Old 10-26-2014, 08:59 AM   #43
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I connected to my car as suggested in other posts. Blue goes from the valenti blue taillight wire, to the light greyish blue wire in the valenti reverse light harness. And the red from the valenti tail light to the thin red wire on the valenti reverse light. Then just plug the plug in.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 10-26-2014, 09:03 AM   #44
blackfireball5
So essentially, the blue taillight wire from the valenti tail light harness will makes its way to the V bar and ground, and the red from the valenti tail light harness will make its way to the left most solder point on the triangle with a new wire bridging the left most and middle solder location.
Wheelwell Profile
Old 10-26-2014, 04:48 PM   #45
ANTLAY
Drives: 2013 FR-S in Whiteout
Well,I think I've officially killed mine,after trying 2-3 different ways the only think I can get to work now is the reverse lights..
ANTLAY is offline   Reply With Quote
Old 10-26-2014, 04:57 PM   #46
blackfireball5
Check and make sure your quick connects are squeezed down hard enough. That happened to me too.
Wheelwell Profile
Old 10-26-2014, 04:58 PM   #47
blackfireball5
Post pictures of yours so i can help.
Wheelwell Profile
Old 10-26-2014, 05:06 PM   #48
ANTLAY
Its back together for now,it is wired exactly like yours the first time I hooked it to car only the triangle would light under running lights and then itd go off when brake was pressed so I tried all over again and again.. Lol sucks,the only thing I can think of is my lack of soldering skills, even though the connections feel sturdy. And BTW I've redone the quick connects twice with same results
Old 10-26-2014, 05:07 PM   #49
ANTLAY
This was the first thing I've ever tried soldering.
Old 10-26-2014, 05:10 PM   #50
blackfireball5
I'd say open it up and take pics. Can you explain what color from the taillights goes to what places inside the reverse light?
Wheelwell Profile
Old 10-26-2014, 06:03 PM   #51
ANTLAY
As far as inside the light? The orange is wired straight to blue, um extra wire added from left post to center post. Can't remember all right off but i double and triple checked your pics as I went along
Old 10-26-2014, 06:04 PM   #52
ANTLAY
I've got it on the car right now.. I have to work tonight so I just temp installed it
Old 10-26-2014, 06:43 PM   #53
blackfireball5
Gotcha. What you want to check is whether the red goes to the light blue or if the orange goes to light blue. When you get pics i can tell you what is wrong. Get pics of everything. I bet you didn't fry it
Wheelwell Profile
Old 10-26-2014, 06:54 PM   #54
ANTLAY
Any ideas what would make only the triangle be on with running lights instead of the v?
Old 10-26-2014, 06:55 PM   #55
blackfireball5
If you have the wrong wire running to the triangle vs V.
Wheelwell Profile
Old 10-26-2014, 06:55 PM   #56
ANTLAY
Originally Posted by blackfireball5 View Post
Gotcha. What you want to check is whether the red goes to the light blue or if the red goes to light blue. When you get pics i can tell you what is wrong. Get pics of everything. I bet you didn't fry it
Lol,huh? Reread that first sentence..
rear fog, valenti
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 09:36 AM
Valenti Japen LED Reverse Tailight USDM Wiring Furtive DIY (Do-It-Yourself) Guides 12 08-21-2015 09:31 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
Valenti Tail Lamps and Tommy Kaira Rear Spoiler harajukukei Cosmetic Modification (Interior/Exterior/Lighting) 19 06-04-2013 07:01 PM
Alternate TRD Rear Bumper Possibilities Breeze Loo Cosmetic Modification (Interior/Exterior/Lighting) 3 05-06-2013 01:06 PM
