Old 10-29-2014, 06:22 AM   #15
diodelphi
diodelphi's Avatar
Drives: 86
is there any book or pdf on web for learning ecutek tuning ?
it seems before that i need a reference for learning tuning basics.
I think dummy people like me will like to learn more about tuning brz with ecutek.
diodelphi is offline   Reply With Quote
Old 04-27-2016, 07:54 PM   #16
BQ89
Drives: 2013 FRS
hey there. I was reading and I saw that you had a problem with cluster communication and I currently having the same problem I keep getting the code uo155 lost communication with the cluster . Could you tell me what did you do the fix it ?
BQ89 is offline   Reply With Quote
Old 04-27-2016, 08:08 PM   #17
steve99
Drives: FT86
does the dash cluster still read correctly ?
often this is caused by interrupting the can buss communications between ecu and dash by plugging\unplugging devices into obd port while car is switched on, best to plug\unplug while ignition off.
if its permanent it can be caused by loading an incompatable rom into ecu
i know this happends if you load a D00G rom in an A01G or earlier car.
Self tune, or tuner? diss7 Software Tuning 55 02-17-2014 03:14 AM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 01:07 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 03:52 PM
A/T, AVO panel filter, Borla UEL, Stock cat-back, Drift Office dyno tune Turbo Den Engine, Exhaust, Transmission 2 09-20-2013 03:01 AM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
