Old 09-16-2014, 10:45 AM   #15
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Originally Posted by nickmerronesucks View Post
im running adaptors, so far 2k and no issues on them the ISC adaptors.
Problem with adapters is finding super-high offset wheels, unless you like your wheels sticking out past your fenders, have a wide body, or insane camber.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-16-2014, 08:08 PM   #16
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
yep but good news is high offset rare/cool jdm wheels are alot cheaper then the fanboy "stance" taxed wheels cause of lower offset.. haha
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
wparsons (10-28-2014)
Old 09-17-2014, 01:04 AM   #17
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
Originally Posted by 08stiguy View Post
Any word from megan about the conversions being re-manufactured? I wreaked my 08 sti a few weeks ago and will be swapping some stuff out. Lots of salvageable parts.
I didn't bother to follow up since I don't have an 86 yet but the sales guy I spoke with said late August back when I called before.
Redstar is offline   Reply With Quote
Old 10-28-2014, 02:59 AM   #18
slava
slava's Avatar
Drives: brZed
Originally Posted by ML View Post
I thought i heard you could swap a 08+ STi hub, they have 5x114
Planning on doing the 08-12 Brembo calipers front and rear over the winter. Do 08+ 5x114 STI hubs also swap right over, front and rear? Any info is appreciated. And yes I realize I could just get 5x100 wheels, and trying to stay away from the Megan hubs. Thanks.
slava is offline   Reply With Quote
Old 10-28-2014, 09:47 AM   #19
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
if the front hubs bolt in you'll have provisions for front axles sooooo....
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
slava (10-28-2014)
Old 10-28-2014, 09:52 AM   #20
ML
ML's Avatar
Drives: 13 White MT FR-S
I'm 95% sure that the rears swap directly over. And aren't our front and rear hubs identical minus splines for axles and what not? If they are then you are a go.
The Following User Says Thank You to ML For This Useful Post:
slava (10-28-2014)
Old 10-28-2014, 11:06 AM   #21
SomeoneWhoIsntMe
I don't have the time to do it right now, but someone can look up the specs on them in Timken's bearing application guide.
also, we need to double check that those style of bearings don't need an axle bolted into them to hold together before anyone tries to run them
slava (10-28-2014)
Old 10-28-2014, 11:12 AM   #22
wparsons
wparsons's Avatar
This! That's the main difference (besides axle splines) between our fronts and AWD fronts.
flickr
Old 11-21-2014, 03:53 PM   #23
slava
slava's Avatar
Drives: brZed
So i just ordered rears, wondering if I should risk ordering fronts too...
Old 12-03-2014, 12:45 AM   #24
PhoKingCool
PhoKingCool's Avatar
The rears are easy to get. I am more interested in seeing a solution for the front. As far as Megan, they still do not have an ETA nor do they sound interested in following up with a replacement conversion set.
PhoKingCool is offline   Reply With Quote
Old 12-28-2014, 07:05 PM   #25
slava
slava's Avatar
Drives: brZed
Just an FYI to everyone the front 08+ STI Hubs DO NOT FIT frs/brz. Not even close. Still no oem replacement to 5x114 conversion...
5x100 to 5x114.3 hub conversion Kai Uhl Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2019 08:57 AM
5x114.3 Hub Conversion moomoopanda Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-07-2015 06:28 AM
5x114 Stud Conversion GreatWhite Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-02-2013 08:55 PM
5x114 hub conversion FRSGIRL❤ Brakes, Suspension, Chassis 1 07-06-2013 02:24 PM
5x114.3 hub conversion mclevin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-03-2012 09:53 AM
