CANADA Canada
go_a_way1
Old 11-12-2014, 11:24 AM   #967
HachiRoku1
Ok, this past weekend was my first real experience with the BRZ in snow conditions.
I must say, I'm more than a little choked by the electronic nanny. I was hoping to have so much fun with it, but no matter how I press the buttons to turn the electronic aids off, they still kick in to some degree, and saps any enjoyment I thought I would have with it. =/
Does anyone in town offer a permanent solution to turning the nanny OFF completely? Like install a switch so I can flick it on or off at will?
HachiRoku1 is offline   Reply With Quote
Old 11-12-2014, 11:53 AM   #968
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by HachiRoku1 View Post
I've never tried Nokians before (mostly cuz they cost an arm and a leg), but I have tried most other brands. Personally, I think the best overall Winter tire is Dunlop (I forget the specific model). Though they aren't as good on pure ice and snow as Blizzaks, but they are much better in wet and have less wear in the dry.
If you don't get Nokians, I'd recommend a good set of Dunlops!
I don't find Nokians to be worth any premium over other quality tires. Pirelli Sottozero are the best performance winters I can currently get (IMO) and I used to love the old Hankook W300 Icebears wear amazing.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 11-12-2014, 11:53 AM   #969
BRZZZZZZZZZZ
Car Nut
Do some reading and you will find how to defeat it properly.
Old 11-12-2014, 01:00 PM   #970
HachiRoku1
Hey, thanks for the suggestion. I watched the video of the "pedal dance", and I can't imagine having to do this every time I jump in the car...that's insane! LOL
However, I'm going to try the pressing/holding the TC button for 3-seconds and see how the car responds after that. I'm hoping it's good enough.
But if anyone knows a shop that can rewire the car and provide a switch that can turn it on/off, that would be ideal.
Thanks!
Old 11-12-2014, 03:09 PM   #971
atomedge
Drives: 2014 Subaru BRZ Sport-Tech
Talked to Kyle at SpecR and he was awesome. Good advice and competitive pricing. Looking forward to dealing with him again.
atomedge is offline   Reply With Quote
Old 11-12-2014, 04:58 PM   #972
Heru Farukon
Drives: MOARLOW BEEARRZEE
None that I know of. Only thing thing I've seen is holding the trac off for 5 secs or pedal dance
Heru Farukon is offline   Reply With Quote
Old 11-12-2014, 05:02 PM   #973
BRZZZZZZZZZZ
Car Nut
I wouldn't want to start messing with wiring, you will void some warranty real quick.
Old 11-12-2014, 06:11 PM   #974
Heru Farukon
0-100 real quick real quick
Old 11-14-2014, 12:19 AM   #975
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
ABS fuse won't solve everything?
Cueman is offline   Reply With Quote
Old 11-14-2014, 11:31 PM   #976
Assunta
Assunta's Avatar
Drives: 2013 SWP BRZ
Somewhere on this forum is a thread showing you a means to return your nannies to their prior settings before ignition kill. Check it out. There may be a way to switch between settings on the fly.
Assunta is offline   Reply With Quote
Old 11-17-2014, 01:19 AM   #977
tipiman
tipiman's Avatar
Drives: slow dd
Loving my hakka 7's in the snow and ice so far, definitely worth the money I think. The car is so much fun in the snow! shutting all the TC off makes it so much more enjoyable to drive it around town.
tipiman is offline   Reply With Quote
Old 11-17-2014, 01:52 AM   #978
zumhakr
Drives: 2014 BRZ Sport Tech - Silver
Did you get the studded ones ? And did you go stock size?
I just pulled the pin on hakka 8's studded for my beater for the ski runs. Getting them installed on Tuesday.
zumhakr is offline   Reply With Quote
Old 11-17-2014, 01:55 AM   #979
tipiman
tipiman's Avatar
Drives: slow dd
Yeah I got the studded ones and went with the same as stock tires size. So far so good this winter!
instagram - jmunni
Old 11-17-2014, 10:55 AM   #980
BRZZZZZZZZZZ
Car Nut
It would in my eyes but he want's a on/off switch so he doesn't have to mess around with fuses etc from the sounds of things.
BRZ ordered in Edmonton whitejdm CANADA 18 07-06-2012 11:41 AM
FRS has arrived in Edmonton! DragynVyrus CANADA 15 06-27-2012 07:16 PM
is there any group buy around calgary or edmonton area? FT86FRS CANADA 0 04-05-2012 01:24 AM
BRZ SWP Premier 6MT at Calgary Auto Show Enemies CANADA 2 03-15-2012 02:55 AM
No FRS at Edmonton Motor Show whitejdm CANADA 16 03-03-2012 08:19 PM
