| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: BMW 120d
I just didn't re-write my post properly. No it's far LESS reliable as you've got a much increased requirement for coordination as you are REQUIRED to nail a seamless brake to throttle transition.
#30 |
Drives: 2015 FR-S (6MT)
Location: Vancouver, BC. not Surrey or Richmond or Burnaby!
First off, I know nothing about cars, but here is what I was told when I bought my first manual transmission (back in 1992):
1) A clutch is what you use in a manual transmission vehicle to replace what the transmission does in an automatic vehicle. 2) The clutch WILL wear out. Depending on how you drive, you usually have about 100,000 Km per clutch. Better driving will extend the life. 3) When the clutch goes, you will need to repair it. It is not easy to get to and requires a fair bit of labour. So when you get your clutch replaced, tell them to replace the flywheel at the same time. The flywheel is what spins to engage the engine to the drivetrain. The idea is that feathering of the clutch wears out the flywheel. But it is safer then just dumping the clutch because that would affect parts beyond the flywheel (not good, more expensive). So feather away my friend, it's much better then dumping. *Like I stated before, I know nothing about cars, so if any information above is incorrect, please correct me. |
#31 | |
The statement "far LESS reliable" is so laughable it's not even funny. Meanwhile you're trying to tell a noob to juggle the handbrake, the clutch pedal, the brake pedal, and the throttle pedal. Hats off to you old chap. ![]() ![]()
#32 | |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Sorry, couldn't help it.
| The Following 3 Users Say Thank You to Scenic Driver For This Useful Post: |
#33 | ||
Drives: BMW 120d
The beauty of this procedure is it allows for one to increase the starting revs from idle upwards before finding the biting point allowing the driver to simply release the handbrake to pull away from a standstill. The driver can simply keep the throttle & clutch at the same position and the car will continue to move forwards. Of course doing this for long periods will burn the clutch out. |
#34 | |
![]() I do this on gradients exceeding 10% all the time. Here's the hills we have in seattle. 18%+ grades all day. http://www.seattlepi.com/local/slide...ttle-31436.php Or we can view this handy grade diagram to knock your silly 10% gradient clutch bite ineffectiveness argument out the window. Notice it's very mild. ![]() You're cute to think that the clutch bite/footbrake only techniques are inferior when your and your country's technique requires the use of crutching another system altogether.
#35 | |||||
Drives: BMW 120d
#36 |
Drives: 2013 DGM BRZ
In the US it is not a requirement to have a handbrake in vehicles and in fact many only have a parking break on the floor. While it's recommended practice in other countries, it is not always possible in the US or really taught that way. The fact remains it's easy enough to do without using the handbrake and greatly helps one better master quick clutch engagement.
#38 |
Drives: 2013 GBS BRZ Limited
My Passat has a hill lock, so I dont need the handbrake OR "jumping off the brake".
I learned to drive stick and was NEVER told to use the handbrake at stops OR on a hill. I have never rolled back into anyone leaving a hill or stalled it. If you LEARN to leave from a hill without the handbrake, it is just second nature. And the "always coast to a stop in gear" is absolute BS as well. For one, if you want to "use the gear to get out of trouble" you are almost guaranteed to need to change gear ANYWAY if you suddenly decide to change from engine braking to abrupt acceleration. So one could argue that I can select my desired gear FASTER from neutral than some other random gear. |
#39 |
Let's get some data on this subject. Here's a poll that asks which hill start technique one prefers for typical hills!
http://www.ft86club.com/forums/showthread.php?t=77896 |
#40 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
If you drive this car based on what will extend the life of the synchros an extra 3 months, or what will get you 3% better fuel economy, or what is the "safest" technique, then YOU'RE DOING IT WRONG. Last edited by Stang70Fastback; 11-19-2014 at 05:49 PM. |
#42 |
Drives: Black Panda BRZ
Is this another 'American tries to teach the rest of the world how to drive a manual' thread? Lol.
| Tags |
| dead pedal, octane, response, slow |
| FRS auto -slow acceleration at 70km/hr | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-12-2014 12:33 AM |
| Slow Revving / Acceleration after TSB 0040-13 | Hardway | Issues | Warranty | Recalls / TSB | 9 | 08-25-2014 10:14 AM |
| Acceleration Times | itdansharpe | Engine, Exhaust, Transmission | 8 | 06-09-2013 04:25 PM |
| Not disappointed but curious. Why BRZ's acceleration numbers are relatively slow? | Wait4BRZ_STI? | BRZ First-Gen (2012+) — General Topics | 46 | 04-10-2012 10:46 PM |
| Acceleration | Axel | Other Vehicles & General Automotive Discussions | 0 | 02-10-2010 06:56 PM |
