Drives: 2013
Turbo Kit & Shop Car Build
We've just recently purchased this FR-S as our new shop car and R&D vehicle. We've been working on some chassis parts but we finally got some time to spend on our turbo setup.
We're just mocking things up right now but we've got a few parts made and the manifold started. Our kit will be at aimed at people looking to make higher than average power, based around a divided T4 double slip collector with mulitple turbo options available, we will likely be using a Borg Warner EFR turbo in our case. This kit will be available in multiple primary sizes and either 321 or 304 stainless tube not pipe like most manifolds. This is a bit more expensive but the gains in power output, durability, and weight are well worth the extra cost. We're also working on an intake manifold, a direct injection removal kit, and more. Some of these parts are still prototypes and may be changed during testing. The machined parts are (left to right): HP fuel pump block off, hub spacers, throttle body flange, intake manfiold flanges. ![]() We've a few other things in the works as well, some of which we have CAD previews of below. Left to right: MAF block with 3" radius, fuel rail, exhaust manifold flange, MAP block
#2 | |
Drives: 2013 Raven FRS
Very nice! Looking forward to seeing the future here.
That Guy
Drives: 2013 asphalt FRS MT
More power then I'm looking to make, but this should be an interesting thread. I can't wait to see the outcome.
What's the motivation to block off the DI system? |
#4 | |
Drives: 2013
While there are advantages to DI and I'm sure it will take over in the future right now it is far to expensive to upgrade the pumps and injectors to be able to support the power we are after reliably. We will have to run so much port injection that the DI would literally be nothing but extra weight and something to break. |
#5 | |
That Guy
Are you planning on building a low compression block?
The reason everyone is able to go FI on our engines with such high compression is because of the cooling effects from the DI system. From what I've gathered, unless you drop the compression, running only port injection won't give the best results with the stock block and high compression. This engine was also designed with DI in mind, and I know the piston tops have a special shape to accommodate the DI. A port-only injection setup might call for different shaped pistons as well. IF you do go with low compression and only port injection, and are going for big power, you'll be breaking new ground. I wish you the best and will watch your results. |
#7 | |
Drives: 2013
The main reason people lower compression is to open up the tuning window. If you are at 12.5:1 under a decent amount of boost there isn't much margin for error. If you lower it to say 10:1 just about anyone can tune it and come through ok. |
| The Following User Says Thank You to Carolina Dyno For This Useful Post: | charged86 (01-27-2014) |
Drives: 2013 Raven Black FRS
What EMS are you running?
Nice to see a post with some different stuff! Very interesting! I'm working on an intake manifold myself also. Jesse |
Drives: 2013
#10 | |
Pegasus White
Drives: 86
Driving: Pegasus White Manual GTS 86.
#11 |
Drives: 2013
At this point you would have to lose the direct injection but we could put a kit together for you. If you're interested email me at ben@carolinadyno.com and well get you sorted out.
A few companies were hopeful at PRI that they would release DI compatible cams but nothing so far. |
#12 |
Drives: 2013
Our turbo for the prototype kit finally arrived this morning. Thanks to our friends at Full-Race for hooking us up with this Borg Warner EFR 7670. The kit will be based around this turbo, but everything from the 7064 to the 9180 will be an option.
| Just Another (Turbo) Build | rb6freak | Member's Car Journals | 184 | 03-22-2017 09:25 AM |
| WTB: Local shop for track build | DatApex | Great Lakes | 1 | 06-17-2013 07:56 PM |
| Just wanted to show off my turbo build | sw20kosh | Forced Induction | 5 | 04-01-2013 03:16 PM |
| Shop in TN or MS to install and tune turbo | brocktwalker | Southeast | 2 | 03-16-2013 09:58 AM |
| Turbo engine build, and parts | No Limit Motorsport | Forced Induction | 30 | 12-11-2012 07:32 PM |
