Old 11-23-2012, 05:49 PM   #1
wootwoot
Drives: FRS
MSI Camber plates
Is anyone running MSI camber plates? I wanted to confirm that they work with OEM type struts and that they do not change the ride height.
wootwoot is offline   Reply With Quote
Old 11-23-2012, 05:55 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Contacting MSI would probably get you the quickest and most accurate information.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-28-2012, 11:54 AM   #3
Turn in Concepts
Turn in Concepts's Avatar
We have tested them. They will work with the stock strut, but they will also raise the height of the car by about 3/8".
I have a little something we've been testing for a while that I'm about to post a pic of.
Turn in Concepts is offline   Reply With Quote
Old 11-28-2012, 02:10 PM   #4
Hotchkis
Hotchkis's Avatar
If you are looking for camber plates that are compatible with stock struts and don't change the ride height, then you may want to take a look at ours:
http://www.hotchkis.net/scion-frs-su...er-plates.html
These plates are precision CNC machined from 6061 T6 aluminum and feature type 3, hard anodized finish for years of durability and performance. Each plate is loaded with a high quality PTFE lined bearing and is designed for easy service. The plates do not change vehicle ride height and are designed to adjust up to -3 degrees of camber when using the included strut bolts. Caster has been increased on this plate by +1 degree from stock.
Hotchkis is offline   Reply With Quote
Old 11-29-2012, 04:06 AM   #5
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks for the info. It's hard to tell from the pic, but there doesn't seem to be any adjustability in the plate itself. Is the whole adjustability done with the strut bolts?
I'm looking for a camber plate that can be used with the stock struts and stock fixed strut bolts, and that won't increase ride height. There doesn't seem to be anything like this out there.
Phaedrus29 is offline   Reply With Quote
Old 11-29-2012, 07:16 AM   #6
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Looks that way. They would function exactly the same as something like the vorshlag camber plates without the added height increase from the adjuster block. Just because there are less parts doesn't necessarily make it any worse. These are the camber plates I will be getting in spring when my car gets lowered on the Hotchkis stage 1.
Although I have to admit the vorshlag ones do look way cooler lol
kask2_6.0 is offline   Reply With Quote
Which camber plates are you running? Coastermikey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-15-2014 10:26 AM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
CUSTOM PLATES OR REGUALR PLATES? Koomoo Scion FR-S / Toyota 86 GT86 General Forum 13 05-21-2012 09:38 PM
