Old 10-23-2014, 10:33 PM   #113
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by ZZT86 View Post
Our 98 > E85 is quite a fair difference. Bum dyno would say at least 20.
Originally Posted by mid_life_crisis View Post
Is that arrow a comparator or a directional?
comparator . . .
So you're saying that Aussie 98 makes 20 more HP than E85? What the hell kind of gas do they sell down there?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-23-2014, 10:42 PM   #114
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No. What he meant was that E85 here should make 20 more hp than Aussie 98. Our 98 here isn't that great actually. Luckily we have 100 (which is actually 98 + E10) and this is slightly better than straight 98. But I was told this fuel is being discontinued next year
I'd love to stay on E85, but it's just a hassle for me because there aren't many around my neck of the woods.
Fizz is offline   Reply With Quote
Old 10-23-2014, 10:47 PM   #115
mid_life_crisis
Well I had an errand that took me by the ethanol station so I got one more tankful. This time I put in one gallon of 93. I also edited the cranking pulse width tables today. I'll see what starting is like in the morning.
Edit: The gallon didn't seem to do anything yesterday morning. This morning, with the edited tables, the car was running on the second try and it's the coldest morning yet.
Old 10-23-2014, 10:57 PM   #116
mid_life_crisis
Then he needs to turn that arrow around. It's confusing.
I know what you mean about the difficulty getting E85. It's in the opposite direction in an area I pretty much never go in my car. You'd think there would be more.
Old 10-23-2014, 11:48 PM   #117
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@Wayno are you going to be there at the next dyno day? Do you reckon you could take snapshots of each dyno graph to share with us?
I'm more interested in seeing the torque/power curves, rather than just knowing what peak power everyone made. This would give a better overall picture of improvements made...
Old 10-24-2014, 12:18 AM   #118
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Yeah I'm more interested in my graph too, which is why I'll run 98 instead of E85. E85 would hide the improvements to the curve made by parts.
Old 10-24-2014, 06:30 AM   #119
ZZT86
ZZT86's Avatar
Drives: BR86
It's pretty obvious that a fuel with a 105 octane rating (E85) is going to make more omph than a 98 octane fuel & so I thought my initial post was self explanatory.
Anyhow . . . what I meant was . . . going FROM 98 to E85 you will GET about 20hp without mods, OFH header is next for me.
ps: for me E85 is all about almost instant acceleration, almost zero knock & a big fat rush of torque from low in the revs which tapers off at the top end. It's not about a big power gain at the peaky end of the rev range. Essentially it pulls really well, torque dip evident but not as with Shell 98. It's a big improvement afaic.
ZZT86 is offline   Reply With Quote
Old 10-24-2014, 10:09 AM   #120
mid_life_crisis
Originally Posted by Superhatch View Post
heh. I was worried about that. I'm about 5k into my e85 tune and it feels stronger than ever. Perrin intake for now is my only engine mod. oft header, Perrin resonated exhaust, shorter rear end, light driveshaft and flywheel and this will feel perfect I think.
"shorter rear end"
Short of some type of FI, this is the single best mod you can do to increase the fun factor of this car. Unless you plan on going FI at some point, this is absolutely the first performance mod you should make. I'm saving my pennies with this in mind. Especially since it's the kind of mod that won't affect your engine warranty.
Old 10-24-2014, 10:39 AM   #121
mid_life_crisis
I logged the drive to work, which means mostly fairly steady cruising, a little stop and go, a couple of hard runs passing people.
I'm seeing some commanded AFRs of 15, with actual of 20. The engine load shows as .15 or a little higher, so this is probably cruising on the highway. Is that normal on E85?
Old 10-24-2014, 04:27 PM   #122
steve99
Drives: FT86
is that with throttle closed ?? if so thats normal.
Old 10-24-2014, 05:53 PM   #123
mid_life_crisis
It could be. That's the problem with logging such a long drive. It's hard to remember what was going on at a particular time.
Old 10-24-2014, 09:00 PM   #124
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Going to do e85 for the first time tonight! Too excited right now! Can't wait to see the difference!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 10-24-2014, 09:20 PM   #125
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Would E85 get rid of the occasional tip in knock I still get when shifting gears under certain conditions?
Old 10-24-2014, 09:29 PM   #126
Wayno
Wayno's Avatar
It gets rid of most, but tip in knock isn't a big deal anyway. At low revs you notice a big difference.
The Following User Says Thank You to Wayno For This Useful Post:
Fizz (10-25-2014)
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
