Old 10-23-2014, 10:43 PM   #15
Mikeez
Engineering Student
Drives: Scion FR-S 2015
My laptop in an Sony Vaio DUO. Supports Bluetooth, and its on windows 8.1
I will check out that software
Mikeez is offline   Reply With Quote
Old 10-23-2014, 11:30 PM   #16
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Originally Posted by Mikeez View Post
How do you do it with the laptop? Windows?
I use Touchscan for Windows: https://www.obdsoftware.net/software/touchscan
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 10-23-2014, 11:51 PM   #17
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
If you need recommendations for a new OBD, I have the full size one from BAFX. I've been using it with my Nexus 7 Tablet for a year and now my new Galaxy Note 4 the past week and it's been pretty solid for me with Torque.
[ame="http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-compatible/dp/B005NLQAHS/ref=sr_1_5?s=automotive&ie=UTF8&qid=1367362509&sr= 1-5&keywords=obd2+scanner+iphone"]http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-compatible/dp/B005NLQAHS/ref=sr_1_5?s=automotive&ie=UTF8&qid=1367362509&sr= 1-5&keywords=obd2+scanner+iphone[/ame]
JonAvalon is offline   Reply With Quote
Old 10-24-2014, 12:59 AM   #18
extrashaky
Drives: 2014 BRZ Limited
I have one of those also, and it worked flawlessly while I was using it. I now have an expensive ScanTool OBDLink LX, and it works even better since it turns itself off and won't drain the battery if the car sits for a while.
From what I read when researching for my own setup, connection problems with Torque like what the OP is experiencing are usually caused by minor differences in the protocols used in some of the cheap bluetooth connectors. These Taiwan operations are making units with bootleg firmware that is old, and that sometimes renders them incompatible with some of the devices and/or software.
From what I've read, switching to a different connector usually solves the problem. If you buy the connector from Amazon, you can pretty easily identify the duds because people will get on there and bitch in the reviews.
One word of warning: Do NOT use any of the software on any CD that comes with the cheap OBDII connectors. Don't even put the CD in your computer. Those things are riddled with malware because those companies put those CDs together from cracked software they find on the internet.
The Following User Says Thank You to extrashaky For This Useful Post:
JonAvalon (10-24-2014)
Old 10-24-2014, 05:02 AM   #19
aagun
Drives: 86
Try disconnect the elm and connected while connecting to the car
aagun is offline   Reply With Quote
Old 10-25-2014, 04:01 PM   #20
Mikeez
Engineering Student
So I tried my set up with my other car (Accord) and it worked fine. Problem is not from the tablet nor elm327. It's the car that rejects it. Why?
Old 10-25-2014, 04:12 PM   #21
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This I have the bafx from Amazon and another mini elm 327 I bought on eBay BOTH came with the same exact mini CDs I immediately threw them out as I've heard all over the place that the devices are great but for some reason that come with malware ridden software you don't need anyway
The devices run perfectly on all my cars though I use torque and Carista all the time with them
Why the low torque? Ds3ire Scion FR-S / Toyota 86 GT86 General Forum 144 11-28-2014 11:49 AM
Lug Nut Torque Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-30-2014 07:45 PM
The Torque Dip. Ozzman Engine, Exhaust, Transmission 25 09-06-2013 02:32 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
