Old 11-18-2014, 01:14 PM   #2185
ja1217
Drives: 2004 Toyota RAV-4 5M
Yes, 2.5 is good.
With those rates I would probably go with 7 inch springs BUT you may want to check the amount of bump travel in your shocks and then look up the specs on the springs to see if they have at least that much.
The Ohlins are a little tricky since they can't lower the car much.
- Andy
Cool, thanks. I can't seem to find any specs on the bump travel, so I will probably give Ohlins a call and see what they recommend.
ja1217 is offline   Reply With Quote
Old 11-18-2014, 01:18 PM   #2186
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Just want to check if anybody is running with the Cusco Zero-3X or the Aragosta Type S coils?been googling but most reviews are on a different platform.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 11-18-2014, 03:47 PM   #2187
PNW FRS
PNW FRS's Avatar
Originally Posted by PNW FRS View Post
Ok - will check that again.
Thx
Well... for not being up on lift, there was only so much leverage I could exert to try and tighten-up both nuts. There was some movement (i.e., tightening) and after a bit of AM driving -- over the usual roads that produce the noise, it does seem to less.... maybe almost 80-90% less... but I'll try to keep tabs on this over the next couple of days and see if the "fix" holds up.
Update: Nope... after a day of driving around.. the crunching sound is back... arggh. Doing more reading on the forum and finding multiple threads about end link binding... sounds very similar to what I'm hearing.
One thing that I'm going to look into is that the replacement end links are different (not only that they are shorter...) in that the mounting points swivel -- and I'm wondering if it is this movement that is making the crunching sound -- i.e., maybe one or both "swivel" are bad (since left side is not making the noise).
Update: Huzzah!! Found the offending nut on the end link (at one of the adjusting ends...) that was tightened the wrong way!! Instead of being tightened down onto the shaft, it was tightened UP to the ball joint -- "grinding" against the outside of the ball joint. Fixed... and now the suspension is QUIET!!
Wow.. what a learning experience!
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 11-20-2014, 08:41 PM   #2188
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@Racecomp Engineering So I just installed HKS MAX IV SP coilovers and now I'm getting some squeaking noise from the front when going over speed bumps. No alignment done yet as I'm giving it a week to settle. Any ideas? It sounds like this kinda
[ame="http://www.youtube.com/watch?v=CscrvojGj9U"]Squeaking Noise, Front Driver Side - YouTube[/ame]
Bach415 is offline   Reply With Quote
Old 11-23-2014, 10:40 PM   #2189
shellslinger
Not sure if this question has been answered, I apologize if it has been answered. I am trying to chose between these 3 coil overs.
1. RSR Sports-I
2. Tein Monosport
3. RCE T2
This set up is mostly just for street use, spirited canyon runs and an occasional track day or two. Also, not looking to lower the car more than 15mm.
Can you guys recommend which is best for my application?
*Please note, I am a beginner when it comes to suspension.
Thank you all for such a great thread
shellslinger is offline   Reply With Quote
Old 11-24-2014, 09:02 AM   #2190
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
1. RSR Sports-I
2. Tein Monosport
3. RCE T2
If i may give my opinion.. I think the RSR sports-i are more oriented towards what you want. The RCE t2 are probably more track oriented and they're dual adjustable(compression, rebound adjust seperately) so it could give you a headache if you're not used to it or really need it(or know what you're doing). I dont know about the Tein but i've been reading on the Sports-i myself and they have a great valving job for comfort on street. They allow to add a fixed amount of camber via top mount , has radial bearing to help with spring noises on mcpherson suspension and rubber bushings to reduce NVH transmitted.
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
shellslinger (11-24-2014)
Old 11-24-2014, 10:50 AM   #2191
Since I'm not too familiar with those coilovers, I can't say much beyond double check the install. Check with your vendor for troubleshooting help too.
- Andy
CSG David (12-01-2014)
Old 11-24-2014, 10:51 AM   #2192
I knew it was an endlink issue.
- Andy
Old 11-24-2014, 10:54 AM   #2193
1. RSR Sports-I
2. Tein Monosport
3. RCE T2
At a 15mm drop our T2s will have a lot of travel which is a plus on canyon runs and the street. We also provide very good settings you can use so you don't have to worry about getting lost in the settings (plus we're almost always available by phone or PM). Run them with stock top mounts and enjoy a good quiet set-up that performs well on the street and track. I think you'd be really happy with them.
I've yet to try the RSRs but I'd like to.
- Andy
Mad_Mike (11-24-2014), shellslinger (11-24-2014)
Old 11-24-2014, 06:25 PM   #2194
PNW FRS
PNW FRS's Avatar
- Andy
Thanks for all the insights!! Now... here's camber situation...
Rear camber: Lt. -2.1 / Rt. -2.3
Front camber: Lt. -1.1 / Rt. -1.2
* This is the best match the alignment shop could do with the camber plates.
So... car is DD. Every chance I can, I'm on the twisty backroads having fun. With aspirations of fitting in some HPDE in 2015 after I beef up the brakes. My lay-opinion today is that the car handles great. But... any additional insight is appreciated.
I'm got 17 x 8.0 TSW Interlagos (+35) with Michelin PSS 225/45 (square).
- Leave as-is? See how the tire wear goes?
- Add some bushings to front to get more negative?
- Add some bushings -- or adj. LCA -- to rear to reduce negative?
2013 Asphalt / MT
Olympia, Washington
Old 11-25-2014, 08:11 AM   #2195
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Tire temps will tell you what you need. Invest in a simple pyrometer to get started. You don't need one with ultra-2000-memories, just a simple instantaneous temp reader and write it down on a sheet of paper. Analyze the temps, then adjust as needed.
bimmer635csi is offline   Reply With Quote
Old 12-01-2014, 07:14 AM   #2196
evil_1998
evil_1998's Avatar
Drives: GT86
Hi, I have a set of coilovers but unsure of spring rate.
On the springs they are marked:
160-8.5 (front)
180-07 (rear)
Can someone please tell me the spring rate in kg's?
Thanks
PROJECTGT86
evil_1998 is offline   Reply With Quote
Old 12-01-2014, 12:39 PM   #2197
Agent 86
Drives: 2017 Cayman S
I have a question that's probably been asked somewhere in these 100 pages…
I have a 2014 BRZ that I have had for a little over 2 months now. I don't race or autocross, but I do enjoy and appreciate having a car that is responsive and handles well with a reasonable level of ride comfort.
The factory setup meets my needs, but I would like to lower my car a little (for looks) and install a better looking set of wheels (17" or 18").
What can you recommend for my situation? There must be a simple path I can take.
I was considering the RCE Yellow springs, but then I see discussion about adjusting camber, installing crash bolts, bushings and lower control arms and i become paralyzed.
Please provide some suggestions.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 12-01-2014, 12:51 PM   #2198
160-8.5 (front)
180-07 (rear)
Thanks
Could be 8.5 kg, 7 kg, but every manufacturer does it differently. Best bet is to contact the company you purchased from or that makes the kit.
- Andy
CSG David (12-01-2014), evil_1998 (12-01-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
