| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Toyota Highlander; Subaru BRZ (SWP)
When I launch (dump the clutch) at around 1000 rpm from a standstill it takes about a second of "pedal to the medal" before the car gives any significant amount of acceleration (maybe 2mph/second). Is this because it's just running at very low rpms, or is it something more? Do I have a "Dead pedal" and need to reset the ECU by pushing the gas pedal up and down 20 times (method explained here http://www.ft86club.com/forums/showthread.php?t=39480)?
Is this normal? I'm currently running 91 octane from Costco. It was significantly worse when I was using 87 octane for 3 or so tanks in a row for reasons already explained in other discussions. |
Drives: Toyota 86 GTS
Is this a serious question? Because taking off at 1k rpm is too low, let alone "launching"
A.K.A. Starlord
Drives: 2015 Series.Blue
Dumping the clutch from idle speed won't really get you anywhere very fast, lol.
Drives: 2013 DGM BRZ
I'm not really sure what more you're expecting out of a 2.0L NA engine at idle speed. Our engines love to rev!
I'm not sure how you even "dump the clutch" at 1000 RPM. I think I'd have to practice that. My diesel truck has pretty good acceleration at 1K RPM but then again it's a 7.3L engine and redlines at 3800 RPM.
"Is this because it's just running at very low rpms,"
You have answered my question. Thank you very much. When I said "launching" I meant accelerating from a standstill. I don't like the feeling of slowly letting off the clutch until about 6 mph when accelerating from a stop, like I normally do. I have tried revving to ~1250 rpm at a standstill and then quickly letting go of the clutch fully while pressing the gas pedal slightly more. This method typically results in a very slow acceleration, taking about 4 seconds to cross a one way street. If this is normal then I am fine with it. |
#7 | |
A.K.A. Starlord
Seriously, how long is it taking you to feather the clutch? There is a difference between "dumping" the clutch like you describe (aka, just letting it go and slamming it into gear) and quickly feathering it. It's something that shouldn't take more than a full second once you're even somewhat adept at it. If you're legitimately just popping the clutch all over the place then you will eventually break something, or piss off your passengers, who will wonder why you can't drive properly. If you are seriously so lazy that you can't even bother to properly feather the clutch, do both yourself and the car a favor and go trade it for an automatic. You'll both be much happier. |
I love my series blue brz
Drives: 2010 335d
you are not driving correctly. need to find someone to tutor your driving technique. and do not put 87 octane. although it is not going to have any immediate damage besides retarded timing (= more fuel consumption and less power and bunching of knocking) , but it just not right.
#9 | |
#10 | |
I popped in the clutch to accelerate from a standstill several times, recorded the response of the car, and posted it online to ask if this was normal. When I had the 87 octane gas, the throttle would sometimes cut out when pushing the gas pedal all the way down even, myself believing this occurred because the computer detected a possible "knock". I was testing if there were better ways to accelerate from a standstill than feathering the clutch, because it ever so slightly wears out several components. Maybe it's me being overly sensitive, but it sounds like you already have some sort of grudge towards me. |
#11 | |
#12 | ||
Drives: 2005 Toyota Camry
There isn't enough torque at low RPMs in this engine to do what you want to do. That, and your choice of words was very poor to convey your thoughts in the first post. When launching a car like this, you need to slip the clutch a lot to maximize engine torque transfer to the wheels. When accelerating, same concept. You shift at a RPM (usually close to redline) to maximize available torque. -alex |
#13 |
No worries, if thats the case then it just sounds like your original post describes you under revving and stalling the engine.
#14 |
Drives: 2006 Evo IX SE
Is this your first manual transmission car? It's a pretty easy car to get going from a standstill.
| Tags |
| dead pedal, octane, response, slow |
| FRS auto -slow acceleration at 70km/hr | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-12-2014 12:33 AM |
| Slow Revving / Acceleration after TSB 0040-13 | Hardway | Issues | Warranty | Recalls / TSB | 9 | 08-25-2014 10:14 AM |
| Acceleration Times | itdansharpe | Engine, Exhaust, Transmission | 8 | 06-09-2013 04:25 PM |
| Not disappointed but curious. Why BRZ's acceleration numbers are relatively slow? | Wait4BRZ_STI? | BRZ First-Gen (2012+) — General Topics | 46 | 04-10-2012 10:46 PM |
| Acceleration | Axel | Other Vehicles & General Automotive Discussions | 0 | 02-10-2010 06:56 PM |
