Old 10-25-2014, 04:19 AM   #127
s2d4
s2d4's Avatar
Originally Posted by Fizz View Post
Would E85 get rid of the occasional tip in knock I still get when shifting gears under certain conditions?
I used to be able to reproduce it every time, now I always fail at doing that like 1 in 20. Like once in a week of driving, and only tiny as well.
The Following User Says Thank You to s2d4 For This Useful Post:
Fizz (10-25-2014)
Old 10-25-2014, 10:04 AM   #128
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You mean you could always reproduce it when on 98? Or when you first started using E85?
Fizz is offline   Reply With Quote
Old 10-25-2014, 11:36 AM   #129
s2d4
s2d4's Avatar
Yeap, 98.
Old 10-26-2014, 07:32 AM   #130
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by mid_life_crisis View Post
I logged the drive to work, which means mostly fairly steady cruising, a little stop and go, a couple of hard runs passing people.
I'm seeing some commanded AFRs of 15, with actual of 20. The engine load shows as .15 or a little higher, so this is probably cruising on the highway. Is that normal on E85?
is that with throttle closed ?? if so thats normal.
It could be. That's the problem with logging such a long drive. It's hard to remember what was going on at a particular time.
Your log should tell you this, provided you have selected it as a parameter to log.
ZZT86 is offline   Reply With Quote
Old 10-26-2014, 08:37 AM   #131
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
Has anyone gone back to 93 because of gas prices? Im on the fence now.
MstrSHAKE is offline   Reply With Quote
Old 10-26-2014, 10:09 AM   #132
mid_life_crisis
Drives: FR-S 10 #103 AT
I don't think anyone is running ethanol to save money. The mileage is not as good, so fuel costs end up comparable anyway. The whole point for people like us is power, although some would do it for the perceived drivability improvements.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-26-2014, 05:07 PM   #133
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I just went back last night, and gas price was one of many factors for me. 27mpg/93 vs 21mpg/E85 and here E85 cost more right now than 93. Add to that, that only 1 station that's out of my way has it, as winter is setting in cold starts are getting to be a pain in the rear, and I have a long trip coming up that I don't want to fill up my trunk with gas cans of E85 or map out places to fill up along the way. I just have to wait a few days for my computer to relearn before I can test the performance difference, and feel.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-26-2014, 05:42 PM   #134
Trettiosjuan
Drives: GT86
Over here it is a lot cheaper so I gain financially (medium term). I love the added driveability and power is nice but far from my main objective.
Also as far fetched it may seem to a (US?) car forum, I actually care that it reduces my carbon footprint a little bit and provides some form of alternative (far from the best but still). Owning a car is my biggest impact, otherwise I live in a small house with geothermal heating, bike shortish distances quite a lot, eat mostly vegetarian and avoid unecessary flights. As for satisfying my driving hobby, this car combo has a very high fun to impact ratio, and suprisingly practical/usable to boot
Please no flaming, not judging anyone here, just want to show what a wide public this car has
Trettiosjuan is offline   Reply With Quote
The Following User Says Thank You to Trettiosjuan For This Useful Post:
Pseud0logik (10-30-2014)
Old 10-26-2014, 11:12 PM   #135
mid_life_crisis
I have trouble wrapping my brain around 93 being less expensive than ethanol. I suppose I should check locally what with the price of gasoline dropping and all.
I knew the car is pretty well global in popularity, but I made the narrow minded mistake of thinking locally. Ethanol is a pain in the butt between getting it and redoing maps to make it usable, at least around here. It's hard to imagine doing it for anything other than an increase in driving pleasure.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Trettiosjuan (10-29-2014)
Old 10-26-2014, 11:34 PM   #136
Target70
Target70's Avatar
It wasn't always cheaper. It used to cost about $3.05/per gallon while 93 was $3.50 per gallon, which still works out to cost more per mile. But right now according to these online sources:
http://www.altfuelprices.com/station...Warner-Robins/
E85 is sitting at $3.25 per gallon
http://www.georgiagasprices.com/inde...s&dl=Y&intro=Y
93 can be as low as $2.95 per gallon
Others have pointed out that they can get E85 for $2.50/gallon and If I could get that price I would just adjust my tune for cold starts, buy some 5gal tanks, and stick with E85. But right now with it being about 22% less mpg, and 9% more expensive, It adds up to about $12 more per tank. (assuming my math isn't screwy).
also without wanting to flame, I think it's been proven that the manufacture of E85 produces more carbon than it's use saves.
Old 10-27-2014, 01:43 AM   #137
DC2R
Drives: 2014 Scion FR-S
Yeah was about same cost per mile but now tempting. I ran on empty light for about forty miles and finally broke down and had to pump 93 since no one had ethanol
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 10-29-2014, 11:29 AM   #138
mid_life_crisis
After driving for a few days with the edited Crank Pulse Width tables, I can say that it was a definite improvement. After editing, every time I started the car cold, it took two attempts. Didn't matter if it was 40 or 60 degrees out. It was like the system needed to be primed or something. It beat the heck out of the half dozen or so it used to take.
I've since gone back to 93 because I got tired of being late for dinner at least once a week because of the lousy availability.
Old 10-29-2014, 08:54 PM   #139
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I wish I could get RR working again because I am down to click click vroom on ever start down to 30 degrees (the lowest it has been this season). If I remember correctly from last winter, I have never needed more than two tries to fire up the car down to I believe as low as -10F.
Luckrider is offline   Reply With Quote
Old 10-29-2014, 10:25 PM   #140
mid_life_crisis
RR?
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
