Southern California SoCal
Old 10-22-2014, 07:01 AM   #1
mystic
mystic's Avatar
Drives: 2020 BRZ PP CWP
Downpipe / Straightpipe Difference?
Hello friends,
Pardon me for being such a noob (I'm still learning), my car is basically stock (lowered on ST coilovers), however I was looking into getting a new exhaust. I Just wanted to know what the difference is between downpipe / straightpipe is and if both will work without having to do any additional modifications to my car?
I found this (check link below) for a pretty reasonable price, I just don't want to order anything yet until I'm certain it'll work on my car..
[ame="http://www.amazon.com/Tsudo-Scion-Subaru-Catback-Exhaust/dp/B00H4LSR94/ref=sr_1_4?ie=UTF8&qid=1413975069&sr=8-4&keywords=TSUDO+EXHAUST+SCION+FRS"]Amazon.com: Tsudo 2012+ Scion FRS & Subaru Brz Dual Tip Catback Exhaust: Automotive[/ame]
Thanks
mystic is offline   Reply With Quote
Old 10-22-2014, 07:19 AM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Straight piping a car is when you have no cats, mufflers or resonators in your system. Its just a straight pipe (hence the name) back.
A downpipe is something found on turbo cars, you won't need to worry about that.
The exhaust you have linked is a cat back. You'll have no figment problems unless the piece isn't well made.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
mystic (10-22-2014)
Old 10-22-2014, 07:37 AM   #3
mystic
mystic's Avatar
@Bobblehead Makes sense. Thank you! I think I've come down to my decision.. I'd just hopefully like to get a second opinion from somebody. What do you think?
[ame="http://www.amazon.com/Outlet-Exhaust-Muffler-Silencer-Titanium/dp/B00HWIEO6E/ref=sr_1_1?ie=UTF8&qid=1413977691&sr=8-1&keywords=SPEC-D+FRS+EXHAUST"]Amazon.com: 4" Dual Outlet tips Subaru BRZ FRS 4" Exhaust Muffler w/Silencer Titanium Tip: Automotive[/ame]
[ame]http://youtu.be/xjSo6iiKGsA?t=4m15s[/ame] skip to 4:15 for rev / drive by
Old 10-22-2014, 07:42 AM   #4
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Are you getting the exhaust just for the noise factor or are you looking for a power bump?
Build Thread
Instagram
Old 10-22-2014, 07:42 AM   #5
raven1231
I think if you like it get it. Although I do think it sounds pretty good
mystic (10-22-2014)
Old 10-22-2014, 07:49 AM   #6
mystic
mystic's Avatar
Noise would be a good start, since stock is just so quiet it's embarrassing lol. Ideally, I'd like a mid-to-high range of noise, but nothing too obnoxious or illegal. I'm not concerned about power yet, that's something I'll look into later down the line when my wallet wants to participate. First step is affordable exhaust, then probably move onto wheels and tires.
Old 10-22-2014, 07:57 AM   #7
midnight23
well headers aren't foo far away from the catback pricing and you will get a nice bump in power and also a sound factor especially if you go UEL you can get a rumble, food for thought. I won't comment on the illegal part :p
Build Thread
Instagram
Old 10-22-2014, 08:03 AM   #8
mystic
mystic's Avatar
A friend from a local meet told me to do the same. To just get headers. However, he mentioned open flash? and all this stuff I don't understand so if I were to get UEL headers, would I need to purchase anything else to have it installed? Also, if I purchase this Spec-D Exhaust, am I able to add on headers later? Or I would need to purchase another type of exhaust?
for answer my questions.
Old 10-22-2014, 08:07 AM   #9
midnight23
open flash is just a tuning solution for the car, it is not required for the headers but it does help, ecutek is another option as well. nothing else is required to swap headers. If you do purchase this exhaust you can add the headers later without issues as well. The other pieces to be replaced would be the overpipe and front pipe.
exhaust layout = headers > overpipe > front pipe > catback
Build Thread
Instagram
The Following User Says Thank You to midnight23 For This Useful Post:
mystic (10-22-2014)
Old 10-22-2014, 09:24 AM   #10
mystic
mystic's Avatar
thanks for simplifying it for me. that makes total sense now.
Old 10-22-2014, 09:37 AM   #11
mystic
mystic's Avatar
I showed the amazon listing to a friend who understands cars better than I do, and he said from the picture that this exhaust was eliminating the catalytic converter? Trying to figure out if this is true, one. two, if it's bad? ....etc?
can somebody please verify. thanks a millon!
Old 10-22-2014, 09:46 AM   #12
s2d4
s2d4's Avatar
Waste of money, waste of time.
The Following User Says Thank You to s2d4 For This Useful Post:
ramiram1984 (10-22-2014)
Old 10-22-2014, 11:50 AM   #13
qijian
Drives: FRS
Cat-back exhaust means an exhaust that bolts on after the catalytic converter. Can't get simpler than that...
qijian is offline   Reply With Quote
Old 10-22-2014, 07:31 PM   #14
solus
Drives: 2014 Scion FRS (Ultramarine)
the twins have two cats... one in the header and one in the front pipe, as long as you have a stock header and front pipe you will retain the cats. Since you live in LA any changes to the cats will void smog for you. You will need to find a carb compliant header and a high flow cat for the front pipe. Also keep in mind removing the cats will cause your exhaust to smell and fail the sniffer.
the link you posted is just a catback, it will have negligible HP gain by itself... but will have a distinct change in sound.
A complete exhaust system includes Header - over pipe - front pipe - mid pipe - axle back (muffler(s) and tips)
catback is an axle back and mid pipe
solus is offline   Reply With Quote
The Following User Says Thank You to solus For This Useful Post:
mystic (10-22-2014)
VA FS: , FA20club Turbo manifold, downpipe, dump, downpipe and intercooler (with pipi Ryan P Engine, Exhaust, Bolt-Ons 18 02-26-2014 07:08 PM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
Downpipe vs Frontpipe? difference? CodyFRS Engine, Exhaust, Transmission 5 05-28-2013 04:15 PM
Anyone straightpipe vids yet? Bounce Engine, Exhaust, Transmission 8 06-11-2012 04:39 PM
