
Old 11-24-2014, 03:19 PM   #55
Koa
I love (hate) you sometimes @Tcoat
Old 11-24-2014, 04:10 PM   #56
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
The BRZ was my first daily driven manual car. Although most of the suggestions to learn was using the handbrake method I found using pedals only was better for me.
Taught me how to feel the car out and be quicker in taking off.
Stealthy is offline   Reply With Quote
TRD Start / Stop Alabang 86 DIY (Do-It-Yourself) Guides 29 05-27-2014 02:35 PM
Start Stop Switch - BRZ Limited whatsinaname BRZ First-Gen (2012+) — General Topics 7 05-18-2014 09:30 PM
Preferred Gasoline Brand Poll brillo Scion FR-S / Toyota 86 GT86 General Forum 40 02-27-2014 12:54 AM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 01:00 PM
