Old 11-01-2014, 06:13 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
Mike, I had a good tune and I bet you did too but you guys still managed to destroy the OEM cats right?
Both of the tuners I spoke with recommended a freer flowing exhaust to eliminate back pressure and added heat.. Freeman was using another tune and his cats were also destroyed..
I'm pretty sure majority of the JR kits also don't see as many track days, I think the question is : " Is it worth to take risks associated with running OEM cats and say buh bye to your motor ?" When things go bad,
We destroyed the OEM cats on an OEM engine with an OEM tune.
We have more track time on our JRSC with CARB tune engine than we did on our first three NA engines combined, and have zero cat problems.
It's all in the tune.
Old 11-01-2014, 06:15 PM   #30
CSG Mike
CSG Mike's Avatar
Lack of 5-6 hp is not the problem with the OEM header (cats specifically) and the front pipe, the problem is the restrictive cats that may cause safety issues such as backfire or melted cats that might sucked in to the engine, I think you should be fine with the OEM catback but I wouldn't use the OEM header and front pipe for sure..
Check my build thread and FI section
If you're got backfires in the cat, or cat pieces being sucked into the engine, you have much, much bigger problems to worry about.
Old 11-02-2014, 12:42 AM   #31
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I meant to say back pressure, and there is a good chance your cat piece may be sucked in to the engine at cold start and yes you may have a bigger problems at that point
glamcem is offline   Reply With Quote
Old 11-02-2014, 12:46 AM   #32
glamcem
glamcem's Avatar
If you were able to destroy the OEM cats with stock power levels, it shouldn't be hard to destroy them with 50%-60% more power.. I don't think it's just tune because you make more power and ultimately generate more heat, EGT s ..
Old 11-02-2014, 01:00 AM   #33
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Not me. I'm on the canned kraftwerks tune with a castless header and catted front pipe.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Freeman is offline   Reply With Quote
Old 11-02-2014, 01:07 AM   #34
glamcem
glamcem's Avatar
Ugh, of course not I was thinking @Model Citizen and his recent experience with the OEM header, my bad :/
The Following 2 Users Say Thank You to glamcem For This Useful Post:
Freeman (11-02-2014), Model Citizen (11-02-2014)
Old 11-02-2014, 01:15 AM   #35
CSG Mike
CSG Mike's Avatar
That's not possible unless you or your tuner REALLY tweaked the startup cam timing and are sucking in exhaust during the intake stroke.
Old 11-02-2014, 01:16 AM   #36
CSG Mike
CSG Mike's Avatar
Exhaust temp has little correlation with EGTs. It's in the tune, and partly injectors. Spray pattern, stratification, and flame front temperature and speed are going to be the determining factors in EGTs.
Pulling timing or running abnormally rich will also raise EGTs, but again, tuning issues.
The reason the OEM cats were destroyed was the OEM tune was pulling timing like crazy for whatever reason, resulting in an ultra high EGT. Again, tune. No variables in a stock engine.
Old 11-02-2014, 01:20 AM   #37
jdmblood
jdmblood's Avatar
Drives: white subaru brz
is op trolling? he hasn't even replied to peoples responses
jdmblood is offline   Reply With Quote
The Following User Says Thank You to jdmblood For This Useful Post:
Old 11-02-2014, 01:01 AM   #38
Model Citizen
Lacking brains
Drives: frz
On my end i consider only having killed a header cat this season being boosted and the abuse the car has seen as a win.
Hell even the clutch survived.
Next year i'm sure i won't be so lucky, but whatever, pay to play.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following 2 Users Say Thank You to Model Citizen For This Useful Post:
Freeman (11-02-2014), glamcem (11-02-2014)
Old 11-02-2014, 02:13 AM   #39
glamcem
glamcem's Avatar
Mike I am surprised you never heard that before because at least 3 other people (not tuners, mechanics ) mentioned this to me and one of the guy's friend lost his engine because of that ..and that's the same reason why many people wash and/or vacuum their manifolds or other exhaust pieces after they get rid of the cats
here's what a quick google search found me
[ame="http://youtu.be/TVpS_ENBraQ"]http://youtu.be/TVpS_ENBraQ[/ame]
Old 11-02-2014, 02:24 AM   #40
glamcem
glamcem's Avatar
how is that so? EGT stands for "Exhaust gas temperature"
at the end of the day, more power, in our case substantially more power (about 50-65% more power than stock) means more heat generated in the engine and the rest of the system (exhaust manifold), no matter what ..
Old 11-02-2014, 02:31 AM   #41
CSG Mike
CSG Mike's Avatar
Brain fart.
It should read power output has little correlation with EGTs.
Old 11-02-2014, 02:34 AM   #42
CSG Mike
CSG Mike's Avatar
I find it highly unlikely that a cat piece can be sucked in, through multiple bends including a 90 degree bend, upward, through the exhaust valve.
I'm gonna say slim to none, until someone actually has a FA20 fail in that manner.
Which Supercharger Kit? 914_WHITE_FRS Engine, Exhaust, Transmission 2 10-30-2014 09:25 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
HKS Supercharger Kit for FR-S & BRZ. 1660 Engine, Exhaust, Transmission 6 11-27-2012 06:11 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS Supercharger Style Forced Induction 75 08-06-2012 02:25 AM
