Old 11-18-2014, 12:03 PM   #29
stonenewt
Drives: BMW 120d
Originally Posted by Koa View Post
I agree, the clutch bite/footbrake method is indeed more predictable and reliable than trying to work the handbrake system as well as your foot pedals.
I just didn't re-write my post properly. No it's far LESS reliable as you've got a much increased requirement for coordination as you are REQUIRED to nail a seamless brake to throttle transition.
stonenewt is offline   Reply With Quote
Old 11-18-2014, 12:20 PM   #30
jdd
Drives: 2015 FR-S (6MT)
Location: Vancouver, BC. not Surrey or Richmond or Burnaby!
Originally Posted by carma143 View Post
because it ever so slightly wears out several components.
First off, I know nothing about cars, but here is what I was told when I bought my first manual transmission (back in 1992):
1) A clutch is what you use in a manual transmission vehicle to replace what the transmission does in an automatic vehicle.
2) The clutch WILL wear out. Depending on how you drive, you usually have about 100,000 Km per clutch. Better driving will extend the life.
3) When the clutch goes, you will need to repair it. It is not easy to get to and requires a fair bit of labour. So when you get your clutch replaced, tell them to replace the flywheel at the same time. The flywheel is what spins to engage the engine to the drivetrain. The idea is that feathering of the clutch wears out the flywheel. But it is safer then just dumping the clutch because that would affect parts beyond the flywheel (not good, more expensive).
So feather away my friend, it's much better then dumping.
*Like I stated before, I know nothing about cars, so if any information above is incorrect, please correct me.
jdd is offline   Reply With Quote
Old 11-18-2014, 12:29 PM   #31
Koa
You do realize there is no need to rush from brake to throttle if you allow the clutch to reach the biting point?
The statement "far LESS reliable" is so laughable it's not even funny. Meanwhile you're trying to tell a noob to juggle the handbrake, the clutch pedal, the brake pedal, and the throttle pedal. Hats off to you old chap.
Old 11-18-2014, 01:02 PM   #32
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
So everyone taught to drive in the UK is being taught to do it wrong?
Since they teach you to drive on the wrong side of the road everything is suspect :-)
Sorry, couldn't help it.
Scenic Driver is offline   Reply With Quote
The Following 3 Users Say Thank You to Scenic Driver For This Useful Post:
Koa (11-21-2014), Stang70Fastback (11-18-2014), stugray (11-18-2014)
Old 11-18-2014, 01:24 PM   #33
stonenewt
Drives: BMW 120d
Small engines, low idle speeds = stalled engine if you're not quick enough or a roll back because you didn't get onto the throttle fast enough or release the clutch fast enough. I learnt to drive in a 700cc car which weighted just shy of a tonn. Using your method on a gradient above 10% you'd either stall or roll back unless you literally jumped off the brake and then jumped onto the throttle.
The brake pedal has NO involvement in a pulling away procedure. The car is held on the handbrake with one foot remaining on the clutch and one on the throttle from beginning to end of the procedure.
The beauty of this procedure is it allows for one to increase the starting revs from idle upwards before finding the biting point allowing the driver to simply release the handbrake to pull away from a standstill. The driver can simply keep the throttle & clutch at the same position and the car will continue to move forwards. Of course doing this for long periods will burn the clutch out.
Old 11-18-2014, 01:42 PM   #34
Koa
Learnt.. hmm not familiar with that word, you Brits have funny English
I do this on gradients exceeding 10% all the time. Here's the hills we have in seattle. 18%+ grades all day. http://www.seattlepi.com/local/slide...ttle-31436.php
Or we can view this handy grade diagram to knock your silly 10% gradient clutch bite ineffectiveness argument out the window. Notice it's very mild.
You're cute to think that the clutch bite/footbrake only techniques are inferior when your and your country's technique requires the use of crutching another system altogether.
Old 11-18-2014, 03:04 PM   #35
stonenewt
Drives: BMW 120d
which word?
