Old 07-08-2013, 05:38 PM   #43
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Originally Posted by Mr.Jay View Post
The little battles first.. but soon the war
Shouldn't be too bad xD. Patience will pay off =D
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 07-08-2013, 05:44 PM   #44
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by boredom.is.me View Post
I admitted defeat. The wire loom for the door is a bigger pain than it is worth.
Use a metal coat hanger
My friend and I got mine done up to the point where we realized the map light is doing something weird (reverse polarity?). So the courtesy lights stuck on all the time. I'll figure out a fix one day but it's fairly low on the priority list.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-08-2013, 06:06 PM   #45
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Dude you're late. I did this...like...a month ago. The thread should be some where above or just search door courtesy lights. I explained the whole idea of the ground controlled configuration.
Old 07-08-2013, 07:09 PM   #46
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I don't have to search, you PMed me all the info
I just didn't remember the username :happy0180:
Old 07-08-2013, 07:28 PM   #47
boredom.is.me
Custom User Title
Oh yeah I didn't realize that was you. for both of us.
Old 07-09-2013, 01:13 AM   #48
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
I just finished the passenger side. Man getting it through that loom and into the door is really annoying. Punched a hole through it and zip tied it to the loom instead. Now for the driver side.
Old 07-09-2013, 11:50 AM   #49
boredom.is.me
Custom User Title
That's exactly what I did.
http://www.ft86club.com/forums/showt...courtesy+light
Old 11-11-2014, 02:03 PM   #50
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Is it possible to get any sort of battery powered module that will only power on when the doors are opened. This would prevent having to do any wiring, etc. I'm thinking of those closet lights that will only power on the LEDs when the door is opened...?!?
Chad86 is offline   Reply With Quote
Old 11-11-2014, 03:39 PM   #51
boredom.is.me
Custom User Title
Then you have to remove the door panel just to change the batteries.
Old 11-19-2014, 03:27 PM   #52
Chad86
Chad86's Avatar
Drives: Toyota GT86
Thumbs up
Ummm...you would just potentially remove the red light cover.
Old 11-19-2014, 09:24 PM   #53
boredom.is.me
Custom User Title
The clip is on the inside of the door.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Chad86 (11-20-2014)
Old 11-20-2014, 01:12 PM   #54
Chad86
Chad86's Avatar
Drives: Toyota GT86
So it seems the only solution is to use the BRZ wiring harness, I assume...
I will definitely need to get this done, as this should have been setup from factory. The Monogram should have included this.
Old 11-20-2014, 01:16 PM   #55
boredom.is.me
Custom User Title
My DIY is right above your first post on this page.
Chad86 (11-21-2014)
Old 06-14-2015, 10:59 PM   #56
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Bumping a very old thread but I figured it out!
I didn't use the harness. I wired a power source through the OEM door tube which took me 4 hours total for both doors. Passenger door went much smoother after I figured out the driver side.
To make sure my struggles didn't go in vain, I will do a short write up on how to shove the fucking wire down that rubber tube's butthole very soon. Everything else is just plug and play.
I wired my courtesy and footwell lights to my dome so they operate as close to OEM as possible, ie when the door is open.
As you can see from the third picture, no exposed wires.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following 3 Users Say Thank You to LXXXV1 For This Useful Post:
Chad86 (06-21-2015), civicdrivr (06-15-2015), G-awesome (06-15-2015)
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
W221 S550 2 step correction CU2MIKE Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-07-2012 12:08 PM
Do you think Mazda will have to step it up now? ngabdala Other Vehicles & General Automotive Discussions 56 06-02-2012 11:47 AM
Manual tranny takes another step into oblivion madfast Other Vehicles & General Automotive Discussions 76 03-06-2012 09:40 PM
