Old 10-31-2014, 08:13 PM   #15
Frs123
Frs123's Avatar
Drives: Raven
Originally Posted by racerx1715 View Post
No problem, When we build the control arms we have the rod end threaded out. When installing the arm the rod end will be threaded into the weld insert further providing negative camber. Make sense??
So stock length is maxed negetive camber?
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 10-31-2014, 09:25 PM   #16
wparsons
wparsons's Avatar
No.
Shortening the arm (threading it in further) will add negative camber. Lengthening the arm will add positive camber.
IIRC, the adjustment range goes both positive and negative on these arms so you can remove or add as desired.
flickr
Jeff@Racer X Fab (11-01-2014)
Old 11-01-2014, 01:57 PM   #17
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by wparsons View Post
No.
Yes, our upper control arms can provide positive or negative camber.
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
wparsons (11-01-2014)
Old 04-01-2015, 04:32 PM   #18
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
HELP! Did the ball joint go all the way in?? Or does it only sit in like 3/4 way in?!? Bc I'm not 100% sure and I'm worried that I'll have a ball joint falling out when im driving
Kosmos is offline   Reply With Quote
Old 04-01-2015, 09:09 PM   #19
Jeff@Racer X Fab
The rod end stud should sit almost flush with the top of the knuckle, be sure that the pinch bolt engages into the stud and you should be good to go.
If you have any more questions feel free to email: tech@racerxfabrication.com
Old 04-01-2015, 09:49 PM   #20
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Like in this picture correct?
Old 04-02-2015, 01:44 PM   #21
Jeff@Racer X Fab
Attachment 105996
Yes.
Kosmos (04-02-2015)
Old 04-02-2015, 01:48 PM   #22
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Yes.
Awesome! Then I am done. Thanks a bunch and I hope to get some more suspension from you guys soon!
Old 04-10-2015, 11:11 PM   #23
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Is there a install on the front lcas? The chromoly anodized 700$ ones lol
Old 04-11-2015, 01:21 PM   #24
xwd
I finally got around to installing my rear UCAs (version 1) a few weeks ago when I put my coilovers back on. Easy install really. If you hammer a small wedge into the ball joint capture bolt area the ball joint goes in and out very easily. Only issue I had was the stock bolt stripped when loosening it on one side. So I had to make a run for another bolt with the same shank area.
The spot welds on the ABS bracket on mine were weak and I ended up snapping one of them off without much force at all. Had to be careful on the others.
We have a very good alignment shop here who had no issues with popping the ball joint out, but they were kind of surprised as it is the first time they have seen UCAs on a twin or Subaru for that matter, with the WRX/STI over the last few years using the same suspension. They still just charged me $99 for a custom alignment with me sitting in the car, great shop. Gran Turismo East in Atlanta. I was able to get right at -2 with them turned in once from the shipping length and the car dropped about an inch.
The Following User Says Thank You to xwd For This Useful Post:
Jeff@Racer X Fab (04-11-2015)
Old 06-08-2015, 11:01 AM   #25
philooo
Drives: 13' Scion FRS Track car
quick questions
with the Upper Control Arm, if I drop the car let's say 2 or 3 inches.
and I play with the UCA to adjust camber, to agressive track setting.
1/ Do I still need something to correct the TOE ?
2/ What would be the point to also have a Lower Control Arm then ?
philooo is offline   Reply With Quote
Old 06-15-2015, 07:48 PM   #26
Jeff@Racer X Fab
Originally Posted by philooo View Post
quick questions
Depending on how aggressive you are with the camber you may still need to adjust toe. A few guys like to change their track width which would still require the lower control arms.
Hope that helps.
Old 04-24-2016, 01:29 PM   #27
LittleBlueGT
Drives: 2013 STI
Any updates on this?
How have they faired, do they make noise now two yrs later?
Had to replace a rod end yet?
How many miles, what conditions?
Thanks
LittleBlueGT is offline   Reply With Quote
Old 04-25-2016, 01:15 PM   #28
mkivsoopra
Thanks
I've had these since Sept 2013. It's been rock solid, no noises, no issues. 30+ track days and about 25k miles.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Jeff@Racer X Fab (04-28-2016)
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 11:42 AM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 09:01 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
Upper control arms for bulk camber JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 06-17-2013 11:40 PM
