Old 10-30-2014, 02:12 PM   #71
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Ecutek license...
On your website, the option for an Ecutek pro license is available, if you buy the ecutek cable, does it come with the standard license for initial flash?
Also, if you elect to not initially get the E85 upgrade can you just pay the $200 later to get it?
Jaden
Jaden is offline   Reply With Quote
Old 10-30-2014, 03:20 PM   #72
nostromo
nostromo's Avatar
I also have a JDL twin scroll kit. What else was installed on the car, would like to get a similar tune too.
nostromo is offline   Reply With Quote
Old 10-30-2014, 07:46 PM   #73
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Jaden
Hi Jaden,
The cable kit and license are actually completely separate items and need to be ordered individually. One does not include the other, unfortunately.
We always offer the option to add the E85 map later for just the $200 upgrade cost, yes.
Sincerely,
Zach
Old 10-30-2014, 07:48 PM   #74
DeliciousTuning
Hi Nostromo,
That vehicle is actually just running our standard Flash N Go tune, nothing different about it. You can view that tune here: http://delicioustuning.com/flash_and_go
Sincerely,
Zach
Old 10-30-2014, 07:49 PM   #75
DeliciousTuning
Originally Posted by Fizz View Post
@DeliciousTuning Will the electronic boost controller be of any advantage or worthwhile addition for someone who plans to just keep boost levels at wastegate pressure (referring to the AVO Stg1 kit)? Does it help control boost better at those levels, or is it only required when increasing boost above wastegate pressure?
Hey Fizz,
The EBC can still help out in the overall responsiveness of the system and it's ability to regulate boost more smoothly, although it certainly isn't required when running at wastegate pressure.
Sincerely,
Zach
Old 10-31-2014, 01:34 AM   #76
Shit Luck
Drives: red frs
Just flashed my ECU...
Now it runs like shit, and has check engine lights and traction lights among others.
Shit Luck is offline   Reply With Quote
Old 10-31-2014, 01:39 AM   #77
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Did you let them know what you're running for a map sensor and injectors ?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 10-31-2014, 01:52 AM   #78
Shit Luck
Drives: red frs
Yeah
Old 10-31-2014, 02:38 AM   #79
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Have you got the CEL codes?
Fizz is offline   Reply With Quote
Old 10-31-2014, 02:55 AM   #80
Shit Luck
Drives: red frs
Says no dtc found
Old 10-31-2014, 02:57 AM   #81
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
The main advantage of ebc is faster spool. Your car will feel much faster even with the same maximum pressure. And when you decide you want some more, it will be easy to do.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
The Following User Says Thank You to maxjedi For This Useful Post:
Fizz (10-31-2014)
Old 10-31-2014, 04:01 AM   #82
Shit Luck
Drives: red frs
I have an injector circuit open code on cylinder 4 now
Swapped injector pigtails around and seem to have fixed it,
The Following User Says Thank You to Shit Luck For This Useful Post:
DeliciousTuning (11-13-2014)
Old 11-04-2014, 12:27 PM   #83
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
How close are you to releasing the new revision?
Will flex fuel on kraftwerks require upgraded injectors?
post_break is offline   Reply With Quote
Old 11-05-2014, 01:05 AM   #84
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@DeliciousTuning can the F&G tune be used with the Sprintex Intercooled kit? There doesn't appear to be an option for this kit in the drop down menu where you select your 'Forced Induction Package'.
Or do you only offer the Innovate Stage 2 tune for the Sprintex kits?
Apart from the F&G being SD based, is one better than the other? Which would be better suited if my priority is low speed drivability (i get stuck in heavy traffic often) and improving low-mid range power/torque?
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 02:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 12:36 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 01:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 01:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 12:36 PM
