#15 | |
Drives: Raven
So stock length is maxed negetive camber? Sent from my iPhone using Tapatalk
Instagram: erik239
#16 | |
Shortening the arm (threading it in further) will add negative camber. Lengthening the arm will add positive camber. IIRC, the adjustment range goes both positive and negative on these arms so you can remove or add as desired.
| The Following User Says Thank You to wparsons For This Useful Post: | Jeff@Racer X Fab (11-01-2014) |
#17 |
Drives: Subaru BRZ, Toyota MR2 Turbo
Yes, our upper control arms can provide positive or negative camber.
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | wparsons (11-01-2014) |
#18 |
Kosmos
Drives: Scion FR-S
HELP! Did the ball joint go all the way in?? Or does it only sit in like 3/4 way in?!? Bc I'm not 100% sure and I'm worried that I'll have a ball joint falling out when im driving
#19 | |
If you have any more questions feel free to email: tech@racerxfabrication.com |
#20 | |
Kosmos
Drives: Scion FR-S
Like in this picture correct? |
#21 | |
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | Kosmos (04-02-2015) |
#22 |
Kosmos
Drives: Scion FR-S
#23 |
Kosmos
Drives: Scion FR-S
Is there a install on the front lcas? The chromoly anodized 700$ ones lol
#24 |
I finally got around to installing my rear UCAs (version 1) a few weeks ago when I put my coilovers back on. Easy install really. If you hammer a small wedge into the ball joint capture bolt area the ball joint goes in and out very easily. Only issue I had was the stock bolt stripped when loosening it on one side. So I had to make a run for another bolt with the same shank area.
The spot welds on the ABS bracket on mine were weak and I ended up snapping one of them off without much force at all. Had to be careful on the others. We have a very good alignment shop here who had no issues with popping the ball joint out, but they were kind of surprised as it is the first time they have seen UCAs on a twin or Subaru for that matter, with the WRX/STI over the last few years using the same suspension. They still just charged me $99 for a custom alignment with me sitting in the car, great shop. Gran Turismo East in Atlanta. I was able to get right at -2 with them turned in once from the shipping length and the car dropped about an inch. |
| The Following User Says Thank You to xwd For This Useful Post: | Jeff@Racer X Fab (04-11-2015) |
#25 |
Drives: 13' Scion FRS Track car
quick questions
with the Upper Control Arm, if I drop the car let's say 2 or 3 inches. and I play with the UCA to adjust camber, to agressive track setting. 1/ Do I still need something to correct the TOE ? 2/ What would be the point to also have a Lower Control Arm then ?
2013 Scion Frs Track Car - Sold.
#26 | |
Hope that helps. |
#27 |
Drives: 2013 STI
Any updates on this?
How have they faired, do they make noise now two yrs later? Had to replace a rod end yet? How many miles, what conditions? Thanks |
#28 |
I've had these since Sept 2013. It's been rock solid, no noises, no issues. 30+ track days and about 25k miles.
| The Following User Says Thank You to mkivsoopra For This Useful Post: | Jeff@Racer X Fab (04-28-2016) |
| Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
| Adjustable rear upper control arms??? | Supermassive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 09-29-2013 09:17 AM |
| Oem rear upper control arms | Jhon19lopez | Brakes, Suspension, Chassis | 1 | 08-25-2013 09:01 PM |
| GTSPEC rear control arms & toe arms review | Jesse | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-23-2013 03:20 PM |
| Upper control arms for bulk camber | JordanWho | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 06-17-2013 11:40 PM |
