Old 11-09-2014, 09:10 AM   #757
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good header, incorrect map, Stage 2 Equal Length Header 93 Octane Map needed
I hope you bought the overpipe too!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
akyp (11-09-2014)
Old 11-09-2014, 06:47 PM   #758
steve99
Drives: FT86
Originally Posted by akyp View Post
I have recently installed a P&L catted EL header. Running OTS Stage 1 I am getting considerable FLKC: http://www.datazap.me/u/akyp/2014110...=0&data=1-4-14
Already pulled some timing following instructions in this thread: http://www.ft86club.com/forums/showthread.php?t=61820
The only change was the header (did reset ECU prior to installation). Thoughts? Am I even using the correct map?
running a hi flow catted header their is no base map for you its going to be a trial of stage 1 and stage 2 maps , the stage 2 maps run more iming but also more fuel/richer . The richer map may stop some of the knock so worth trying stage2 map but be preared to pull up to 2 degrees from the map top end due knock. Us G series guys only get 1 map the 91 maps.
i would try the stage2 map as it also has different cam timing for header better flow, but pull some timing out of it above 5000 and prbably need a bit at 1500-3500 as well
93 fuel is way better than our 98 and even usa 91 is superor to 98, so you always have to pull timing unless you have 100 ron available.
akyp (11-09-2014)
Old 11-09-2014, 08:11 PM   #759
akyp
Drives: 2012 86
Thanks Steve. I will take a look at stage 2 maps, pull some timing and try. Despite all that FLKC the car seems to run fine.
As said we don't get Stage 2 EL for G series. Might be worth it to create my own based on a USDM one.
Yes I got the overpipe too. Both coated. Fit and finish is superb.
akyp is offline   Reply With Quote
Old 11-09-2014, 08:23 PM   #760
steve99
Drives: FT86
the only difference between 91/93 maps is about 1.5 degree more timing in base timing B map in 93 tunes above 5000 high load
Old 11-09-2014, 10:43 PM   #761
k.houan
k.houan's Avatar
Drives: BRZZZ
Could you guys take a look at my log?
3rd gear pull. OFT 2.06 E85 tune. Completely stock besides HKS drop in filter. How am I looking?
http://www.datazap.me/u/khouan/3rdge...?log=0&data=11
k.houan is offline   Reply With Quote
Old 11-10-2014, 01:22 AM   #762
VakaGT
VakaGT's Avatar
Drives: None
any chance there will be a special price on the OFT for black friday ?
VakaGT is offline   Reply With Quote
The Following User Says Thank You to VakaGT For This Useful Post:
Chad86 (11-11-2014)
Old 11-10-2014, 03:53 AM   #763
steve99
Drives: FT86
looks fine to me
read links below and you will be able to interpret the logs.
Old 11-10-2014, 08:31 PM   #764
smellslikecurry
Can someone take a look at this log for me? I just popped a CEL for P219A a d P2097
http://www.datazap.me/u/asajedeen/log1?log=0&data=1-12
smellslikecurry is offline   Reply With Quote
Old 11-10-2014, 09:19 PM   #765
steve99
Drives: FT86
intake or exhasust leak ?
what mods
what fuel
did it come up after installing mods ?
Old 11-10-2014, 09:35 PM   #766
tomaszjanczak
Drives: Silver Subaru BRZ
I had P2097 after installing OpenFlash Header. Both of those codes could be caused by a leak or faulty O2 sensor (most probable cause especially if you were just installing them in a header). I haven't solved my problem yet but I'm hoping it is a leak at one of the O2 sensors when I was screwing them in, I had some resistance but tightened with a wrench anyway. I think that might have messed up the soft aluminum threads on the sensors and there's a leak.
I bought 2 new O2 sensors, which I will be installing later in the week and I will torque them properly, unlike last time which I may have tightened them too much and deformed them that way. I also bought a O2 sensor thread chaser to make sure the threads in the header are perfect before screwing in the O2 sensors.
tomaszjanczak is offline   Reply With Quote
Old 11-11-2014, 07:48 AM   #767
smellslikecurry
what mods
what fuel
I think it may be an 02 sensor leak.
OFH, stock overpipe/stock mid pipe/buddyclub exhaust/stock airbox w/ hks filter/act clutch and flywheel/alum ds
93 octane
It started about 1000 miles after installing my OFH.
Old 11-11-2014, 08:03 AM   #768
steve99
Drives: FT86
93 octane
did you use new gaskets ?
as per other guys reply its best to run thread tap through o2 fittings to clean them up before o2 install.
Old 11-11-2014, 09:54 AM   #769
smellslikecurry
Yes I did. Thanks for all your help in this thread!
Going to try that out. I was just curious if the car was safe to drive for now. It's the only car I have access to for the week.
Old 11-11-2014, 01:43 PM   #770
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Arrow
I second this!
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
VakaGT (11-11-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
