#15 |
I wouldn't rule out the brakes or transmission, both are still turning when the car is rolling. In neutral, the only part of the transmission that slows down is the input shaft/intermediate shaft, but if the rear wheels are moving, so are all the gears.
If it's a dry scraping/rubbing sort of chuffing sound, something might be rubbing a tire or rotor, or the drive shaft. Approx how many "chuffs" per second at 20mph? It might be as simple as a stick or brush caught under the car somewhere... |
#16 |
#17 | |
why do you own this car?
#18 |
Drives: 2013 Subaru Brz WRB Limited
Can you record it somehow? I'm experiencing, what seems like the same problem.
#19 |
Drives: FR-S MT
Okay, problem solved! It was the tires -
I changed over to winter tires and the sound is GONE! The OEM tires are fairly worn, so I'll just replace them in the Spring. |
#20 |
Could you see any scuff marks or debris that might have been causing the sound? It's a little weird that the tire itself would make noise other than tread/road noise.
#21 |
Drives: FR-S MT
No marks or debris. It may be something internal in the tire. I also didn't see any marks from misalignment or over/under inflation.
| 4th gear grind | aaguirre123 | Engine, Exhaust, Transmission | 8 | 08-03-2015 04:58 PM |
| 2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 04:02 PM |
| 4th gear grind | Moetivegt86 | Issues | Warranty | Recalls / TSB | 10 | 03-07-2014 11:50 AM |
| Very annoying rattle/noise in the back of my BRZ. Any help? | MrGamer | BRZ First-Gen (2012+) — General Topics | 6 | 08-02-2013 09:32 AM |
| weird plastic squeaking noise (back seats) | whyreeto | AUSTRALIA | 5 | 09-17-2012 01:34 AM |
