Old 06-29-2014, 10:19 PM   #57
UF Key Master
UF Key Master's Avatar
Drives: 2013 Toyota FRS Ultramarine
No problems with the windows hitting anything but if you do not put the door all the way down when closing it to latch it will rise and the door will strike against the latch bolt. In order to help prevent further damage to the door I have put a strip of rubber above the latch on both doors.
UF Key Master is offline   Reply With Quote
Old 06-29-2014, 11:25 PM   #58
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
looks like good solid work and skipping over to the last vid shows that the work looks pretty good.
couple of things that i'm concerned with with the video though...
1 - is it me or does it look like the bottom portion of the door does not line up with the body now? or is that just an illusion?
2 - when I saw you pull the door down, it looks like the metal gives a little and bends a bit. how's the wear and tear of the module? it looks like the mounts don't take stress very well with the bouncing of the doors with the brace.
I mean for me i'm not a fan of vertical doors, but it's a bit unique in this term since it actually pulls out and then up so i'm wondering about the build as well as the braces to see how they are reinforced.
CamryDS is offline   Reply With Quote
Old 06-30-2014, 12:46 AM   #59
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by evan View Post
I'm putting on my tight pants and thick rimmed glasses on right now. Yes, the majority are lemmings.
What if you enjoy something, some movie or musician or something, and then you discover more people like that something than don't? Do you stop liking it when you find out the majority does to avoid being a lemming?
brianhj is offline   Reply With Quote
Old 06-30-2014, 03:47 PM   #60
chas3wba0
chas3wba0's Avatar
Drives: Yes
That's what you call a "desperately different hipster"
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 10-09-2014, 07:13 PM   #61
Parappa
Parappa's Avatar
Drives: Scion FR-S White Out
I think it looks pretty damn hot! Nice job on the doors. The FRS is a fun car to customise and is a great hobby.
Parappa is offline   Reply With Quote
The Following User Says Thank You to Parappa For This Useful Post:
UF Key Master (10-09-2014)
Old 10-09-2014, 08:19 PM   #62
G-awesome
Drives: 2015 Firestorm Scion FRS
hmmm....that actually looks pretty damn good! nice job!
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
UF Key Master (10-10-2014)
Old 10-13-2014, 05:24 PM   #63
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Originally Posted by UF Key Master View Post
Your right, it was purchased as a Scion. I have since rebadged and purchased everything I could to make it Toyota. I'm the original owner of an '89 MR2 and this car was its' replacement. It just bugged me looking at "Scion" so I changed it. You know - the title actually says Toyota.
Original owner? That is awesome, My wife has a 91 MR2 but we aren't old enough to be the original owners haha. Do you have pictures of your MR2?
Also awesome job on the mod, I like it!
Gregory Gawaran is offline   Reply With Quote
Old 10-13-2014, 05:38 PM   #64
brianhj
What are you going to do about the fact that the entire car was built by Subaru? Well except the DI system
Old 10-15-2014, 07:27 PM   #65
Model Citizen
Lacking brains
Drives: frz
I hate oxygen cause everyone else likes it.
Good for you op,
in for your gullwing door followup
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-17-2014, 11:23 AM   #66
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
nice DIY but not fan of this.
Old 11-12-2014, 02:39 PM   #67
Parappa
Parappa's Avatar
Wondering if you can tell me a bit more about the doors. Can you use them like regular doors for daily use and use the vertical door mode for fun?
When you open the door, does it spring to vertical door mode or easy to accidently bounce into vertical door mode?
What happens when the door is vertical and you push door towards the body of the car...it looked a bit wobbly in the video. Any chance of damage to the body/frame of the car.
I like the kit, entertaining the idea of getting this done. Just want to make sure its a solid kit.
Old 11-12-2014, 03:26 PM   #68
radroach
Drives: car
I think this would look better if it were on some kind of track to swing upward instead of having to go outward with all that play. Really like the look though.
Old 08-11-2018, 12:48 AM   #69
ArgentoAtl
ArgentoAtl's Avatar
Drives: Argento manual
adjustment to keep doors open on hills
Your mod is very impressive to me.
I wonder if you or others know of a way to adjust the standard FRS doors to stay open on slight hills? Mostly my need is on sideway hills, not front to back, but both would be nice. My 2013 has a hard time staying open.
Brian in Atlanta
ArgentoAtl is offline   Reply With Quote
The Following User Says Thank You to ArgentoAtl For This Useful Post:
jcw99 (08-11-2018)
Old 08-11-2018, 01:52 AM   #70
jcw99
Drives: swp mt '14 brz premium
Brian in Atlanta
Ditto
jcw99 is offline   Reply With Quote
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 03:08 PM
DiodeDynamics Door LED install Khazzy DIY (Do-It-Yourself) Guides 25 05-09-2014 09:52 PM
Red inside door handle grips how to install? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 03-24-2014 12:21 AM
Selling a Vertical door kit FRS-89 Exterior Parts (Aero, Lighting, Etc.) 0 02-20-2013 02:57 PM
Anyone install door stabilizer? russv Cosmetic Modification (Interior/Exterior/Lighting) 1 08-12-2012 12:08 PM
