Old 10-17-2014, 07:26 AM   #43
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
https://m.facebook.com/story.php?sto...62711873758009
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 10-17-2014, 09:27 PM   #44
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
It's in the 6's now
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-31-2014, 03:37 PM   #45
slicktop
Happy Halloween. Day 1.
Old 10-31-2014, 07:06 PM   #46
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
It is time???
Drift&Drag is offline   Reply With Quote
Old 11-01-2014, 12:44 AM   #47
slicktop
Originally Posted by Drift&Drag View Post
It is time???
It's time, no shenanigans. Well, not right now
-slicktop
2013 Scion FRS
The Following User Says Thank You to slicktop For This Useful Post:
Drift&Drag (11-01-2014)
Old 11-01-2014, 05:25 AM   #48
the puppet master
2013 Whiteout
the puppet master's Avatar
Drives: 2013 whiteout
there was a slicktop on ZY, are you the same slicktop?
In for your build.
PARTS FOR SALE: Bride Zeta x 2 (1 sold). Defi Link controller, oil temp, oil pressure, water temp, Whiteline front and rear sway bars, Cusco spin turn knob. Beatrush shift knob(sold). ZE40 18x10J+40 square (sold). ATI triple meter dash pod 60mm,
the puppet master is offline   Reply With Quote
Old 11-01-2014, 10:27 AM   #49
slicktop
In for your build.
possibly, its an alias from the slicktop 300ZX TT I built.
Old 11-02-2014, 03:39 AM   #50
slicktop
EDIT: Day 2
So, got the motor pulled a few hours ago with two buddies helping out.
We were cleaning up the bay and realized after 15min there wasn't much to be done... so... yeah.
Old 11-02-2014, 04:32 AM   #51
slicktop
These pics aren't final placement, but I had to sit back and take in how much room there actually was. I put the alternator and A/C on the motor and there's still plenty of room for everything.
The Following 13 Users Say Thank You to slicktop For This Useful Post:
akahenry (11-02-2014), alpine (11-02-2014), brianhj (11-02-2014), Carlitoz3 (12-06-2014), Creole (11-02-2014), Guff (11-02-2014), Josue Cafe FR-S (02-19-2016), Lonewolf (11-02-2014), OmarGC (11-02-2014), rusty959 (11-02-2014), Ryaquinn (11-02-2014), SnapOv3st3r (07-02-2015), the puppet master (11-02-2014)
Old 11-02-2014, 12:46 PM   #52
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Awesome!!! Glad to see you drop it in! Are you going to leave AC on your car or are you going to delete it?
Old 11-02-2014, 12:59 PM   #53
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Sweet! This is my plan as well. Look forward to the end result!
AVodka14 is offline   Reply With Quote
Old 11-02-2014, 03:40 PM   #54
slicktop
The car will be a DD with full accessories since my wife will be driving it as well. Should be a very fun DD
BboyKidKoda (06-17-2015)
Old 11-02-2014, 07:16 PM   #55
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
isn't it amazing how well the JZ tucks in there on the XM mounts? have you had to drill out the trans u-brace inside the tunnel yet, or did you not have a trans installed when you test-fitted the motor?
also, mind snapping a pic of how much room there is for a downpipe? I'm curious for when I go big single.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 11-02-2014, 08:25 PM   #56
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Oh yeah it will! Not to mention it will probably surprise a lot of people too! lol
For the V160/V161 you do have to cut the brace off completely. If your R154 is wider than the stock trans, then it will need to be removed as well.
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 09:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 08:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
