Old 08-14-2013, 07:02 PM   #1
whatsinaname
Drives: 1998 Ford ZX2
Start Stop Switch - BRZ Limited
Might be a stupid question, but does anyone know what happens if the switch is hit when the car is in motion? The exact same thing as when you turn off the engine with a normal key or are there protections built in? I asked the sales person while test driving the FRS 10-series today and he didn't know.
whatsinaname is offline   Reply With Quote
Old 08-14-2013, 07:09 PM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
I never tried it but I'm going to guess there is a safe that wont let it shut down
SliverBrz is offline   Reply With Quote
Old 08-14-2013, 07:11 PM   #3
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
I was messing with this over the weekend and it didn't seem to want to turn off on the highway over 50mph.
Edit*
I should add that under 50mph it will turn the car off if you are in neutral. Press it again and it'll kick right back up.
Really wish this thing had the keyless nub-turn ignition my speed6 came with. Acted like a key without having to use the key.
spdfreak is offline   Reply With Quote
Old 08-14-2013, 07:13 PM   #4
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Refer to the manual, but IRRC in D/or in a gear hitting the start/stop button won't do anything. In N under a specific speed it will turn your motor off.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 08-14-2013, 07:21 PM   #5
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
I'm sure all start/stop buttons are at least child proof... or pet proof for that matter incase naughty children or small pets accidentally press buttons on your center console.
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 08-14-2013, 07:23 PM   #6
PhreshhWun
PhreshhWun's Avatar
Drives: 2013 Subaru Brz Sport-Tech SWP
I think from the last time I was being curious george, it turns off the car if your doing up to 50km/h or something around that ? I'll play with it again tonight haha
Mods: 2013 Subaru Outback fog lights, HID fog lights, LED vanity lights, LED dome light, LED trunk light, LED license plate lights, LED door courtesy lights, LED side markers, HID headlights, J2 Engineering test pipe, HKS Drop-In air filter, Window Visors, De-badged, and Diode Dynamics LED side mirrors
Side Chick: 93' 240sx Convertible
PhreshhWun is offline   Reply With Quote
Old 08-15-2013, 02:42 PM   #7
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
From the owners manual:
When the push-button ignition switch is pressed for 3 seconds or longer or pressed 3 times successively, the engine will stop. When the engine stops, the brake booster will not function. A greater foot pressure will be required on the brake pedal.
The power steering system will not operate either. A greater force will be required to steer, and it may result in an accident.
There has to be a way to turn it off while in motion, remember the Toyota unintended acceleration fiasco.
Scenic Driver is offline   Reply With Quote
Old 05-18-2014, 09:30 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks for this.... I had a scary situation with oil cooler line popping off and couldn't for the life of me turn the motor off quickly... Good to know there is a procedure for it.
TRD Start / Stop Alabang 86 DIY (Do-It-Yourself) Guides 29 05-27-2014 02:35 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 03:25 AM
