Old 11-08-2014, 02:38 PM   #71
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by stonenewt View Post
Am I being stupid here but I can't see a difference between the moderate overlap? However they introduce a small overlap criteria which the FR-S shows adequate in
Right, something changed but don't know if it's just the term for the test or more likely the actual test criteria.
torqdork is offline   Reply With Quote
Old 11-08-2014, 02:53 PM   #72
The test criteria changes almost as often as the weather. These tests are not just based on U.S. requirements but (usually) on the highest standard used by any country that imports the vehicle.
So if last years test required an impact speed of 60MPH +/- 1MPH and Lower Slavovia decides this year they want 60MPH +/- .8MPH then the whole test numbers can change.
Since these cars are sold in many countries it is not strange the criteria changes.
Overly simplified I know but you get what I mean?
torqdork (11-08-2014)
Old 11-08-2014, 04:08 PM   #73
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by sechs View Post
Hope you're lucky enough to never have to deal with the after math of other drivers doing something completely unexpected.
Yes, I hope none of us will have to deal with someone unexpectedly making an illegal turn in front of us.
The Following User Says Thank You to extrashaky For This Useful Post:
NWFRS (11-08-2014)
Old 11-08-2014, 06:33 PM   #74
Or be making a turn when somebody blows through a light!
sechs (11-08-2014)
Old 11-08-2014, 06:46 PM   #75
sechs
Drives: 2013 FRS
It's mind blowing how you and that other guy are so convinced I'm at fault based on your assumptions without even giving the benefit of doubt.
Accusing myself and others of wrong doing and being bad drivers without evidence is incredibly arrogant and self righteous.
sechs is offline   Reply With Quote
Old 11-08-2014, 07:00 PM   #76
Welcome to the forum! Arrogance and self rightness rule here.
Unfortunately the way you presented the evidence it does appear that you changed your story so they have a point.
But... at the same time, after the first person made the statement the rest of the following comments are not really required and just become a form of flaming.
Mind you I can not plead innocence myself as there are some topics that get under my skin and I comment when there really is nothing to be gained but starting an argument.
Best bet (as hard as it is to do) is to ignore the posts that bother you as the more you fight back the worse it can get.
chas3wba0 (11-08-2014), sechs (11-08-2014)
Old 11-08-2014, 07:14 PM   #77
G-awesome
Drives: 2015 Firestorm Scion FRS
too late for my and my former brz. :/ :P
G-awesome is offline   Reply With Quote
Old 11-08-2014, 07:16 PM   #78
They make more every day (for now at any rate) and only one of you.
Sure if you are found at fault it will cost you but you can get a new one.
Easy to say when it isn't my car or cash I guess!
Old 11-08-2014, 07:36 PM   #79
Jegan_V
Drives: 2023 Subaru BRZ
Yeah, was making the left on to the ramp leading to hwy 7.
Ahh...I can see that there's a possible issue as those coming the opposite direction can also go up the ramp or decide to cross the intersection. Unfortunately its unlikely you'll be able to prove your case against the charge, your best hope is plead for forgiveness with the prosecutor, its worth a shot. Worse case scenario there's no change and the charge stands, best case scenario the charge is tossed out. No point hiring a traffic lawyer as you're without witnesses(no surprise in Richmond Hill, I know from experience). When its your word versus the cop, you're destined to lose.
Had you said Yonge, you can definitively fight off the ticket and possibly reverse the outcome due to the way the lights are set up.
Jegan_V is offline   Reply With Quote
The Following User Says Thank You to Jegan_V For This Useful Post:
sechs (11-08-2014)
Old 11-09-2014, 10:13 AM   #80
RFB
RFB's Avatar
Drives: FRS
Not applicable in Canadian jurisprudence unless the cop witnessed the accident, and was able to clarify for the judge which driver was the farthest from the intersection when the A.T.S changed to amber etc.
If it was travelling at the speed limit of about 45 feet per second, and was about 150 ft. away from the intersection when changed to amber, the car turning left across its path would not be convicted, the other car would - D.A.T.S. amber.
These classic collisions were not liked by our J.P.'s. They often resulted in both drivers charged and J.P.'s hated that, so they dismissed both charges.
Anyway - all one has to do is to introduce reasonable doubt with your version and the other drivers versions contradicting (that is not evidence with 2 good liars).
Your defence is that the other driver was far enough away to stop safely but ran the light instead.
Due to the nature of the nature of the collision, it is worthwhile fighting in traffic court and besides, certain sections of the HTA are designed for certain situations, and since the GTA traffic cops were abolished (except symbolically) cops OFTEN lay the wrong charge and the case gets tossed.
CERBERUS
RFB is offline   Reply With Quote
The Following 2 Users Say Thank You to RFB For This Useful Post:
sechs (11-09-2014), Tcoat (11-09-2014)
Old 11-09-2014, 03:38 PM   #81
KNS
Drives: BMW and Porsche at the moment
The above mentioned ring-shaped B pillar in the extrication article... Pretty cool.
Does anyone know if that was incorporated into the FRS/BRZ? Not sure when the article was written. Didn't Toyota do more of the body design on the car?
KNS is offline   Reply With Quote
Old 11-09-2014, 04:04 PM   #82
May not be exactly like that but will be very similar.
Old 11-09-2014, 08:02 PM   #83
Jegan_V
CERBERUS
If that's the case, that's really good news for the OP. GTA cops have gotten a lot better at ensuring their tickets don't get tossed out which is why I assumed they wouldn't do such things unless they believed that to be the case. Good to know.
Old 11-09-2014, 08:13 PM   #84
DarkSunrise
DarkSunrise's Avatar
Yeah the BRZ/FR-S have a next-generation ring of safety.
Next-generation Ring-Shaped Reinforcement Frame
The pursuit of high degrees of safety and sports driving performance has led to the next generation of this class-leading design that links together the roof, door beams, side pillars and floor. More robust than ever, the design now incorporates 53% high-tensile strength steel for superior crashworthiness without adding unnecessary weight and creates a 360-degree barrier of protection by diverting impact energy away from the cabin.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Tcoat (11-09-2014)
accident, crashed, insurance
Did a full write up on our new Audi RS7. dem00n Other Vehicles & General Automotive Discussions 7 04-24-2014 10:46 AM
My baby is a write off T_T Wilso Scion FR-S / Toyota 86 GT86 General Forum 36 02-13-2014 08:26 PM
Just a preview, full write up tomorrow. vividracing Forced Induction 41 12-18-2013 05:23 PM
[GTA] Dealerships reviews. Please write your own experience. chenshuo CANADA 44 11-16-2013 08:15 PM
Herald Wheels BRZ Write Up ngabdala BRZ First-Gen (2012+) — General Topics 0 05-23-2012 12:43 PM
