#85 | |||||
Engineering Student
Drives: Scion FR-S 2015
You fixed the problem (po230) by ripping out the relay of the fuel pump? I don't get how this happened, like a small voltage was going through the fuel pump or something? Did the DTC go away by itself or you had to connect to an ecutek? Quote:
I thought FBM comes with an 270 Fuel Pump?? Quote:
What are the traction isues? You are running 15psi? Whos your tune? Quote:
What is vaccuming, what does it do :3?? Quote:
I am sorry, who tuned you this time or whos the best tune you had? |
#86 |
in orbe terrum non visi
Drives: violent
You need someone to sit you down and teach you how a car works before you start asking questions on the Internet.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#87 |
NASA SpecE30 Racer
Go easy on him bro.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#88 | |
You need someone to sit you down and teach you how "internet' works before you start answering questions on the forum.
#89 | |
Drives: violent
#90 |
Engineering Student
#91 |
Sideways and Smiling!
Drives: Scion FR-S
Are you still using the stock transmission with a cooler?
#92 |
Drives: violent
no cooler. I didnt end up having temp problems im just shearing 4th. Working with a vendor on a possible fix. If none is found im putting in a sequential.
#93 |
NASA SpecE30 Racer
- King Tut
#94 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#95 |
Updates? These kind of build threads are what keeps me on the forum.
#96 |
Drives: violent
Tracked the car hard at AMP in 80+* heat. Oil temp was 230s with a record high of 240. Coolant was 200. RCE tarmac 2's out performed my expectations with 500 pound springs. I had them dialed in after a few sessions. Ventus V12s were at their limit all day and my AP sprint kit felt great with winmax w5 pads. Though I was on the abs a little much. Never had any fade but my rotors show they got pretty hot. Going to put brake ducts in. Had massive fuel starvation on the long sweeping left hander. I put an oem fuel pump in the passage side pumping fuel into the surge cup to fix the problem but the Walbro 485 still sucks the surge cup dry faster than it can be refilled. Two other NA cars had the same problem. All on street tires. I can't believe there isn't more people talking about this. Every one of us can fuel starve the car in turns even at stock hp and street tires at 1/2 tank. Trying to fix it now. Car was on waste gate pressure all day, mid-upper 300whp and had no problems leap frogging with a zr1 on this track.
#97 |
Off Topic
@King Tut posted about a Holley HydraMat in @ATL BRZ's build thread, because he was having the same issues at AMP. It's basically a bladder that sits inside your fuel tank and wicks fuel into itself from wherever it's touching. The pump draws fuel from within the bladder.
https://www.holley.com/products/fuel_systems/hydramat/ |
#98 |
Drives: violent
Thanks. I saw that and is a possibility
| Just Another (Turbo) Build | rb6freak | Member's Car Journals | 184 | 03-22-2017 09:25 AM |
| Sms Al Suwaidi's Frs Turbo to be Build | SmsAlSuwaidi | Member's Car Journals | 327 | 01-30-2017 09:19 AM |
| Do Boy's Turbo FR-S build!!! | Do Boy | Member's Car Journals | 417 | 11-29-2015 02:17 AM |
| fully build turbo fr-s/gt86/brz | Baramzisyan | Want-To-Buy Requests | 15 | 03-22-2014 03:26 PM |
| Turbo Kit & Shop Car Build | Carolina Dyno | Forced Induction | 11 | 01-22-2014 03:59 PM |
