#43 |
Drives: Scion FR-S
Shouldn't be too bad xD. Patience will pay off =D
2013 Ultramarine FR-S 6MT
#44 | |
When In Doubt...
Drives: Slowww
My friend and I got mine done up to the point where we realized the map light is doing something weird (reverse polarity?). So the courtesy lights stuck on all the time. I'll figure out a fix one day but it's fairly low on the priority list.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#45 |
Custom User Title
Drives: Asphalt FR-S MT
Dude you're late. I did this...like...a month ago. The thread should be some where above or just search door courtesy lights. I explained the whole idea of the ground controlled configuration.
#46 | |
When In Doubt...
Drives: Slowww
I don't have to search, you PMed me all the info ![]() I just didn't remember the username :happy0180:
#48 |
Drives: Scion FR-S
I just finished the passenger side. Man getting it through that loom and into the door is really annoying. Punched a hole through it and zip tied it to the loom instead. Now for the driver side.
#49 | |
Custom User Title
http://www.ft86club.com/forums/showt...courtesy+light
#50 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
Is it possible to get any sort of battery powered module that will only power on when the doors are opened. This would prevent having to do any wiring, etc. I'm thinking of those closet lights that will only power on the LEDs when the door is opened...?!?
#51 |
Custom User Title
Then you have to remove the door panel just to change the batteries.
#52 |
Drives: Toyota GT86
#53 |
Custom User Title
The clip is on the inside of the door.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Chad86 (11-20-2014) |
#54 |
Drives: Toyota GT86
So it seems the only solution is to use the BRZ wiring harness, I assume...
I will definitely need to get this done, as this should have been setup from factory. The Monogram should have included this.
#55 |
Custom User Title
![]() My DIY is right above your first post on this page.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Chad86 (11-21-2014) |
#56 | |
Drives: 2014 FR-S Monogram, Whiteout 6MT
![]() I didn't use the harness. I wired a power source through the OEM door tube which took me 4 hours total for both doors. Passenger door went much smoother after I figured out the driver side. To make sure my struggles didn't go in vain, I will do a short write up on how to shove the fucking wire down that rubber tube's butthole very soon. Everything else is just plug and play. I wired my courtesy and footwell lights to my dome so they operate as close to OEM as possible, ie when the door is open. As you can see from the third picture, no exposed wires.
2007 Honda CBR600RR-Pearl White/Silver - Totaled ![]() 2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build) φφκα |
| The Following 3 Users Say Thank You to LXXXV1 For This Useful Post: |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 07:29 PM |
| W221 S550 2 step correction | CU2MIKE | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 06-07-2012 12:08 PM |
| Do you think Mazda will have to step it up now? | ngabdala | Other Vehicles & General Automotive Discussions | 56 | 06-02-2012 11:47 AM |
| Manual tranny takes another step into oblivion | madfast | Other Vehicles & General Automotive Discussions | 76 | 03-06-2012 09:40 PM |
