#15 | ||
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Jackson Racing Supercharger System - Factory Tuned System - Automatic Transmission - BRZ / FRS - CARB Approved EO# D-700-2 Quote:
#16 | |
Drives: 2022 BRZ Limited
If it's for street only, why not trying the ESC (electric superchargers), they are great for the money and can be even used for some light track duty ![]() good luck with your project
#17 | |
Off Topic
#18 |
Drives: WRB Limited BRZ
Is rotrex a new type of supercharger system? I thought there was only a Rooted, Centrifugal and Twin screws.
#19 |
Drives: UK GT86
Rotrex is a centrifugal system. Its just the manufacturer, like Sprintex, Eaton etc.
.: Stealth 86 :.
#20 | |
Y u do dis?
Just tell him to go buy a Mustang GT and GTFO this forum, OP is a Troll.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#21 |
No rice, no life
Drives: 2013 Asphalt FR-S
@914_WHITE_FRS with the amount of people saying Jackson Racing, Kraftwerks, and Rotrex in this thread, you should take that as a hint
#22 | |
Drives: 2013 BRZ limited WRB
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
#23 |
It's a Centrifugal type supercharger, that uses a planetary gear drive. It allows for higher impeller speeds, letting the supercharger's efficiency get into turbo range.
#24 | |
#25 |
Drives: 13' Subaru BRZ Limited SWP 6MT
There's a Sticky thread in this Technical Topics/Forced Induction section, at the top.
Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 http://www.ft86club.com/forums/showthread.php?t=55705 Example from thread: HP&TQ Curves of all Superchargers Anytime someone asks "which supercharger is right for me?" in the forums, they are told "lol use search noob." If you search and find the power output of the different options, you get this jumbled mess.
#26 |
I've seen several posts where guys were making pretty much same power, and in some cases more whp with stock header vs catless header on SC setups.
Doesn't make sense why, but there are Dyno graphs to prove it. Point being might not be much value in adding aftermarket header to SC setup. I'd put money towards quality overpipe-back exhaust with SC.
#27 | |
Check my build thread and FI section
| The Following User Says Thank You to glamcem For This Useful Post: | kbogarto (11-02-2014) |
#28 | |
Both of the tuners I spoke with recommended a freer flowing exhaust to eliminate back pressure and added heat.. Freeman was using another tune and his cats were also destroyed.. I'm pretty sure majority of the JR kits also don't see as many track days, I think the question is : " Is it worth to take risks associated with running OEM cats and say buh bye to your motor ?" When things go bad,
| Which Supercharger Kit? | 914_WHITE_FRS | Engine, Exhaust, Transmission | 2 | 10-30-2014 09:25 PM |
| ETA on TRD Supercharger? | frsinpa | Forced Induction | 18 | 01-11-2013 10:09 AM |
| HKS Supercharger Kit for FR-S & BRZ. | 1660 | Engine, Exhaust, Transmission | 6 | 11-27-2012 06:11 AM |
| supercharger? but by who? | carbonBLUE | Forced Induction | 14 | 11-02-2012 10:10 PM |
| HKS Supercharger | Style | Forced Induction | 75 | 08-06-2012 02:25 AM |
