Old 10-23-2014, 08:16 PM   #43
Turdinator
Señor Member
Turdinator's Avatar
That is a nice flat torque curve @maxjedi it must be nice to drive.
@DeliciousTuning am i reading it right that after he installed the exhaust it ran leaner? Is that a concern?
1974 TA22 Celica
2013 86 GT
Old 10-24-2014, 02:07 AM   #44
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
I don't think AFRs should be discussed without real data from a wideband sensor. So I decided to provide some (with Invidia exhaust), from a single WOT run. Looks good to me, it's in the 11s with full boost:
"AFR" "Manifold Pressure PSI"
12.68693065 0.1408154688
13.00444038 2.348774272
12.87946899 3.20754053
12.61551843 4.270246433
12.46802472 5.332952335
12.49686427 6.232645256
12.96983291 7.213497832
13.31123827 8.235277071
13.44390021 8.644543705
13.11100938 9.62539628
12.82481117 10.03396924
12.21972992 10.68810218
12.064271 11.01551549
12.43012131 11.79242842
11.86651408 12.11914806
11.46550698 12.36470804
11.32570382 12.48679435
11.26775006 12.32378137
11.81844816 12.11914806
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
The Following 2 Users Say Thank You to maxjedi For This Useful Post:
DeliciousTuning (10-26-2014), Turdinator (10-26-2014)
Old 10-24-2014, 03:46 AM   #45
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I am curious how the SBD kit will go with this tune compared to the ecutek and OFT tunes they offer with the kit. Can you post you impressions and maybe a dyno in future?
Hmm...isn't ecutek the preferred option when running FI? I've asked jamesm before if he could e-tune with OFT and he said not recommended, as it lacks many necessary features to do it safely. As much as I hate the ecutek model, I'd still be using them when I eventually go ahead with FI.
@maxjedi, is your F-N-G map "stock" as received, or did you need to get it revised or fine-tuned further after install?
Fizz is offline   Reply With Quote
Old 10-24-2014, 08:46 AM   #46
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Yes, those charts were done on the first file received from Bill, no additional tweaking.
Calum (10-24-2014), DeliciousTuning (10-26-2014)
Old 10-26-2014, 06:35 PM   #47
Turdinator
Señor Member
Turdinator's Avatar
Not a good thread for it but there is an OTS tune for the SBD turbo kit from OFT. The F-N-G tune from Delicious appears to be smoother and make more power than the OTS Ecutek tune SBD provide, which makes more power than the OFT tune again.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
Fizz (10-26-2014)
Old 10-26-2014, 06:46 PM   #48
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Delicious Flash & GO Tunes for ALL FORCED INDUCTION Applications - Q&A
Peak power is great and all, but driveability is just as important imo. The FNG tune feels like an oem tune when driving around town
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 3 Users Say Thank You to protpibe For This Useful Post:
DeliciousTuning (10-26-2014), Kiske (10-26-2014)
Old 10-26-2014, 08:23 PM   #49
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Does anyone have a dyno comparison between the AVO Stg1 base map and the Flash-n-Go?
Also looking for reviews/comments from those who have switched from the AVO base map to FNG.
Old 10-26-2014, 09:09 PM   #50
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We are working on some new developments now. Here is what we have in the works.
BETA Testing
- Closed Loop Boost Control
ALPHA Testing
- Closed Loop WOT Fuel Control
Development (coming 2015)
- Boost Control from your Android/iPhone device
- Desired Air/Fuel from your Android/iPhone device
More to come.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
8686 (10-26-2014), Shit Luck (10-28-2014)
Old 10-26-2014, 09:58 PM   #51
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Correct me if I'm wrong but this is how i've interpreted this tuning. If I bought a SC, say a JR SC, and needed to get tuning for it, this would work with it? Instead of using their tuning software?
Old 10-27-2014, 12:20 AM   #52
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Originally Posted by DeliciousTuning View Post
BETA Testing
Can you give more details about this ? Does it mean variable target boost depending on some sensor inputs ?
Old 10-27-2014, 12:54 AM   #53
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
in for the long haul. curious to see the reliability in long term testing
Old 10-27-2014, 08:43 AM   #54
qtwre
Drives: White FR-S
I don't have a dyno comparison but I can describe the difference I noticed. The AVO base map is ok, but the car feels like you've tacked a turbo onto it. It kind of jumps a bit around the boost transition. Acceleration could be smoother. The FNG map makes it feel like the car was built with a turbo. There is no noticeable transition into boost. The power just builds. Little throttle actions are a big difference too. I can't speak to the power difference because I installed a boost controller at the same time (why wouldn't you?) but I'm sure the FNG tune is more efficient.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
Fizz (10-27-2014)
Old 10-27-2014, 10:13 AM   #55
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks, yeah I was going to ask about low speed driving with small throttle openings. Which boost controller are you using by the way?
I asked a local ecutek tuner about speed density tunes and he advised against it saying they're great for high hp applications with custom intakes, but the daily driving in traffic will suck.
Old 10-27-2014, 10:30 AM   #56
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok stupid question time, but I'd like to know if there are any negative affects on the engine if i used say 93 octane fuel on a 91 map? Apart from lack of power of course...
And will I need to upgrade the map sensor to use FNG tunes? Or will the stock sensor be just fine?
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
