Old 10-23-2014, 11:11 AM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok dragging this back from the dead because I didn't want to create another thread just for my question.
When installing the overpipe at the same time as the header, do I still need to remove the heat shields, or lift the engine like most do? Or is it much easier to wriggle the overpipe without doing all that when the header is already removed?
Fizz is offline   Reply With Quote
Old 10-23-2014, 11:28 AM   #16
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
hmmm you might be able to wiggle it out to header side.
maybe others who installed all components at same time can help
Old 10-23-2014, 11:31 AM   #17
Anh5oi
Drives: 13 FRS
I installed the OFH and the Overpipe with midpipe last week. I remove the heat shield, there are only 5 bolts. It would be easier if you remove the midpipe mounting.
Current: FRS(Daily), Cayenne(Weekend), 1000RR(Fun), 650Maxim(Fun).
Recently Sold: 13 Boxster(Crash), 08&10 335i, 08 M3, 12 A4, 97 NSX....
Anh5oi is offline   Reply With Quote
Old 10-23-2014, 11:52 AM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
You would still need to jack the engine up or remove the heat shields. I removed the one bolt and jacked the engine up a bit with a wood block under the oil pan. Takes only a minute to do.
malubawla is offline   Reply With Quote
Old 10-23-2014, 12:12 PM   #19
Anh5oi
Drives: 13 FRS
If you planned to do this by yourself via Rhino ramp or jacks, heat shields removal is better since you will have more room under the car to work with.
If you in a shop, jack up the engine would be better.
Old 10-23-2014, 07:40 PM   #20
hattrickey
Drives: Scion FR-S
You still need to remove the heat shields or lift the engine. Either one will work. I replaced the header at the same time as my overpipe, and I had to remove the heat shields.
hattrickey is offline   Reply With Quote
Old 10-23-2014, 10:00 PM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok thanks guys....heat shields are coming off then.
By the way, anyone here with a JDL header + JDL overpipe + Motiv front pipe combo? Any fitment issues with the JDL overpipe to Motiv front pipe?
Old 09-23-2015, 01:27 PM   #22
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by DJCarbine View Post
Another vote for heat shields.
If it takes longer than 5 minutes or the bolts are rusted, jack the engine up
Hey man I'm installing turbo kit right now and this over pipe is a pain in the ass. One of the two nuts that connects to the stock headers is stripped smh. Is their anyway to get it out while still connected to header?
SoCal80six is offline   Reply With Quote
Headers & downpipe/overpipe installation Sonolin Engine, Exhaust, Transmission 23 09-23-2015 01:58 PM
OEM Overpipe Philly758 Want-To-Buy Requests 2 09-04-2013 08:45 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
WTB overpipe jamesm Engine, Exhaust, Bolt-Ons 0 06-30-2013 08:01 PM
Greddy EVO 3 + front and overpipe questions jonbonazza Engine, Exhaust, Transmission 5 06-02-2013 10:00 AM
