Old 08-04-2013, 10:20 PM   #1
mrk1
Drives: Sterling BRZ Ltd
Hotchkis Camber plates, anyone tried them?
http://www.hotchkis.net/scion-frs-su...er-plates.html
I'm looking for a replacement for the whiteline com mounts. Has anyone tried these hotchkis plates? I've used hotchkis sways before with great success.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Hotchkis (08-05-2013)
Old 08-05-2013, 04:14 AM   #2
KONVERTER
KONVERTER's Avatar
Hotchkis makes a good product.
These are ideal if you are using aftermarket shocks & springs and want adjustable camber. Many coilover kits are going to have pillow ball camber plates.
Many of these Hotchkis products are used for different autocross classes that may require factory suspension / specific stock / spring combo's only.
KONVERTER is offline   Reply With Quote
The Following User Says Thank You to KONVERTER For This Useful Post:
Old 08-05-2013, 09:15 AM   #3
wparsons
wparsons's Avatar
Looks like a good option!
flickr
Old 08-05-2013, 11:37 AM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Does anyone know if these work with the OEM upper spring perch?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following 2 Users Say Thank You to feldy For This Useful Post:
console_cowboy (08-05-2013), Hotchkis (08-05-2013)
Old 08-05-2013, 02:20 PM   #5
Hotchkis
Hotchkis's Avatar
Hi feldy,
Yes, the Hotchkis camber plates were originally designed to work with the OEM upper spring perch. They will work with Koni yellows, along with other coilover struts that intended to reuse the OEM top hat.
Another factor that we paid close attention to was maintaining bump stroke and not raising the ride height with these camber plates. Let us know if you have any other questions.
Cheers!
Hotchkis is offline   Reply With Quote
Old 08-05-2013, 02:26 PM   #6
feldy
feldy's Avatar
Originally Posted by Hotchkis View Post
Hi feldy,
Cheers!
Thanks for the reply. Currently on my 4th set of white line c-coms they just cant take the extra caster. Hoping to find something that worked with the oem top hats.
The Following User Says Thank You to feldy For This Useful Post:
Old 08-05-2013, 02:30 PM   #7
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
So is there a reason you decided to go with 6065 aluminum over 7075 aluminum? I've dealt with equipment made out of both, and 7075 has always been much more sturdy stuff. I am just curious about the reasoning of going with what is traditionally considered a weaker aluminum alloy.
console_cowboy is offline   Reply With Quote
The Following User Says Thank You to console_cowboy For This Useful Post:
Old 08-05-2013, 02:44 PM   #8
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm waiting ... ever so patiently ... on the Raceseng caster/camber plates:
http://www.raceseng.com/blog/design/...camber-plates/
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Old 08-05-2013, 06:17 PM   #9
Hotchkis
Hotchkis's Avatar
Hi console_cowboy,
We designed our camber plates using 6061 T6 AL due to it's strength, weight, and cost. 6061 is more than adequate for this particular component. We did not want to incur more cost for 7075 when it did not need to.
Now with that said, we do produce other components (for other applications) out 7075 where more strength is needed. So we do not shy away from stronger, more expensive materials, but rather use it when we need it.
Cheers!
The Following 2 Users Say Thank You to Hotchkis For This Useful Post:
console_cowboy (08-05-2013), feldy (08-05-2013)
Old 11-16-2014, 09:21 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
Hi console_cowboy,
Cheers!
Back from the dead...
What's the life expectancy of the bearings in these?
Anyone using these able to share a review?
Old 11-16-2014, 09:41 PM   #11
wootwoot
Drives: FRS
I'm curious what kind of camber you can get of of them when not using the supplied camber bolts?
Old 11-18-2014, 01:19 PM   #12
Hotchkis
Hotchkis's Avatar
Calum,
On our shop FR-S we recently checked the condition of our Hotchkis camber plate bearings and they were still in good condition. We had approximately 13k miles of street, track, and autocross driving. We've never experienced any noise or knocking from these plates.
Just like anything else, bearings will eventually wear out and need replacement. The bearing itself is replaceable, so you can always order more from us when needed. We do use large, high quality Aurora M20 PTFE lined spherical bearings, so life expectancy is great for a pillow ball designed camber plate.
Thanks for the inquiry!
Calum (11-18-2014), Sportsguy83 (11-18-2014)
Old 11-18-2014, 01:46 PM   #13
Hotchkis
Hotchkis's Avatar
wootwoot,
You can get about 1.5° of negative camber using our plates without using the supplied crash bolt. Note:This is for an OE style strut equipped car. Various adjustable coilovers do have the upright mounting holes in different locations (compared to OE) that allow for more negative camber. In some coilover cases, one could achieve a decent amount of negative camber with simply using the crash bolts, which could save some guys money by just buying bolts.
The camber plates do have 1° of positive caster built in as well.
Calum (11-18-2014), OGSCION (11-19-2014)
FEELER: KW V3 With Hotchkis Camber plates Jesse@JDLAutodesign Brakes, Suspension, Chassis 11 10-18-2013 01:54 PM
AMR Camber Plates 20firestorm13 Southwest 4 06-09-2013 10:21 AM
FS: AMR Camber Plates 20firestorm13 Brakes, Suspension, Chassis 2 06-08-2013 09:50 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
MSI Camber plates wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-29-2012 07:16 AM