And this proves what? You have hills, hey so did I growing up! Getting off my parents drive required a +18% grade climb.
I was talking about the 700cc car I learnt to drive in not every single car ever produced...
... but for a real world example using factory numbers - My engine produces up to 0.47kW at 650rpm with the throttle closed, that's about enough power to hold 1mph up a 10% gradient. Problem is the gearing gives me 2.5mph in 1st at idle! This tells us that it's going to be an absolute b**tch to pull away. Now with my foot flat to the floor I get 7.3kW at 650 rpm, that's enough power for almost 70%! So if I use my right foot for the throttle I'm a little stuck... unless I use my hand for the handbrake! See what happened? It suddenly got REALLY easy because I used the hand brake to give me more power
The very fact that the hill hold assistance exists is because people do not or, due to vehicle design, cannot effectively use the handbrake. Kind of says it all about the effectiveness of its use doesn't it
Old 11-18-2014, 03:34 PM   #36
Akari
Drives: 2013 DGM BRZ
In the US it is not a requirement to have a handbrake in vehicles and in fact many only have a parking break on the floor. While it's recommended practice in other countries, it is not always possible in the US or really taught that way. The fact remains it's easy enough to do without using the handbrake and greatly helps one better master quick clutch engagement.
Akari is offline   Reply With Quote
Old 11-18-2014, 03:43 PM   #37
Koa
^^ x10000
Old 11-18-2014, 04:02 PM   #38
stugray
Drives: 2013 GBS BRZ Limited
My Passat has a hill lock, so I dont need the handbrake OR "jumping off the brake".
I learned to drive stick and was NEVER told to use the handbrake at stops OR on a hill.
I have never rolled back into anyone leaving a hill or stalled it.
If you LEARN to leave from a hill without the handbrake, it is just second nature.
And the "always coast to a stop in gear" is absolute BS as well.
For one, if you want to "use the gear to get out of trouble" you are almost guaranteed to need to change gear ANYWAY if you suddenly decide to change from engine braking to abrupt acceleration.
So one could argue that I can select my desired gear FASTER from neutral than some other random gear.
Old 11-19-2014, 02:15 PM   #39
Koa
Let's get some data on this subject. Here's a poll that asks which hill start technique one prefers for typical hills!
http://www.ft86club.com/forums/showthread.php?t=77896
Old 11-19-2014, 02:20 PM   #40
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I use the "shift-down-through-the-gears-as-you-slow-down" engine braking technique. Why? Not because it's "correct," not because I like adding extra wear and tear to the synchros, and not because it saves fuel. I do it because it's fun. And fun is why I bought the goddamned car in the first place. Plus it doesn't hurt to get more rev-matching practice.
If you drive this car based on what will extend the life of the synchros an extra 3 months, or what will get you 3% better fuel economy, or what is the "safest" technique, then YOU'RE DOING IT WRONG.
Stang70Fastback is offline   Reply With Quote
The Following 6 Users Say Thank You to Stang70Fastback For This Useful Post:
Akari (11-21-2014), JohnJuan (11-19-2014), Jond63 (11-19-2014), Koa (11-19-2014), stugray (11-19-2014), Tgionet (11-20-2014)
Old 11-20-2014, 11:17 AM   #41
fika84
fika84's Avatar
Than put a 12lb flywheel in the car and start all over..
fika84 is offline   Reply With Quote
Old 11-20-2014, 08:53 PM   #42
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Is this another 'American tries to teach the rest of the world how to drive a manual' thread? Lol.
jonboy99 is offline   Reply With Quote
dead pedal, octane, response, slow
FRS auto -slow acceleration at 70km/hr Zhangy Scion FR-S / Toyota 86 GT86 General Forum 9 11-12-2014 12:33 AM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 04:25 PM
Not disappointed but curious. Why BRZ's acceleration numbers are relatively slow? Wait4BRZ_STI? BRZ First-Gen (2012+) — General Topics 46 04-10-2012 10:46 PM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 06:56 PM
